Re: My first build, all metal delta "The Imp" February 23, 2016 09:11AM |
Re: My first build, all metal delta "The Imp" February 23, 2016 09:05PM |
Re: My first build, all metal delta "The Imp" February 23, 2016 10:38PM |
Re: My first build, all metal delta "The Imp" February 24, 2016 05:41AM |
Re: My first build, all metal delta "The Imp" February 24, 2016 06:00AM |
Re: My first build, all metal delta "The Imp" February 24, 2016 06:27AM |
Re: My first build, all metal delta "The Imp" February 24, 2016 09:25AM |
Re: My first build, all metal delta "The Imp" February 24, 2016 10:17AM |
Re: My first build, all metal delta "The Imp" February 25, 2016 06:26PM |
Re: My first build, all metal delta "The Imp" February 29, 2016 10:49AM |
Re: My first build, all metal delta "The Imp" February 29, 2016 12:31PM |
GroupB
Im gonna have to forget about printing this week, I have to find a proper bed hexagon shape about 9 inch radius, or a big enough circle to reach the side frame
Re: My first build, all metal delta "The Imp" February 29, 2016 01:08PM |
Re: My first build, all metal delta "The Imp" February 29, 2016 04:18PM |
Re: My first build, all metal delta "The Imp" February 29, 2016 09:15PM |
Re: My first build, all metal delta "The Imp" February 29, 2016 11:37PM |
GroupB
I have done maybe 5-6 time your 6 point / 10 probe calibration( manually with paper) and its still not perfect im at .23 deviation right now , the calculator dont stop moving my tower around im now near 4 degree offset on X and im pretty sure when I build it up its was not that bad since I took my time and take million measurement, you think my bed that is not super flat can be the cause?
Another question for you DC or anyone with a large metal delta, what the speed you set ? im now default octoprint at 3000 and 300 extruder but my frame is very heavy, it wont defect if I push the top like a mad man, Im wondering what kind of speed I should start at ?
motor 17HS8401 - 1.8 degree, - 1.8A - 20 tooth gt2 , must be set at 1.5A on the driver right now
Re: My first build, all metal delta "The Imp" March 01, 2016 04:33PM |
Re: My first build, all metal delta "The Imp" March 01, 2016 04:43PM |
Re: My first build, all metal delta "The Imp" March 02, 2016 07:46AM |
Re: My first build, all metal delta "The Imp" March 03, 2016 01:43AM |
G0 F10800 X-0.132 Y-4.782 Z0.100
G21 ;metric values G90 ;absolute positioning M107 ;start with the fan off G28 ;move to endstops G92 E0 ;zero the extruded length G1 F200 E3 ;extrude 3mm of feed stock G92 E0 ;zero the extruded length again G1 F{travel_speed} ;Put printing message on LCD screen M117 Printing...
; Configuration file for The Imp ; Communication and general M111 S0 ; Debug off M550 Ptheimp ; Machine name and Netbios M555 P2 ; Set output to look like Marlin G21 ; Work in millimetres G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves ; Axis and motor configuration M569 P0 S0 ; Drive 0 goes forwards M569 P1 S0 ; Drive 1 goes forwards M569 P2 S0 ; Drive 2 goes forwards M569 P3 S0 ; Drive 3 goes forwards M574 X2 Y2 Z2 S0 ; set endstop configuration M665 R175.40 L349.70 B152.00 H402.02 X0.27 Y0.22 Z0.00 M666 X0.26 Y0.63 Z-0.89 ; put your endstop adjustments here M92 X160 Y160 Z160 ; Set axis steps/mm M201 X1000 Y1000 Z1000 E1000 ; Accelerations (mm/s^2) M203 X18000 Y18000 Z18000 E3600 ; Maximum speeds (mm/min) M566 X1200 Y1200 Z1200 E1200 ; Max instant speed changes mm/min ; Thermistors ;M305 P0 T100000 B3950 R4700 H0 L0 ; set the bed thermistor M305 P1 T100000 B3950 R4700 H0 L0 ; set the first nozzle ;M305 P2 T100000 B3950 R4700 H0 L0 ; set the second nozzle M570 S180 ; Hot end heat timer ; Tool definitions M563 P0 D0 H1 ; Define tool 0 G10 P0 S0 R0 ; Set standby temperatures ;If you have a dual-nozzle build, un-comment the next 2 lines ;M563 P1 D1 H2 ; Define tool 1 ;G10 P1 S0 R0 ; Set standby temperatures M92 E300.62 ; Set extruder steps per mm ; Z probe and compensation definition ;M558 P3 X0 Y0 Z0 ;G31 X0 Y0 Z4.80 P500 ; Set the zprobe height and threshold M556 S78 X0 Y0 Z0 ; Axis compensation here M208 S1 Z-0.1 ; set minimum Z M106 P0 T45 H1:2:3 T0 ;Set Tool 0 by default
; Homing file for TheImp G91 ; use relative positioning G1 S1 X700 Y700 Z700 F2500 ; move all carriages up 700mm, stopping at the endstops G1 S2 X-6 Y-6 Z-6 ; move carriage slowly down 6mm G1 S1 X12 Y12 Z12 F200 ; move all carriages up 12mm, stopping at the endstops G1 S2 X-6 Y-6 Z-6 ; move carriage slowly down 6mm G1 S1 X12 Y12 Z12 F200 ; move all carriages up 12mm, stopping at the endstops G1 Z-5 F2000 ; move head down 5mm G90 ; set absolute position G1 X0 Y0 F2000 ; center the head
Re: My first build, all metal delta "The Imp" March 03, 2016 02:52AM |
Re: My first build, all metal delta "The Imp" March 03, 2016 12:11PM |
dc42
If reducing the travel speed fixes the problem with the head not going all the way to Z=0 then either the travel speed or the acceleration is probably set too high. Please post your config.g file and say what motors and pulleys you are using.
Edit: and as you are using RADDS, what current you have set the stepper drivers to.
Re: My first build, all metal delta "The Imp" March 03, 2016 01:20PM |
Re: My first build, all metal delta "The Imp" March 03, 2016 02:03PM |
Re: My first build, all metal delta "The Imp" March 03, 2016 04:43PM |
Re: My first build, all metal delta "The Imp" March 03, 2016 07:54PM |
Re: My first build, all metal delta "The Imp" March 04, 2016 03:33AM |
Re: My first build, all metal delta "The Imp" March 04, 2016 06:22AM |
Re: My first build, all metal delta "The Imp" March 04, 2016 08:26AM |
Re: My first build, all metal delta "The Imp" March 04, 2016 08:51AM |
Re: My first build, all metal delta "The Imp" March 04, 2016 10:31AM |
