Has anyone tried this type of rod? I'm sure it's an order of magnitude weaker than 6mm carbon tubes, but I'm thinking still strong enough? For a Fisher at least, these are nearly free, being they fit on cutoffs.
Designed for traxxas rod ends, to be cut from 3mm thick s355 steel. Rod is 4mm wide.
Yes, twice the weight of carbon tubes. 50% more than original Fisher acrylic rods (which, most agree, are not good). Strength-wise somewhere between the two.
