Re: FLSUN from AliExpres June 22, 2016 10:14AM |
Re: FLSUN from AliExpres June 27, 2016 06:16PM |
Re: FLSUN from AliExpres June 27, 2016 06:27PM |
Re: FLSUN from AliExpres June 28, 2016 04:23PM |
Re: FLSUN from AliExpres June 28, 2016 04:57PM |
Re: FLSUN from AliExpres July 07, 2016 04:18PM |
Re: FLSUN from AliExpres July 08, 2016 07:12AM |
Re: FLSUN from AliExpres July 13, 2016 08:52AM |
Re: FLSUN from AliExpres July 19, 2016 11:09AM |
Re: FLSUN from AliExpres July 20, 2016 02:26PM |
Re: FLSUN from AliExpres July 22, 2016 02:56PM |
Re: FLSUN from AliExpres August 04, 2016 01:50PM |
Re: FLSUN from AliExpres August 05, 2016 03:50AM |
Re: FLSUN from AliExpres August 13, 2016 12:59PM |
[filament: PLA01] bed_temperature = 55 bridge_fan_speed = 100 cooling = 1 disable_fan_first_layers = 3 extrusion_multiplier = 1 fan_always_on = 0 fan_below_layer_time = 60 filament_colour = #FFFFFF filament_diameter = 1.75 first_layer_bed_temperature = 60 first_layer_temperature = 210 max_fan_speed = 100 min_fan_speed = 100 min_print_speed = 10 slowdown_below_layer_time = 30 temperature = 205 [print: PLA01] avoid_crossing_perimeters = 0 bottom_solid_layers = 3 bridge_acceleration = 0 bridge_flow_ratio = 1 bridge_speed = 60 brim_width = 0 complete_objects = 0 default_acceleration = 0 dont_support_bridges = 1 external_fill_pattern = rectilinear external_perimeter_extrusion_width = 0 external_perimeter_speed = 50% external_perimeters_first = 0 extra_perimeters = 1 extruder_clearance_height = 20 extruder_clearance_radius = 20 extrusion_width = 0 fill_angle = 45 fill_density = 20% fill_pattern = honeycomb first_layer_acceleration = 0 first_layer_extrusion_width = 200% first_layer_height = 0.1 first_layer_speed = 10 gap_fill_speed = 20 gcode_comments = 0 infill_acceleration = 0 infill_every_layers = 1 infill_extruder = 1 infill_extrusion_width = 0 infill_first = 0 infill_only_where_needed = 0 infill_overlap = 15% infill_speed = 80 interface_shells = 0 layer_height = 0.2 max_print_speed = 80 max_volumetric_speed = 0 min_skirt_length = 0 notes = only_retract_when_crossing_perimeters = 1 ooze_prevention = 0 output_filename_format = [input_filename_base].gcode overhangs = 1 perimeter_acceleration = 0 perimeter_extruder = 1 perimeter_extrusion_width = 0 perimeter_speed = 60 perimeters = 3 post_process = raft_layers = 0 resolution = 0 seam_position = aligned skirt_distance = 6 skirt_height = 1 skirts = 1 small_perimeter_speed = 15 solid_infill_below_area = 70 solid_infill_every_layers = 0 solid_infill_extruder = 1 solid_infill_extrusion_width = 0 solid_infill_speed = 20 spiral_vase = 0 standby_temperature_delta = -5 support_material = 0 support_material_angle = 0 support_material_contact_distance = 0.2 support_material_enforce_layers = 0 support_material_extruder = 1 support_material_extrusion_width = 0 support_material_interface_extruder = 1 support_material_interface_layers = 3 support_material_interface_spacing = 0 support_material_interface_speed = 100% support_material_pattern = pillars support_material_spacing = 2.5 support_material_speed = 60 support_material_threshold = 0 thin_walls = 1 threads = 2 top_infill_extrusion_width = 0 top_solid_infill_speed = 15 top_solid_layers = 3 travel_speed = 150 xy_size_compensation = 0 [printer: PLA01] bed_shape = 89.507x9.40756,88.0333x18.7121,85.5951x27.8115,82.2191x36.6063,77.9423x45,72.8115x52.9007,66.883x60.2218,60.2218x66.883,52.9007x72.8115,45x77.9423,36.6063x82.2191,27.8115x85.5951,18.7121x88.0333,9.40756x89.507,0x90,-9.40756x89.507,-18.7121x88.0333,-27.8115x85.5951,-36.6063x82.2191,-45x77.9423,-52.9007x72.8115,-60.2218x66.883,-66.883x60.2218,-72.8115x52.9007,-77.9423x45,-82.2191x36.6063,-85.5951x27.8115,-88.0333x18.7121,-89.507x9.40756,-90x0,-89.507x-9.40756,-88.0333x-18.7121,-85.5951x-27.8115,-82.2191x-36.6063,-77.9423x-45,-72.8115x-52.9007,-66.883x-60.2218,-60.2218x-66.883,-52.9007x-72.8115,-45x-77.9423,-36.6063x-82.2191,-27.8115x-85.5951,-18.7121x-88.0333,-9.40756x-89.507,0x-90,9.40756x-89.507,18.7121x-88.0333,27.8115x-85.5951,36.6063x-82.2191,45x-77.9423,52.9007x-72.8115,60.2218x-66.883,66.883x-60.2218,72.8115x-52.9007,77.9423x-45,82.2191x-36.6063,85.5951x-27.8115,88.0333x-18.7121,89.507x-9.40756,90x0 before_layer_gcode = end_gcode = M104 S0 ; turn off temperature\nG28 X0 ; home X axis\nM84 ; disable motors\n extruder_offset = 0x0 gcode_flavor = reprap layer_gcode = nozzle_diameter = 0.4 octoprint_apikey = octoprint_host = pressure_advance = 0 retract_before_travel = 2 retract_layer_change = 0 retract_length = 2 retract_length_toolchange = 10 retract_lift = 0 retract_restart_extra = 0 retract_restart_extra_toolchange = 0 retract_speed = 40 start_gcode = G28 ; home all axes\nG1 Z5 F5000 ; lift nozzle\n toolchange_gcode = use_firmware_retraction = 0 use_relative_e_distances = 0 use_volumetric_e = 0 vibration_limit = 0 wipe = 0 z_offset = 0
Re: FLSUN from AliExpres August 14, 2016 06:52AM |
Re: FLSUN from AliExpres August 14, 2016 09:29AM |
Re: FLSUN from AliExpres August 21, 2016 08:59AM |
Re: FLSUN from AliExpres August 22, 2016 01:04PM |
Re: FLSUN from AliExpres August 23, 2016 04:38PM |
Re: FLSUN from AliExpres September 08, 2016 12:58PM |
Re: FLSUN from AliExpres September 09, 2016 09:11AM |
Re: FLSUN from AliExpres September 24, 2016 08:43AM |
Re: FLSUN from AliExpres October 01, 2016 05:31PM |
Re: FLSUN from AliExpres October 03, 2016 10:34PM |
Re: FLSUN from AliExpres October 06, 2016 10:38AM |
Re: FLSUN from AliExpres October 06, 2016 10:44AM |
Re: FLSUN from AliExpres October 09, 2016 07:28PM |
Re: FLSUN from AliExpres October 09, 2016 07:31PM |
Re: FLSUN from AliExpres October 09, 2016 07:42PM |
Re: FLSUN from AliExpres October 09, 2016 08:26PM |
