dc42 auto-calibration doesn't go all the way to the bed March 11, 2016 08:35PM |
Re: dc42 auto-calibration doesn't go all the way to the bed March 11, 2016 09:17PM |
Re: dc42 auto-calibration doesn't go all the way to the bed March 11, 2016 09:46PM |
Re: dc42 auto-calibration doesn't go all the way to the bed March 11, 2016 11:08PM |
; Configuration file for Mini Kossel kit from Think3DPrint3D
; Communication and general
M111 S0 ; Debug off
M550 MiniKossel ; Machine name and Netbios name (can be anything you like)
M551 MiniKossel ; Machine password (used for FTP)
M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED ; MAC Address
;*** Adjust the IP address and gateway in the following 2 lines to suit your network
M552 P192.168.0.120 ; IP address (0 = use DHCP)
M554 P192.168.0.1 ; Gateway
M553 P255.255.255.0 ; Netmask
M555 P2 ; Set output to look like Marlin
M575 P1 B57600 S1 ; Comms parameters for PanelDue
G21 ; Work in millimetres
G90 ; Send absolute coordinates...
M83 ; ...but relative extruder moves
; Axis and motor configuration
M569 P0 S0 ; Drive 0 goes forwards
M569 P1 S0 ; Drive 1 goes forwards
M569 P2 S0 ; Drive 2 goes forwards
M569 P3 S0 ; Drive 3 goes forwards
M569 P4 S0 ; Drive 4 goes forwards
M574 X2 Y2 Z2 S1 ; set endstop configuration (all endstops at high end, active high)
;*** The homed height is deliberately set too high in the following - you will adjust it during calibration
M665 R109 L218.0 B85 H180 ; set delta radius, diagonal rod length, printable radius and homed height
M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
M92 X100 Y100 Z100 ; Set axis steps/mm
M906 X300 Y300 Z300 E500 I60 ; Set motor currents (mA) and increase idle current to 60%
M201 X1000 Y1000 Z1000 E1000 ; Accelerations (mm/s^2)
M203 X20000 Y20000 Z20000 E3600 ; Maximum speeds (mm/min)
M566 X1200 Y1200 Z1200 E1200 ; Maximum instant speed changes mm/minute
; Thermistors
;*** If you have a Duet board stickered "4.7K", change R1000 to R4700 to the following M305 commands
M305 P0 T100000 B3950 R1000 H30 L0 ; Put your own H and/or L values here to set the bed thermistor ADC correction
M305 P1 T100000 B3974 R1000 H30 L0 ; Put your own H and/or L values here to set the first nozzle thermistor ADC correction
M305 P2 T100000 B3974 R1000 H30 L0 ; Put your own H and/or L values here to set the second nozzle thermistor ADC correction
M570 S180 ; Hot end may be a little slow to heat up so allow it 180 seconds
; Tool definitions
M563 P0 D0 H1 ; Define tool 0
G10 P0 S0 R0 ; Set tool 0 operating and standby temperatures
;*** If you have a dual-nozzle build, un-comment the next 2 lines
;M563 P1 D1 H2 ; Define tool 1
;G10 P1 S0 R0 ; Set tool 1 operating and standby temperatures
M92 E663:663 ; Set extruder steps per mm
; Z probe and compensation definition
;*** If you have an IR zprobe instead of a switch, change P4 to P1 in the following M558 command
M558 P1 X0 Y0 Z0 ; Z probe is a switch and is not used for homing any axes
G31 X0 Y0 Z4.8 P500 ; Set the zprobe height and threshold (put your own values here)
;*** If you are using axis compensation, put the figures in the following command
M556 S78 X0 Y0 Z0 ; Axis compensation here
M208 S1 Z-0.2 ; set minimum Z
T0 ; select first hot end
; Auto calibration routine for delta printers
; Before running this, you should have set up your zprobe Z offset to suit your build, in the G31 command in config.g.
M561 ; clear any bed transform, otherwise homing may be at the wrong height
G31 X0 Y0 ; don't want any probe offset for this
G28 ; home the printer
;*** Remove the following line if your Z probe does not need to be deployed
;M98 Pdeployprobe.g ; deploy the mechanical Z probe
; The first time the mechanical probe is used after deployment, it gives slightly different results.
; So do an extra dummy probe here. The value stored gets overwritten later. You can remove this if you use an IR probe.
;G30 P0 X0 Y0 Z-99999
; Probe the bed and do 6- or 7-factor auto calibration
G30 P0 X-73.6 Y-42.5 Z-99999 ; X tower
G30 P1 X0 Y-85 Z-99999 ; between X and Y towers
G30 P2 X73.6 Y-42.5 Z-99999 ; Y tower
G30 P3 X73.6 Y20 Z-99999 ; between Y and Z towers
G30 P4 X0 Y67 Z-99999 ; Z tower
G30 P5 X-73.6 Y20 Z-99999 ; between Z and X towers
G30 P6 X-36.8 Y-21.25 Z-99999 ; half way to X tower
G30 P7 X36.8 Y-21.25 Z-99999 ; half way to Y tower
G30 P8 X0 Y42.5 Z-99999 ; half way to Z tower
G30 P9 X0 Y0 Z-99999 S6 ; centre, and auto-calibrate 6 factors
;*** Remove the following line if your Z probe does not need to be retracted
;M98 Pretractprobe.g ; retract the mechanical Z probe
G1 X0 Y0 Z150 F15000 ; get the head out of the way of the bed
Re: dc42 auto-calibration doesn't go all the way to the bed March 12, 2016 01:31AM |
Re: dc42 auto-calibration doesn't go all the way to the bed March 12, 2016 02:11AM |
