Z axis not able to remain constant during lateral move
Posted by murd0cun
April 14, 2016 11:19AM
Hi all,
I am building my second mini kossel printer. The first one workes well and I able to print with it.
The second one is giving me a lot of hard time. The problem is that the Z axis will not remain constant while the printer moves on x and y axis.
I bring the printing head as close as possible to the plate using pronterface and then I start moving in 10 mm increments on the X and Y axis. While moving, the head will raise to about 1mm while moving to the back (+y) and will start touching the plate coming forward (-y). The same happens on the X axis. Negative x will make the head raise and positive x will make it start digging in the plate.
So far, I have tried with no results:
- make sure the plate is level
- make sure the endstops are at the same height on the towers
- make sure the belts are tight
- make sure the arms (the 6 arms from the moving cart to the extruder) are of the same size
- make sure the arms can move free
- make sure the towers are at the same distance from each other
- make sure the settings in Marlin for the diagonal_rod and the others are good
I do not understand what makes it different for this printer then the other one I've done. They are exactly the same.
Can you please advise?
Thank you!
Zoli
Re: Z axis not able to remain constant during lateral move
April 14, 2016 11:49AM
Have you checked the horizontal offset? That value will change the cupping or doming behavior.
April 14, 2016 11:56AM
Thanks for the quick reply!
I am not sure if I got your answer right...
Are you talking about this line:
// Horizontal offset of the universal joints on the carriages.
#define DELTA_CARRIAGE_OFFSET 22.0 // mm
If yes, then the answer is yes, That is the correct value for my mini delta.
Thank you again,
Zoli
April 14, 2016 09:03PM
Start at 1905.1 in this document:
[docs.google.com]
April 15, 2016 02:15AM
Hi Nebbian,
Thank you for the link. I didn't know that such a detailed document exists.
I am currently at work but later this evening I will try that section.
I will post back my findings.
Regards,
Zoli
