Dual extruder Delta machine April 28, 2016 09:02PM |
Re: Dual extruder Delta machine April 28, 2016 09:59PM |
Re: Dual extruder Delta machine April 28, 2016 11:19PM |
Re: Dual extruder Delta machine April 28, 2016 11:32PM |
Re: Dual extruder Delta machine April 28, 2016 11:35PM |
Re: Dual extruder Delta machine April 29, 2016 02:33AM |
Re: Dual extruder Delta machine April 29, 2016 04:16AM |
Re: Dual extruder Delta machine April 29, 2016 05:23AM |
Re: Dual extruder Delta machine April 29, 2016 08:57AM |
bgkdavis
The problem I have with mixing extruders is I've yet to see a slicer package that can make good use of them
Of course if/when they become popular then Im sure the slicer software will follow
Re: Dual extruder Delta machine April 30, 2016 10:54PM |
Re: Dual extruder Delta machine May 01, 2016 03:28AM |
Re: Dual extruder Delta machine May 01, 2016 09:31AM |
Re: Dual extruder Delta machine May 01, 2016 03:41PM |
Adventprinter
So im thinking the diamond hotend is the way to go. i think using 2040 ali extrusions is a good choice so i've been looking into it.
i managed to come across this 2040 delta kossel
but unfortunately the files for the vertexes are missing and the author is also MIA which causes a bit of a problem in getting the vertexes unfortunatly
anyone know of any other 2040 kossel builds?
Re: Dual extruder Delta machine May 01, 2016 04:31PM |
dc42
bgkdavis
That is certainly a problem at present. Also I hear that the mixing in the Diamond is not perfect, so the colour of the print when mixing depends somewhat on the printing direction.
Re: Dual extruder Delta machine May 01, 2016 06:37PM |
Re: Dual extruder Delta machine May 01, 2016 07:28PM |
PRZ
Delta-six OpenScad files and STL files are in the zip file in the 'files and drawing' tab of the link you have given. They are more detailed than what is in the simulation, so what do you mean when you say the Vertexes files are missing ?.
Re: Dual extruder Delta machine May 04, 2016 09:17PM |
Re: Dual extruder Delta machine May 05, 2016 08:29AM |
Re: Dual extruder Delta machine May 05, 2016 09:30AM |
Adventprinter
what are peoples thoughts on flying extruders? is it worth incorporating it at the start or something i should consider down the road once i have the machine built and running for a few prints first?
Re: Dual extruder Delta machine May 07, 2016 07:35AM |
Re: Dual extruder Delta machine May 07, 2016 09:36AM |
Adventprinter
Would this stepper be suitable you recon
bipolar high torque Nema 17 stepper motor with 1.8° step angle (200 steps/revolution). Each phase draws 2A, allowing for a holding torque of 59Ncm(83.6oz.in).
Specification
Manufacturer Part Number 17HS19-2004S1
Step Angle 1.8°
Step Accuracy 5%
Holding Torque 59Ncm(83.6oz.in)
Rated Current/phase 2.0A
Phase Resistance 1.4ohms
Voltage 2.8V
Inductance 3.0mH±20%(1KHz)
Weight 400g
Re: Dual extruder Delta machine May 07, 2016 03:31PM |
Adventprinter
Specification
Step Angle 1.8°
Step Accuracy 5%
Voltage 2.8V
Weight 400g
Re: Dual extruder Delta machine May 07, 2016 03:42PM |
PRZ
I assume your question is about steppers for extruder, not for movement ?
Re: Dual extruder Delta machine May 08, 2016 08:23AM |
Re: Dual extruder Delta machine May 19, 2016 01:08PM |
