Re: Zonestar D810B from AliExpress June 09, 2016 11:19AM |
Re: Zonestar D810B from AliExpress June 09, 2016 11:25AM |
tidehunter
Hi guys!
Could some1 send config of D810 for Cura?
I can not print any model. My Extruder freezes at about 1 cm from the bed and does not move while plastic is extruded.
But with test gcode files it starts printing.
Re: Zonestar D810B from AliExpress June 09, 2016 12:07PM |
Re: Zonestar D810B from AliExpress June 09, 2016 09:19PM |
Re: Zonestar D810B from AliExpress June 10, 2016 02:14AM |
Re: Zonestar D810B from AliExpress June 10, 2016 04:24AM |
tidehunter
I mean for Cura (software)
all necessary settings
update:
I have also download repitier, but I don't know where should I get all settings.
There is no any information in manual.. and I'm new in this.
Re: Zonestar D810B from AliExpress June 10, 2016 05:21AM |
Re: Zonestar D810B from AliExpress June 10, 2016 05:01PM |
Re: Zonestar D810B from AliExpress June 10, 2016 05:31PM |
tidehunter
Thanks a lot for the explanation, also I need all printer setting like Travel Feed Rate, Z-Axis Feed Rate etc.
update:
when I slice the model I get the coordinates with nulls like these:
12:29:24.465 : X:-0.00 Y:-0.01 Z:15.000 E:576.7647
12:29:24.465 : X:-0.00 Y:-0.01 Z:15.000 E:577.2235
12:29:24.465 : X:-0.00 Y:-0.01 Z:15.000 E:577.4235
12:29:24.505 : X:-0.00 Y:-0.01 Z:15.000 E:577.8000
What do I do wrong?
Re: Zonestar D810B from AliExpress June 11, 2016 03:41PM |
Re: Zonestar D810B from AliExpress June 12, 2016 02:30PM |
Hally
Hi Hergonoway,
The new version effector need some custom components, include:
1. 3 pcs "spring generating"
2. 1 acrylic piece to mount the hotend module
3. 1 metal piece to mount the extruder fan and heater sink.
We will put this upgrade module on the racks of our store in the next week.
Re: Zonestar D810B from AliExpress June 12, 2016 08:02PM |
Re: Zonestar D810B from AliExpress June 13, 2016 02:54AM |
frankvdh
Just a quick thought for Hally...
I suggest that you move the mounting holes for the bed so that they're away from the uprights. Where they are now, it is awkward to adjust the bed level, since the carriages and rods are in the way. I don't think there's any need for the bed mount screws to be aligned with the uprights.
People with existing printers might want to drill new holes in the bottom acrylic to change the position of those mounts.
Frank
Re: Zonestar D810B from AliExpress June 13, 2016 07:18AM |
Hergonoway
frankvdh
Frank
personally I''ve changed this system to a printed wheel adjustment below the bed. basically the V shape screw is locked to the hexa threaded spacer with loctite (just the tip of the screw to keep the benefit of the spring movement), there I've printed an adjustment wheel which is place on the hexa spacer and then I change the screw below the acrylic plate to a longer one and block it with a autolock nut. Now I can align the hotend to the tower and easily adjust the bed from below, without moving everything an screw it from above
This method keep the same "possible spring movement" on each tower axis whatever the bed level is.
I'm currently working on an improved version in order to stack a glass plate of the same size or bigger onto the bed.
Re: Zonestar D810B from AliExpress June 14, 2016 10:15AM |
Re: Zonestar D810B from AliExpress June 15, 2016 05:46PM |
Re: Zonestar D810B from AliExpress June 15, 2016 06:12PM |
Re: Zonestar D810B from AliExpress June 15, 2016 07:23PM |
Re: Zonestar D810B from AliExpress July 05, 2016 09:43AM |
Re: Zonestar D810B from AliExpress July 14, 2016 07:33PM |
Re: Zonestar D810B from AliExpress July 26, 2016 11:09PM |
Re: Zonestar D810B from AliExpress July 26, 2016 11:11PM |
tidehunter
Hally
Hi Hergonoway,
Hi Hally,
When are u going to store it?
Re: Zonestar D810B from AliExpress July 26, 2016 11:18PM |
frankvdh
Frank
Re: Zonestar D810B from AliExpress July 27, 2016 06:12AM |
Hally
frankvdh
Frank
Thanks Frank, we will do it later.
Re: Zonestar D810B from AliExpress August 04, 2016 01:59PM |
Hally
Hi Hergonoway,
Re: Zonestar D810B from AliExpress August 04, 2016 02:03PM |
Re: Zonestar D810B from AliExpress August 04, 2016 05:25PM |
I don't think anyone wants to spend 20USD + delievery for the parts they already have.
Re: Zonestar D810B from AliExpress August 05, 2016 11:53AM |
frankvdh
I think the idea is that these are redesigned parts... i.e. parts that we don't already have.
Re: Zonestar D810B from AliExpress August 06, 2016 12:14PM |
Re: Zonestar D810B from AliExpress August 06, 2016 01:11PM |
tidehunter
Hergonoway,
Looks like great. Could you let me know pls where did u get models and other parts of the clamp system and the glass?
and sry, but I didn't get what is 2020 structure? (I'm new with this)
