Effector moving up/down slightly during horizontal moves May 05, 2016 05:32AM |
Re: Effector moving up/down slightly during horizontal moves May 05, 2016 07:22AM |
Is the sound approximately the same for all three towers?
Re: Effector moving up/down slightly during horizontal moves May 06, 2016 10:56AM |
Re: Effector moving up/down slightly during horizontal moves May 06, 2016 12:38PM |
Re: Effector moving up/down slightly during horizontal moves May 10, 2016 11:13PM |
nebbian
Is the height dependant on the direction you got there? ie. X -> Y is a different height than Y -> X? Or is it just a case of the head being the wrong height when between towers?
If the latter, I'd highly recommend going back over your build with a pair of calipers and a set square, and ensure that your towers are parallel and not twisted.
Failing that you can always try out DC42's delta calculator: [escher3d.com]
Re: Effector moving up/down slightly during horizontal moves May 13, 2016 02:37AM |
Re: Effector moving up/down slightly during horizontal moves May 13, 2016 04:38AM |
verdesmarald
For example, moving from home -> X -> Y results in the hotend being slightly higher than moving directly from home -> Y.
Re: Effector moving up/down slightly during horizontal moves May 13, 2016 05:04AM |
Re: Effector moving up/down slightly during horizontal moves May 13, 2016 05:23AM |
Re: Effector moving up/down slightly during horizontal moves May 14, 2016 04:59AM |
Re: Effector moving up/down slightly during horizontal moves May 14, 2016 01:24PM |
Re: Effector moving up/down slightly during horizontal moves May 16, 2016 11:17AM |
Re: Effector moving up/down slightly during horizontal moves May 16, 2016 12:06PM |
verdesmarald
Hi dc,
I'm confused about the second part of your post, the pages on the Pololu website for the A4988 say the current limit is 2.5 times the VREF setting for both the black and regular editions, why would the real current only be half that amount? Also I am not sure what a sense resistor is, or if mine are 0.1 or 0.05 ohms, sorry.
Re: Effector moving up/down slightly during horizontal moves May 16, 2016 04:31PM |
+Quote
verdesmarald
Hi dc,
Anonymous User
Re: Effector moving up/down slightly during horizontal moves May 17, 2016 03:05AM |
dc42
+Quote
verdesmarald
Hi dc,
You are quite right, both types of genuine Pololu driver use 0.05 ohm sense resistors (I thought the regular edition used 0.1 ohms, but I was mistaken). However, most Chinese-built clones use 0.1 ohm resistors, and some may still use 0.2 ohm resistors. See [reprap.org].
The sense resistors are the two largest SMD resistors on the board. If you are lucky, they will have the resistance marked on them, e.g. R100 or R050.
Re: Effector moving up/down slightly during horizontal moves May 17, 2016 03:48AM |
Re: Effector moving up/down slightly during horizontal moves May 17, 2016 06:08AM |
verdesmarald
Worst case I can hook up an ammeter in series with the motor coil and verify it that way, right?
Re: Effector moving up/down slightly during horizontal moves May 17, 2016 07:05AM |
Re: Effector moving up/down slightly during horizontal moves May 17, 2016 07:54AM |
roboprint
dc42
Connecting/disconnecting motors with power applied is what blows stepper drivers.
Sorry for offtopic, but can someone explain why this is happening?
Anonymous User
Re: Effector moving up/down slightly during horizontal moves May 17, 2016 08:45AM |
dc42
roboprint
dc42
I don't know for sure, but it's probably because if you disconnect a stepper motor when it is energised, it will produce a high back emf and for a short time it will spark across the gap where you have just broken the connection. Such a spark will cause very rapid changes in the current flowing, not at all like the smooth current changes you get when the driver itself turns off the current. My guess is that it is these very rapid changes in current that the driver doesn't like. But this is only a guess, it could also be due to the voltage waveform being even sharper than usual. One day when I feel like blowing up a few of my old stepsticks, I may take a look at what exactly happens with an oscilloscope, and see what measures I can find to protect the driver.
Re: Effector moving up/down slightly during horizontal moves August 04, 2016 08:10AM |
