Ripple Eliminator May 08, 2016 05:24PM |
Re: Ripple Eliminator May 08, 2016 05:44PM |
Re: Ripple Eliminator May 08, 2016 08:06PM |
Re: Ripple Eliminator May 08, 2016 08:43PM |
Re: Ripple Eliminator May 08, 2016 10:20PM |
Re: Ripple Eliminator May 08, 2016 10:42PM |
Re: Ripple Eliminator May 09, 2016 07:08AM |
nebbian
It's got nothing to do with isolating regenerative current.
It's to do with reducing the dead zone. Lots more information available here:
[cabristor.blogspot.com.au]
Re: Ripple Eliminator May 09, 2016 08:21AM |
interesting remark.Quote
PRZ
low inductance stepper are desirable
Re: Ripple Eliminator May 09, 2016 10:11AM |
Re: Ripple Eliminator May 09, 2016 11:28AM |
Re: Ripple Eliminator May 09, 2016 07:37PM |
uvarovkv
Thanks for your answer.
But i afraid to use LED 24v PSU with my poor electrical skills. Now i am using the Xbox PSU (~203w), in my opinion its safer to use and look nice instad of PC PSU or LED PSU.
But reading other forums threads i understood that using 0.9° stepper will give more accuracy... if it's realy true, i am ready to sacrifice print speed and try them in my setup.
As for the driver now i will wating the new DuetNG board with embedded drivers.
Re: Ripple Eliminator May 09, 2016 08:24PM |
Re: Ripple Eliminator May 10, 2016 02:07PM |
dc42
uvarovkv
The 0.9deg motors on my delta have a very similar specification to the ones you propose to use. With 12V supply, I found I was limited to about 150mm/sec travel speed. 24V is recommended for these motors. OTOH if you intend to wait for the Duet NG then you may find that a motor with a current rating of around 2A instead of 1.68A and correspondingly lower inductance would give you higher speed at 12V.
I presume your planned machine has either a small bed or an unheated bed. If the bed is large or heated, then you need to use 24V or mains power to heat the bed anyway.
Re: Ripple Eliminator May 10, 2016 04:43PM |
uvarovkv
It's a good news!
But i want to ask, if i'll use 42BYGHM810 with 1.8 mH inductance which rated at 2.4A... the new Duet and its drivers will be able to survive this current?
Re: Ripple Eliminator May 11, 2016 04:29AM |
Re: Ripple Eliminator November 28, 2016 12:36PM |
fredchan
We are making this Ripple Eliminator according discussion from HK 3D Printer Forum base on Kossel Mini Delta 3D Printer
[www.hkepc.com]
For Delta type 3D Printer, it reduce the noise from motor and get great appearance impovement,
For cardesian type 3D Printer, it will reduce the noise from the motor
Re: Ripple Eliminator July 19, 2017 10:36PM |
