linear rods VS aluminum extrusions and pulleys May 17, 2016 01:11PM |
Re: linear rods VS aluminum extrusions and pulleys May 17, 2016 02:09PM |
Re: linear rods VS aluminum extrusions and pulleys May 17, 2016 08:20PM |
Re: linear rods VS aluminum extrusions and pulleys May 17, 2016 10:52PM |
Re: linear rods VS aluminum extrusions and pulleys May 18, 2016 04:49AM |
Re: linear rods VS aluminum extrusions and pulleys May 18, 2016 06:56AM |
Re: linear rods VS aluminum extrusions and pulleys May 18, 2016 07:40AM |
Re: linear rods VS aluminum extrusions and pulleys May 18, 2016 04:06PM |
Re: linear rods VS aluminum extrusions and pulleys May 19, 2016 06:50AM |
Re: linear rods VS aluminum extrusions and pulleys May 19, 2016 07:29AM |
hercek
My preference for linear rod over linear rails is easy to explain. I do not want to buy this stuff from a shop which does not specify tolerances.
Re: linear rods VS aluminum extrusions and pulleys May 19, 2016 09:48AM |
Not sure what rails you are buying but the ones I buy have most dimensions toleranced, not only that but the tolerance for the mounting surface is also specified.Quote
bgkdavis
hercek
Rod manufacruers specify tolerances because rods have a huge range of uses where the tolerance is critical, this is not true for rails, the only dim thats normally toleranced is the mounting heights.
