Why Spindle driven Delta's are more precise than Belt Driven May 20, 2016 02:58AM |
Re: Why Spindle driven Delta's are more precise than Belt Driven May 20, 2016 03:48AM |
Re: Why Spindle driven Delta's are more precise than Belt Driven May 20, 2016 04:38AM |
Re: Why Spindle driven Delta's are more precise than Belt Driven May 20, 2016 04:54AM |
Re: Why Spindle driven Delta's are more precise than Belt Driven May 20, 2016 05:01AM |
Admin Registered: 16 years ago Posts: 13,889 |
Re: Why Spindle driven Delta's are more precise than Belt Driven May 20, 2016 07:50AM |
Re: Why Spindle driven Delta's are more precise than Belt Driven May 20, 2016 09:04AM |
evandene
Quite a few Delta's on the market are offered with Timing Belt driven sliders and I wonder if anyone ever has questioned this system.
A spindle driven slider can be much more precise as a timing belt driven one. Especially when printing small parts in the center of the print bed of a Delta printer, precise movements do matter.
Maybe you have noticed that when printing small parts in the print bed center with holes of about 4 mm (0.157"), the holes are not round anymore. (Timing belt driven delta) There is a reason for that behavior and it has nothing to do with your build but more with the quantity of steps per unit the system needs.
In the center all three parallel arms will move much more aggressively per unit as out of center. (At least two of them) (See schematics attached)
For a given belt driven system, for 1 mm movement it takes 5 MOTOR steps (1/16th driver makes it 80 micro steps); 0.1 mm takes 0.5 MOTOR step, what won't happen, it will be skipped till the next full step, due to many variables working together with Murphy.
A spindle system with a spindle pitch of 2 mm will take 100 MOTOR steps for the movement of 1 mm (1/16th driver makes it 1600 micro steps); 0.1 mm takes 10 motor steps and the system will do most probably his job.
See attached schematics and new design picture below
Re: Why Spindle driven Delta's are more precise than Belt Driven May 20, 2016 04:48PM |
Re: Why Spindle driven Delta's are more precise than Belt Driven May 20, 2016 05:36PM |
Re: Why Spindle driven Delta's are more precise than Belt Driven May 20, 2016 07:30PM |
Re: Why Spindle driven Delta's are more precise than Belt Driven May 20, 2016 09:22PM |
Re: Why Spindle driven Delta's are more precise than Belt Driven May 20, 2016 09:40PM |
Koko76
It's not shocking, and it has been "though of before".
Re: Why Spindle driven Delta's are more precise than Belt Driven May 20, 2016 11:14PM |
It's Ok dude, sometimes I forget that posting useful information like links to websites with good practical information is wasted on those who would rather be smart mouthed jerks. You have a lovely one ok bud.Quote
bgkdavis
Koko76
Sometime I forget that sarcasm is wasted on those who speak English as a foreign language
Re: Why Spindle driven Delta's are more precise than Belt Driven May 21, 2016 12:41AM |
Re: Why Spindle driven Delta's are more precise than Belt Driven May 21, 2016 01:21AM |
evandene
I'm doing this for 35 years, i know what I'm doing.
Re: Why Spindle driven Delta's are more precise than Belt Driven May 21, 2016 01:30AM |
Re: Why Spindle driven Delta's are more precise than Belt Driven May 21, 2016 01:38AM |
Re: Why Spindle driven Delta's are more precise than Belt Driven May 21, 2016 02:00AM |
Re: Why Spindle driven Delta's are more precise than Belt Driven May 21, 2016 02:34AM |
Re: Why Spindle driven Delta's are more precise than Belt Driven May 21, 2016 03:07AM |
Re: Why Spindle driven Delta's are more precise than Belt Driven May 21, 2016 10:16AM |
Re: Why Spindle driven Delta's are more precise than Belt Driven May 21, 2016 06:39PM |
Re: Why Spindle driven Delta's are more precise than Belt Driven May 21, 2016 08:30PM |
hercek
I think that you are going to create a pretty printer which will have a really bad price/performance ratio. Or you are going to build a slow printer in which case you should be rather building a cartesian. Anyway if you enjoy building it then just go for it. And post pictures!
Re: Why Spindle driven Delta's are more precise than Belt Driven May 22, 2016 03:23AM |
Re: Why Spindle driven Delta's are more precise than Belt Driven May 22, 2016 04:06AM |
Re: Why Spindle driven Delta's are more precise than Belt Driven May 22, 2016 04:36AM |
evandene
After nice tips, misunderstandings and good idea's, I have decided for; a ball screw 1004 or 1204 with a stroke of 350 mm and a max print speed of 100mm/sec and max travel speed of 150mm/sec.
The stiffness, durability and accuracy is preferred; more speed and acceleration is easy to achieve with other motor drive systems.
Thanks guys
Re: Why Spindle driven Delta's are more precise than Belt Driven May 22, 2016 08:57AM |
Re: Why Spindle driven Delta's are more precise than Belt Driven May 22, 2016 08:58AM |
Re: Why Spindle driven Delta's are more precise than Belt Driven May 22, 2016 01:01PM |
My DTI does not agree.Quote
evandene
All,
Traveling from A B with a stepper driven system Works well if no speed or accurate positioning is required.
Please do following test with your delta printer;
1) go from A to B in Z height like 25 mm (1") and measure the real distance. Most probably all it's within a few hundreds of a mm.
2) do this again but now Z= 0.1mm (0.00393"). Asuming you use micro stepping of 1/16 or 1/32 you will notice that sometime the requested positioning is slipped and sometimes double or more executed. This is normal behavior for stepper systems.
See Wikipedia for steppers, 5th paragraph.
I can't have that in my system.
Re: Why Spindle driven Delta's are more precise than Belt Driven May 22, 2016 01:38PM |
