Re: Why Spindle driven Delta's are more precise than Belt Driven May 22, 2016 06:15PM |
evandene
All,
Traveling from A B with a stepper driven system Works well if no speed or accurate positioning is required.
Please do following test with your delta printer;
1) go from A to B in Z height like 25 mm (1") and measure the real distance. Most probably all it's within a few hundreds of a mm.
2) do this again but now Z= 0.1mm (0.00393"). Asuming you use micro stepping of 1/16 or 1/32 you will notice that sometime the requested positioning is slipped and sometimes double or more executed. This is normal behavior for stepper systems.
See Wikipedia for steppers, 5th paragraph.
I can't have that in my system.
Re: Why Spindle driven Delta's are more precise than Belt Driven May 22, 2016 07:38PM |
Re: Why Spindle driven Delta's are more precise than Belt Driven May 23, 2016 05:53AM |
Re: Why Spindle driven Delta's are more precise than Belt Driven June 30, 2016 02:56PM |
Re: Why Spindle driven Delta's are more precise than Belt Driven June 30, 2016 03:04PM |
Re: Why Spindle driven Delta's are more precise than Belt Driven June 30, 2016 06:40PM |
sungod3k
I had some talks with people and got inspired to look for servomotors and to keep compatibility high a converter to take the stepper signal and transform in to pwm for the servomotors.
Re: Why Spindle driven Delta's are more precise than Belt Driven June 30, 2016 07:05PM |
DjDemonD
Here's a leadscrew driven large delta.
[www.youtube.com]
Looks nice and they are using a direct drive extruder on the effector. But I am not sure it's going to be very fast.
Re: Why Spindle driven Delta's are more precise than Belt Driven July 01, 2016 05:17AM |
Re: Why Spindle driven Delta's are more precise than Belt Driven July 01, 2016 05:24AM |
evandene
Kuhling & Kuhling is using a RADDS controler with 1/128 micro stepper driver in their DELTA printer able to run super high frequencies.
The pitch of the lead screws is about 20 mm (close to an inch), no need for a gearbox. NEMA 23 steppers will do the job.
Re: Why Spindle driven Delta's are more precise than Belt Driven July 01, 2016 05:54AM |
Re: Why Spindle driven Delta's are more precise than Belt Driven July 01, 2016 06:07AM |
evandene
Kuhling & Kuhling know how to avoid using gearboxes because of cost and the always under-estimated gearbox efficiency and ever increasing backlash.
When someone can play with the lead-screw pitch, there is no reason for adding costs for a gearbox.
Worm-Wormwheel gearboxes have an efficiency from 45% to 65% (expensive ones) because of the high internal friction.
Planetary gearboxes go from 70% to +90% (super expensive) (stamped sheet-metal gear or hardened and grind gears)
Straight gearboxes go from 65% to max 85% (stamped sheet-metal gear or hardened and grind gears)
Serious supplier do mention the true and guaranteed efficiency and backlash in their spec.
Re: Why Spindle driven Delta's are more precise than Belt Driven July 01, 2016 10:29AM |
