DeltaXY
Posted by PavloG
DeltaXY
May 21, 2016 09:34AM
Hi everyone
I started working on DeltaXY Kinematic
Idea descriped in images and video
Top view:
Video
Math and Web visualization
Current setup allows to have biggest reachability with shortest arms.
My targets:
  • 100x100x100mm build area with smallest possible box (approx 140x200x150mm)
  • Closed build area
  • Fast
  • Cheap
  • Opensource
  • Software - Marlin (i have experience to modify source code)
Z-Axis seems like to be moved platform.
Thanks for your feedback...any suggestions, critique and discussion is appreciated.
P.S. I have printed a few parts of my printer - openscad file will be available a little bit later
My blog
Re: DeltaXY
May 21, 2016 11:13PM
First printed prototype (e3d v6 mouned - not visible from this point of view)
4-LM6UU, 6-623 bearings, 2-200mm 6mm rods
My blog
Re: DeltaXY
May 22, 2016 02:22AM
My biggest concerns with this idea is how are you going to achieve Z axis, and the deflection under load of the arm mechanism between the two rails. which will have a tendency to rotate on the rails, which will put cross axis load on the mid point bearings, I reckon your really going to suffer from a lack of rigidity.
Your could eliminate the rotation issues by having two pairs of parallel rails on each side and replace each mid point bearing with a pair of bearings separated vertically.
When it comes to printing you are going to need some methodology to accurately calibrate the position of the tool point and take into account any eccentricity between the axis of rotation and the toolpoint position, especially if you plan on using an E3D style hot end
RepRapPro Mendel 3 Tricolour
RepRapPro Fisher
-Carbon Arms
-Easy adjust Carriage+effector
-axis stiffness mods
HE3D -600 delta
-Duet 0.8.5
-PanelDue
-DC42 Height probe
-RobotDigg metal components
Simplyfy3D
RS Design Spark CAD
Re: DeltaXY
May 22, 2016 05:16AM
Rigidity is ok (I checked it on real printed prototype) - it is only 130 mm beetween rods.
Also it is possible to use MGN type rails for bigger sizes or 2 rods on each size (as your said)
Calibration seems to be even simpler than regular delta (of course some surprises are possible but I don't afraid)
My blog
Re: DeltaXY
May 24, 2016 02:28AM
Keep going PavloG,
I'm really looking forward to seeing where this one goes.
Fiendishly clever!
Re: DeltaXY
May 25, 2016 11:14AM
Work in progress
My blog
Re: DeltaXY
May 25, 2016 02:23PM
I'm really interested in seeing how this turns out drinking smiley , please keep the updates coming and good luck thumbs up
Re: DeltaXY
May 26, 2016 11:43AM
DeltaXY - work in progress
Dry Run video
Fast Movement video
My blog
Re: DeltaXY
May 27, 2016 03:44AM
Firmware on git hub
Openscad sources on git hub
Edited 3 time(s). Last edit at 05/27/2016 05:34AM by PavloG.
My blog
Re: DeltaXY
May 30, 2016 03:56AM
Thumbs up! thumbs up
In your design XY plane is fixed, print bed - Z axis is moving.
Two stepper motors for XY plane,
One stepper motor for Z axis,
One stepper motor for extruder
Re: DeltaXY
June 08, 2016 09:23PM
Progress a little bit delayed due to:
Hotend sink with impeller
Edited 1 time(s). Last edit at 06/09/2016 10:36AM by PavloG.
My blog
Re: DeltaXY
June 08, 2016 09:47PM
That's... far out that's amazing!!
How much cooling do you think you'll get without fins on the heatsink?
Re: DeltaXY
June 08, 2016 09:51PM
I hope to do testing during weekend.
But seems like air flow bigger than China e3d v5 fan.
My blog
Re: DeltaXY
June 08, 2016 10:30PM
Are you blowing air down, or sucking it up? I'd imagine that sucking it would work better, as that way you're not blowing on the print and cooling it. ABS doesn't like being cooled too much.
Re: DeltaXY
June 09, 2016 04:24AM
Rotation - clockwise from heating block side view (suck air to center, exhausting at impeller top area).
Some experiments required (better with colored fluids).
Edited 2 time(s). Last edit at 06/09/2016 08:28AM by PavloG.
Re: DeltaXY
June 11, 2016 04:17PM
DeltaXY progress
Video Z axis
Re: DeltaXY
June 11, 2016 09:34PM
Well your clearly not afraid to do things your own way, but the more I see of this design the more I'm convinced that this is not a delta, more of an oddball Cartesian/CoreXY hybrid....and looking at this I wonder why a Cartesian XY rack would be considered an inferior design choice
Really can't fathom the rational behind any of your design decisions, if this were me I'd make those uprights 16mm rod and mount the plate with linear bearings, or even affix 4 pieces of linear rail
Any lack of precision in the distance between the pivots on that bed elevation mechanism is going to result in XY and AB shift errors, however, its possible that the right angle orientation of the lift plates will help eliminate this....but that's not necessarily a good thing, it just means you have an over constrained mechanism. so you either have play in the mechanism to overcome the over constraints or the over constraint will cause wear and you will have play
RepRapPro Fisher
-Carbon Arms
HE3D -600 delta
-Duet 0.8.5
-PanelDue
-DC42 Height probe
Simplyfy3D
RS Design Spark CAD
Re: DeltaXY
June 12, 2016 06:17AM
About delta - XY axes math is a delta.
About Sarrus - it is just prototype, and required testing (one week later I hope)
Generally speaking I try experimenting as much as possible - because I can.
My current Scara printer became good only after third revision, and now I am happy with it.
Of course current DeltaXY pure experimental setup and I don't afraid to get failed.
