High speed delta's are often not that speedy at all June 02, 2016 01:45PM |
Re: High speed delta's are often not that speedy at all June 02, 2016 03:32PM |
Re: High speed delta's are often not that speedy at all June 02, 2016 05:14PM |
Re: High speed delta's are often not that speedy at all June 02, 2016 05:59PM |
Re: High speed delta's are often not that speedy at all June 02, 2016 06:03PM |
Re: High speed delta's are often not that speedy at all June 02, 2016 07:11PM |
Re: High speed delta's are often not that speedy at all June 03, 2016 03:48AM |
Re: High speed delta's are often not that speedy at all June 03, 2016 04:10AM |
Re: High speed delta's are often not that speedy at all June 03, 2016 06:06AM |
If that's what you need to tell yourself to rationalize why your system doesn't perform well that is fine. Perhaps you might try backing that up with some math, because the system I have in front of me works fine at that accelleration.Quote
evandene
4000 mm/sec. sec acceleration for a NEMA17 with a Pull-out Torque of 0.42NM motor is simple not possible for a belt driven system with carriages, arms, effector and friction.
Typical "bigger is better talk".
Pull-out torque
The stepper motor pull-out torque is measured by accelerating the motor to the desired speed and then increasing the torque loading until the motor stalls or misses steps. This measurement is taken across a wide range of speeds and the results are used to generate the stepper motor's dynamic performance curve. As noted below this curve is affected by drive voltage, drive current and current switching techniques. A designer may include a safety factor between the rated torque and the estimated full load torque required for the application.
Re: High speed delta's are often not that speedy at all June 03, 2016 11:39AM |
evandene
Re: High speed delta's are often not that speedy at all June 04, 2016 04:22AM |
Re: High speed delta's are often not that speedy at all June 04, 2016 06:31AM |
Re: High speed delta's are often not that speedy at all June 04, 2016 09:22AM |
Re: High speed delta's are often not that speedy at all June 04, 2016 09:39AM |
Re: High speed delta's are often not that speedy at all June 04, 2016 10:48AM |
Re: High speed delta's are often not that speedy at all June 04, 2016 11:50AM |
Re: High speed delta's are often not that speedy at all June 05, 2016 04:52AM |
Re: High speed delta's are often not that speedy at all June 05, 2016 05:21AM |
Re: High speed delta's are often not that speedy at all April 30, 2017 03:41AM |
Re: High speed delta's are often not that speedy at all April 30, 2017 05:16AM |
Re: High speed delta's are often not that speedy at all April 30, 2017 08:54AM |
