How to install an ir Zprobe on a Duet v0.6 June 08, 2016 06:20PM |
Re: How to install an ir Zprobe on a Duet v0.6 June 08, 2016 10:41PM |
Re: How to install an ir Zprobe on a Duet v0.6 June 08, 2016 11:21PM |
Re: How to install an ir Zprobe on a Duet v0.6 June 09, 2016 03:37AM |
bgkdavis
and an IR probe wont stop you from regular calibrations, it will just make a few things easier
Re: How to install an ir Zprobe on a Duet v0.6 June 09, 2016 03:47AM |
w1k3
I found a sensor on eBay simply labeled as ZHS-10A
The two pictures are what it looks like. I'm not familiar with how the DC42 sensor works specifically, but this one apparently outputs different analog voltages to represent the distance.
Re: How to install an ir Zprobe on a Duet v0.6 June 09, 2016 04:16AM |
dc42
bgkdavis
Don't you use the automatic delta calibration built into RRF?
Re: How to install an ir Zprobe on a Duet v0.6 June 09, 2016 01:00PM |
Re: How to install an ir Zprobe on a Duet v0.6 June 09, 2016 05:46PM |
dc42
If that sensor can work from 3.3V power, with the output increasing as the target gets nearer, then you can wire it up as for my sensor. You will need to adjust the P value in the G31 command in config.g to get a suitable trigger distance.
