Print skewed to the right as Z goes up - Issue Found June 29, 2016 03:03AM |
Re: Print skewed to the right as Z goes up June 29, 2016 12:45PM |
Re: Print skewed to the right as Z goes up June 29, 2016 05:52PM |
Re: Print skewed to the right as Z goes up June 30, 2016 12:39AM |
Re: Print skewed to the right as Z goes up June 30, 2016 03:46AM |
Re: Print skewed to the right as Z goes up June 30, 2016 07:53PM |
Re: Print skewed to the right as Z goes up June 30, 2016 11:26PM |
dc42
What electronics and firmware are you using? If it's RepRapFirmware:
1. Make sure you haven't accidentally enabled orthogonal axis compensation;
2. After or during a print that shows these symptoms, run M122 and check the 'Step errors' field. It should be zero.
Do your stepper motors have flats on the shafts?
Re: Print skewed to the right as Z goes up June 30, 2016 11:41PM |
bgkdavis
two possible causes
1) lost motion due to slippage
2) orthogonal error
you can test for 1 by starting your printer and doing a normal calibration and then mark where the nozzle touches the bed and the carraige positions when at XYZ=0, if you can measure the carriage positions accurately.
Then, run a program, doesnt have to use filament, just run the program for a couple of hours
After the program has run go back to XYZ=0, is everything in exactly the same place? if NO then you have a lost motion problem.
