E3D Chimera or Cyclops for a delta? August 08, 2016 03:46AM |
Re: E3D Chimera or Cyclops for a delta? August 08, 2016 09:02AM |
" my choice is Cyclops mainly because of the single nozzle down side as O_lampe points out, no different filament unless they share a common temperature,|
Re: E3D Chimera or Cyclops for a delta? August 08, 2016 09:53AM |
Re: E3D Chimera or Cyclops for a delta? August 08, 2016 11:25AM |
Re: E3D Chimera or Cyclops for a delta? August 09, 2016 02:02AM |
Re: E3D Chimera or Cyclops for a delta? August 09, 2016 03:00AM |
Re: E3D Chimera or Cyclops for a delta? August 10, 2016 02:55AM |
Re: E3D Chimera or Cyclops for a delta? August 11, 2016 01:39PM |
Re: E3D Chimera or Cyclops for a delta? August 11, 2016 03:05PM |
Re: E3D Chimera or Cyclops for a delta? August 12, 2016 10:38AM |
Re: E3D Chimera or Cyclops for a delta? August 12, 2016 12:08PM |
o_lampe
I can mix colors with the Cyclops too, but they look like toothpaste. Does the diamond produce better results?
BTW: which slicer can generate G1 X20 E20:10 commands? I mixed colors using M567 & M568 command.
