Is it layer shift? Please help.
August 11, 2016 04:06PM
Hi everyone, I recently got this delta printer (Micromake D1). It is much better than the i3 had before but it is way too complicated in terms of understanding settings and what not. I am having a weird problem, I have attached a photo. I printed a tube like structure and it seems like there is a lot of layer shifting going on or might be something else, I don't know. Can someone please tell me how I can solve this problem? The problem is, the gear-like shaped tube is supposed to be absolutely straight, but as you can see the outline is anything but that. Can someone shed light on this matter? Thanks!
open | download - delta.jpg (380 KB)
Re: Is it layer shift? Please help.
August 11, 2016 08:37PM
Anyone?
August 12, 2016 03:15AM
Can you also give us a photo of your printer?
If you are using wheels for the linear movement, I would say it's likely your wheels are bad.
This is a common problem in cheap Delta kits that use wheels. (Especially ones that use white nylon door roller wheels)
