Re: Large Kossel all metal delta build log September 27, 2016 01:28PM |
Re: Large Kossel all metal delta build log September 27, 2016 02:25PM |
Re: Large Kossel all metal delta build log September 27, 2016 03:10PM |
Re: Large Kossel all metal delta build log September 27, 2016 03:32PM |
DjDemonD
That's also well worth considering, the cups in the magnets are fairly shallow, and when the rods are fairly low angle to the effector they can almost slip out of the cups, I wonder if a string/spring tensioner would help or whether they would slip out anyway due to the angle. The flying extruder is essentially an elastic link pulling the effector towards the carriages.
Its also worth wondering if my rods might be a bit short. They would not move into this low angle position if they were slightly longer.
Re: Large Kossel all metal delta build log September 27, 2016 04:11PM |
Re: Large Kossel all metal delta build log September 27, 2016 05:55PM |
Re: Large Kossel all metal delta build log September 27, 2016 09:36PM |
Re: Large Kossel all metal delta build log September 28, 2016 05:06AM |
Re: Large Kossel all metal delta build log September 28, 2016 09:08AM |
Re: Large Kossel all metal delta build log September 28, 2016 09:59AM |
Re: Large Kossel all metal delta build log September 28, 2016 02:08PM |
Re: Large Kossel all metal delta build log September 28, 2016 05:02PM |
Re: Large Kossel all metal delta build log September 28, 2016 09:38PM |
Re: Large Kossel all metal delta build log September 29, 2016 02:15AM |
Re: Large Kossel all metal delta build log September 29, 2016 03:01AM |
Re: Large Kossel all metal delta build log September 29, 2016 03:59AM |
Re: Large Kossel all metal delta build log September 30, 2016 12:22PM |
nebbian
I don't like nozzle sensing schemes due to difficulty of sensing (piezo sensors often have issues, accelerometers even more so, hinged nozzles cause issues in the print), as well as the height being wrong if there's a bit of ooze on the nozzle.
Re: Large Kossel all metal delta build log October 01, 2016 11:21AM |
leadinglights
It may be that I am too close to the subject as I put in quite a bit of work on piezo sensing - being blind to the flaws of you own creation is something that nobody is imune to. Knowing the foregoing, I woule be genuinely interested in what issues you see in piezo disk sensing.
Mike
Re: Large Kossel all metal delta build log October 01, 2016 02:01PM |
Re: Large Kossel all metal delta build log October 01, 2016 04:15PM |
Re: Large Kossel all metal delta build log October 01, 2016 04:33PM |
Re: Large Kossel all metal delta build log October 02, 2016 04:30AM |
Re: Large Kossel all metal delta build log October 02, 2016 05:23AM |
Re: Large Kossel all metal delta build log October 02, 2016 06:12AM |
Re: Large Kossel all metal delta build log October 04, 2016 06:14PM |
Re: Large Kossel all metal delta build log October 05, 2016 03:30AM |
Re: Large Kossel all metal delta build log October 05, 2016 03:47AM |
Re: Large Kossel all metal delta build log October 13, 2016 06:06PM |
Re: Large Kossel all metal delta build log October 17, 2016 06:34PM |
Re: Large Kossel all metal delta build log October 24, 2016 05:16PM |
