Re: Large Kossel all metal delta build log October 24, 2016 06:19PM |
Re: Large Kossel all metal delta build log October 24, 2016 06:36PM |
Re: Large Kossel all metal delta build log October 25, 2016 04:15AM |
Re: Large Kossel all metal delta build log October 25, 2016 12:20PM |
Re: Large Kossel all metal delta build log October 25, 2016 02:25PM |
Re: Large Kossel all metal delta build log October 25, 2016 04:30PM |
Re: Large Kossel all metal delta build log October 25, 2016 10:37PM |
Re: Large Kossel all metal delta build log October 26, 2016 02:22AM |
Re: Large Kossel all metal delta build log October 26, 2016 03:42AM |
Re: Large Kossel all metal delta build log October 26, 2016 03:53AM |
Re: Large Kossel all metal delta build log October 26, 2016 09:12AM |
Re: Large Kossel all metal delta build log October 26, 2016 09:24AM |
GroupB
I dont know where hayden put his magnet but if its in the carbon tube so tube make contact with balls (you said you need bigger one) you should avoid that.
Having a proper cup made of nylon is a must and no need to have a cup surrounding the ball perfectly a 60 degree cone shape will do the trick , just calculate them with the right deep so the ball touch or even go through the back of the cone a little, then you adjust you magnet by shimming them or if they fit tight like me, just push them a little till the no more contact between ball and magnet this make sure you have a very minimal gap and maximum magnetic force. Trying to build a preset gap often turn not so precise and make a bigger gap .
Re: Large Kossel all metal delta build log October 26, 2016 09:45AM |
nebbian
The forces are always in line with the arms.
Re: Large Kossel all metal delta build log October 26, 2016 11:07AM |
nebbian
I can't see how having the ball on the arms has any advantage.
Re: Large Kossel all metal delta build log October 26, 2016 01:09PM |
Re: Large Kossel all metal delta build log October 27, 2016 03:50AM |
Re: Large Kossel all metal delta build log October 27, 2016 06:30PM |
Re: Large Kossel all metal delta build log October 28, 2016 12:28PM |
Re: Large Kossel all metal delta build log October 28, 2016 12:35PM |
Re: Large Kossel all metal delta build log October 28, 2016 06:39PM |
Re: Large Kossel all metal delta build log October 29, 2016 03:43AM |
Re: Large Kossel all metal delta build log October 29, 2016 05:05AM |
Re: Large Kossel all metal delta build log October 29, 2016 05:41AM |
Re: Large Kossel all metal delta build log October 29, 2016 01:15PM |
Re: Large Kossel all metal delta build log October 29, 2016 02:59PM |
Re: Large Kossel all metal delta build log October 29, 2016 04:19PM |
Re: Large Kossel all metal delta build log October 30, 2016 04:25PM |
Re: Large Kossel all metal delta build log October 30, 2016 05:21PM |
Re: Large Kossel all metal delta build log October 30, 2016 05:45PM |
