Re: Large Kossel all metal delta build log November 15, 2017 03:46PM |
Re: Large Kossel all metal delta build log November 15, 2017 04:14PM |
Re: Large Kossel all metal delta build log December 06, 2017 09:45AM |
Re: Large Kossel all metal delta build log December 09, 2017 06:27PM |
Re: Large Kossel all metal delta build log December 10, 2017 07:51AM |
Re: Large Kossel all metal delta build log December 10, 2017 07:59AM |
Re: Large Kossel all metal delta build log December 10, 2017 10:27PM |
DjDemonD
I was never unhappy with a flying extruder which only ever had a 20cm bowden tube, but the mass could be seen as ringing or corner defects at high speed. Switched to flex3drive probably about the same, then nimble again about the same.
These remote direct drives definitely beat a long bowden (70cm) even with pressure advance and cyberdine systens ultra ptfe or whatever it is called.
You can use nimble with ysplitter but you need two nimble probably on a flying bracket.
I've tried a pivoting extruder on a microdelta which work great. Might be less useful on an XL. Duet allows a slave axis so you could have a pivoting extruder sliding on its own axis up and down to track the effector. Or even a second complete delta arm system with its own motors and rails but probably a bit OTT.
Re: Large Kossel all metal delta build log December 11, 2017 02:43AM |
Re: Large Kossel all metal delta build log December 11, 2017 08:12PM |
DjDemonD
Apologies this image only wants to display landscape, it will display portrait if clicked-on
Re: Large Kossel all metal delta build log December 24, 2017 07:33AM |
Re: Large Kossel all metal delta build log January 12, 2018 02:13PM |
Re: Large Kossel all metal delta build log January 12, 2018 02:22PM |
Re: Large Kossel all metal delta build log January 13, 2018 01:11AM |
Re: Large Kossel all metal delta build log January 13, 2018 06:57AM |
Re: Large Kossel all metal delta build log January 29, 2018 11:25AM |
Re: Large Kossel all metal delta build log January 29, 2018 07:53PM |
