How do I test the pins for the x axis motor September 19, 2016 02:33AM |
Re: How do I test the pins for the x axis motor September 20, 2016 07:13PM |
Re: How do I test the pins for the x axis motor September 21, 2016 01:39AM |
Re: How do I test the pins for the x axis motor September 21, 2016 01:47AM |
Re: How do I test the pins for the x axis motor September 21, 2016 02:01AM |
Re: How do I test the pins for the x axis motor September 21, 2016 02:54AM |
Re: How do I test the pins for the x axis motor September 21, 2016 03:43AM |
Re: How do I test the pins for the x axis motor September 21, 2016 07:51AM |
#define X_STEP_PIN 36 #define X_DIR_PIN 34 #define X_ENABLE_PIN 30 #define X_MIN_PIN 3 #ifndef X_MAX_PIN #define X_MAX_PIN 2 #endif #define Y_STEP_PIN 60 #define Y_DIR_PIN 61 #define Y_ENABLE_PIN 56 #define Y_MIN_PIN 14 #define Y_MAX_PIN 15 #define Z_STEP_PIN 46 #define Z_DIR_PIN 48 #define Z_ENABLE_PIN 62 #define Z_MIN_PIN 18 #define Z_MAX_PIN 19 #define E0_STEP_PIN 26 #define E0_DIR_PIN 28 #define E0_ENABLE_PIN 24 #define E1_STEP_PIN 54 #define E1_DIR_PIN 55 #define E1_ENABLE_PIN 38
Re: How do I test the pins for the x axis motor September 21, 2016 12:46PM |
Re: How do I test the pins for the x axis motor September 21, 2016 01:26PM |
Re: How do I test the pins for the x axis motor September 21, 2016 02:31PM |
Re: How do I test the pins for the x axis motor September 21, 2016 02:33PM |
Re: How do I test the pins for the x axis motor September 23, 2016 03:12AM |
Re: How do I test the pins for the x axis motor September 23, 2016 03:31AM |
