Re: Geeetech Rostock 301 first topic October 31, 2016 03:56AM |
Re: Geeetech Rostock 301 first topic October 31, 2016 05:38AM |
Re: Geeetech Rostock 301 first topic October 31, 2016 08:50AM |
Re: Geeetech Rostock 301 first topic October 31, 2016 02:47PM |
isuru
HI raoulito9
In my rostock 301 when I checked the firmware version it shows 1.1.0 A
Is this a new version or do I need to upgrade
Thanks
Regards
Isuru
Re: Geeetech Rostock 301 first topic October 31, 2016 03:07PM |
isuru
Hi
i was trying to upload the new firmware as described in the geetech forum.
it did not work and i received a message at the end stating "jump app fail"
at the end.
now my lcd screen does not work.
lcd screen is blank
restart does not make any change
could somebody please help me to fix this
thank you
retract.... November 01, 2016 06:27AM |
Re: retract.... December 01, 2016 10:32AM |
Re: Geeetech Rostock 301 first topic December 01, 2016 07:42PM |
Re: Geeetech Rostock 301 first topic December 01, 2016 09:26PM |
Re: Geeetech Rostock 301 first topic December 02, 2016 01:22AM |
Re: Geeetech Rostock 301 first topic December 02, 2016 02:45AM |
Re: Geeetech Rostock 301 first topic December 02, 2016 05:33AM |
Re: Geeetech Rostock 301 first topic December 02, 2016 05:58AM |
Re: Geeetech Rostock 301 first topic December 02, 2016 06:40AM |
Re: Geeetech Rostock 301 first topic December 03, 2016 02:28AM |
Re: Geeetech Rostock 301 first topic December 03, 2016 04:19AM |
Re: Geeetech Rostock 301 first topic December 03, 2016 05:14AM |
Re: Geeetech Rostock 301 first topic December 07, 2016 09:55PM |
Re: Geeetech Rostock 301 first topic December 08, 2016 03:01AM |
Re: Geeetech Rostock 301 first topic December 08, 2016 02:28PM |
Extruder0
Well it's been 4 hellatious days but my printer is finally assembled and I am printing a large circle just to see how level my bed is. I am using a new nozzle as my extruders are so powerful it blew that one apart. I was chasing clogs for 2 days and even though I knew my teflon tubes were all the way in, it blew them out. I thought I was printing too close to the bed but even when I backed it off, Plastic would go out the mixing nozzle and into one of the other colors. I found an easy way to clean that type of nozzle because I thought a torch might deform the brass. I put the nozzle in the oven and hit "Clean". It worked for 2 prints then blew a fitting out of the other side in two, destroyed the ptfe tubing as molten plastic pushed through the other 2 tubes. I got a new nozzle and turned Vref to .9volts thinking it will stall instead of doing all of that. And aside from a small leak that I tightened up and days of leveling, my first prints are impressive. The new extruders push out only what is needed and can go to a 225%FR easily. although for the current print I am running it slow.
so to recap...Original extruders gone replaced with gearmotors
nozzle gone...replaced w/ internal PTFE tubing. Bowden lines replaced.
2 quick connect fittings destroyed
bent 2 of the endstop screws and replaced all 3 springs.
But I am printing. And I can finally work on fine tuning it.
Re: Geeetech Rostock 301 first topic December 12, 2016 05:03AM |
Re: Geeetech Rostock 301 first topic December 12, 2016 09:48AM |
Re: Geeetech Rostock 301 first topic December 15, 2016 08:12PM |
Re: Geeetech Rostock 301 first topic December 16, 2016 02:34PM |
Re: Geeetech Rostock 301 first topic December 26, 2016 04:39PM |
Re: Geeetech Rostock 301 first topic January 03, 2017 05:22PM |
Levelling Rostock 301 Bed January 06, 2017 08:54AM |
Re: Levelling Rostock 301 Bed January 12, 2017 04:57PM |
Re: Geeetech Rostock 301 first topic January 13, 2017 10:25AM |
flintewn
raoulito9
What do you think about that ?
I think your idea fits perfectly with your requirement, because you need to switch on and off, as mentionned by geeetech use the M106 g-code command.
For me as discussed before, i'll use an airpump with crystal a crystal soft tubing comming and fixed next to the nozzle.
Re: Geeetech Rostock 301 first topic January 21, 2017 07:34AM |
