Delta Calibration and Rotary Deltas October 24, 2016 04:57AM |
Re: Delta Calibration and Rotary Deltas October 24, 2016 05:55AM |
Trakyan
I've been wondering for a while about auto calibration and leveling on deltas. Would it be possible to calibrate/auto level a delta using only a bed sensor or does it NEED endstops at the top of the rails?
Re: Delta Calibration and Rotary Deltas October 24, 2016 10:33AM |
Trakyan
M913 X50 Y50 Z50 ; reduce motor current to 50% G1 S2 X300 Y300 Z300 ; move all carriages up 300mm so that they hit the stops G1 S2 X-5 Y-5 Z-5 ; move them all down 5mm G92 X0 Y0 Z200 ; this point is close to 200mm above bed centre M913 X100 Y100 Z100 ; restore motor current
Re: Delta Calibration and Rotary Deltas October 24, 2016 12:57PM |
Re: Delta Calibration and Rotary Deltas October 24, 2016 02:50PM |
hercek
Interesting idea with reduced motor current. I was thinking about not doing any kind of homing at all. User would just position hotend approximately to the middle of the bed (± few cm should not matter). The firmware would assume the carriages are homed (with a few cm error). Calibrate the endstop positions. Print.
Maybe it could be practical with a 32bit controller board and some good z-probe. But it still cannot be quick since one cannot go to quickly against bed when probing and also it would need to move up quite a bit (at least about the same amount as expected initial endstop error) between each two probing points.
But mechanical endstops are enough too and they are dirt cheap so there is not much reason to bother leaving endstops out.
Re: Delta Calibration and Rotary Deltas October 24, 2016 07:43PM |
Re: Delta Calibration and Rotary Deltas October 25, 2016 08:15AM |
Re: Delta Calibration and Rotary Deltas October 25, 2016 12:29PM |
Re: Delta Calibration and Rotary Deltas October 31, 2016 05:05PM |
