My printer keeps losing it bed level settings
Posted by DerpThing
November 09, 2016 05:38PM
I have had this problem lots of times now. one day will have the printer bed settings in just right and then the next day i come and turn it on and the thing is 5 cm high and unlevel. I will re do it then after a few days it will go bad to some random setting. I have no idea why it is doing this andi can deal with it.
Re: My printer keeps losing it bed level settings
November 09, 2016 07:44PM
Give us more detail, something like Firmware you using a least.
November 10, 2016 06:04PM
I am using repetier for the firmware/
November 11, 2016 09:54AM
Make sure EEPROM is enabled
Proper sequence for Repetier:
Center effector:
G131 \\removes any offsets
M322 \\clears any bed measurements
G33 R0 \\clears any bed height maps
Center the effector (same exact height on all carriages)
G132 S1 \\measures endstop offets and stores in EEPROM
G28 \\Home printer
Run Autolevel:
G32 S2 \\measures autolevel and stores in EEPROM
G28 \\home printer
Run Z distortion correction:
G0 Z5 \\Run effector down to 5mm above plate
G33 \\Run height map measurements (will auto store to EEPROM)
G28 \\Home printer
Done.
November 17, 2016 09:37AM
I am not an advocate of auto level. Once you spend the time to learn to manually level a delta; all other times(if you need to) go very quickly.
be sure everything is mechanically sound and you leveling will be perfect. I have only had to relevel when changing nozzles or trying a new hotend.
Never had to autolevel and have made hundreds of parts.
