Skewed print any ideas? December 17, 2016 11:33AM |
Re: Skewed print any ideas? December 17, 2016 12:45PM |
Re: Skewed print any ideas? December 17, 2016 12:50PM |
Re: Skewed print any ideas? December 17, 2016 01:18PM |
Re: Skewed print any ideas? December 17, 2016 01:38PM |
Re: Skewed print any ideas? December 17, 2016 03:29PM |
Re: Skewed print any ideas? December 17, 2016 03:37PM |
Re: Skewed print any ideas? December 17, 2016 03:40PM |
Re: Skewed print any ideas? December 17, 2016 03:41PM |
Re: Skewed print any ideas? December 17, 2016 04:01PM |
Re: Skewed print any ideas? December 17, 2016 04:04PM |
Re: Skewed print any ideas? December 17, 2016 04:46PM |
Re: Skewed print any ideas? December 17, 2016 04:50PM |
Re: Skewed print any ideas? December 17, 2016 04:54PM |
Re: Skewed print any ideas? December 17, 2016 05:17PM |
Re: Skewed print any ideas? December 17, 2016 05:40PM |
Re: Skewed print any ideas? December 17, 2016 06:43PM |
Re: Skewed print any ideas? December 17, 2016 07:42PM |
Re: Skewed print any ideas? December 17, 2016 09:02PM |
Re: Skewed print any ideas? December 17, 2016 11:34PM |
Re: Skewed print any ideas? December 18, 2016 10:10AM |
Re: Skewed print any ideas? December 18, 2016 10:20AM |
Re: Skewed print any ideas? December 18, 2016 10:28AM |
Re: Skewed print any ideas? December 18, 2016 03:27PM |
Re: Skewed print any ideas? December 18, 2016 04:43PM |
Re: Skewed print any ideas? December 18, 2016 04:48PM |
Re: Skewed print any ideas? December 18, 2016 09:06PM |
DjDemonD
Definitely the most plausible explanation so far.
The hot end assembly is not as tight in the effector as I'd like it to be, the only weak point on Hayden's effector is the hot end clamp is a bit flimsy. I will try to get it tighter/redesign it.
Those thumbnails are clickable for a bigger image but here's another if it helps.
) inside the clamp. It doesn't matter what you connect it to, or even if it's vertical, it just has to stay in the one place relative to the effector. That way you are testing your existing effector. But then again I am a bit of a caveman in the workshop
Re: Skewed print any ideas? December 18, 2016 11:12PM |
Re: Skewed print any ideas? December 19, 2016 05:33AM |
Re: Skewed print any ideas? December 19, 2016 01:26PM |
