Delta design, wanting criticism! December 17, 2016 07:08PM |
Re: Delta design, wanting criticism! December 17, 2016 07:33PM |
Re: Delta design, wanting criticism! December 17, 2016 10:28PM |
Re: Delta design, wanting criticism! December 18, 2016 12:32PM |
Re: Delta design, wanting criticism! December 18, 2016 09:29PM |
Andreas15
Thank you for your valuable input. The reason I placed the hotend higher is so you would see effector tilt less in your prints. But you have a good point.
Re: Delta design, wanting criticism! December 19, 2016 11:19AM |
Re: Delta design, wanting criticism! December 19, 2016 11:03PM |
Re: Delta design, wanting criticism! December 20, 2016 07:12AM |
Re: Delta design, wanting criticism! December 20, 2016 12:34PM |
Re: Delta design, wanting criticism! December 22, 2016 03:27AM |
Re: Delta design, wanting criticism! December 22, 2016 06:22AM |
Re: Delta design, wanting criticism! December 23, 2016 01:19AM |
Re: Delta design, wanting criticism! December 23, 2016 03:50AM |
Andreas15
EDIT: For the magnetic balls, I think I'm going to stick with 12mm. It could be too much, but I don't like the look of 10mm on such a large kossel. Remember that beauty is a key on this machine too
Re: Delta design, wanting criticism! December 23, 2016 05:27AM |
Re: Delta design, wanting criticism! December 23, 2016 08:07AM |
Re: Delta design, wanting criticism! December 23, 2016 03:16PM |
Re: Delta design, wanting criticism! December 23, 2016 05:19PM |
Re: Delta design, wanting criticism! December 23, 2016 08:17PM |
Re: Delta design, wanting criticism! December 23, 2016 09:39PM |
Re: Delta design, wanting criticism! December 24, 2016 03:28AM |
Re: Delta design, wanting criticism! December 24, 2016 08:59AM |
Re: Delta design, wanting criticism! December 25, 2016 11:56AM |
Re: Delta design, wanting criticism! December 25, 2016 12:25PM |
Re: Delta design, wanting criticism! January 25, 2017 05:18PM |
hercek
Andreas15, if you want good joints then use angle ball joints. They will be much lighter then magnets and they will withstand much bigger forces. Magnetic joints are crap ... especially if you plan to use high speeds and accelerations. If they are small enough to be light then they are weak. When they are strong then they are heavy too.
Also read this: [reprap.org] ... especially the part about TES coefficient.
Re: Delta design, wanting criticism! January 26, 2017 07:20AM |
Re: Delta design, wanting criticism! January 26, 2017 12:12PM |
Re: Delta design, wanting criticism! January 26, 2017 12:40PM |
Re: Delta design, wanting criticism! January 30, 2017 10:32AM |
