Opinions about the H3D K200 Delta? January 11, 2017 11:24AM |
Re: Opinions about the H3D K200 Delta? March 09, 2017 12:58AM |
Re: Opinions about the H3D K200 Delta? March 09, 2017 08:23AM |
Re: Opinions about the H3D K200 Delta? March 22, 2017 04:43PM |
Re: Opinions about the H3D K200 Delta? May 12, 2017 03:54AM |
Re: Opinions about the H3D K200 Delta? May 16, 2017 05:12PM |
Re: Opinions about the H3D K200 Delta? May 17, 2017 03:47PM |
Re: Opinions about the H3D K200 Delta? May 17, 2017 05:10PM |
Re: Opinions about the H3D K200 Delta? May 18, 2017 07:08AM |
dlc60
What voltage did you tune the Chinese knock-off stepper drivers to? I am uncertain as to the bias resistor and would be guessing.
dlc60
The SD-card we got did not have any firmware image on it, is the website image a recent version of the firmware or ancient one? The Folger Teck Marlin firmware on my Kossel kit is over six years old so I am hoping that the k200 one is newer vintage!
Did it come with all of the printer specifics set? What did you mean about the EEPROM settings? Did it come with eeprom offsets already set saved???
dlc60
This kit does look really solid however I am already looking at pointing the controller down down so that I don't have to remove the bed to fiddle with the controller wiring!
Re: Opinions about the H3D K200 Delta? May 18, 2017 12:09PM |
Elerion
dlc60
Hehehe...
I actually did not have any issues with the drivers or the motors. I beleave out of the box voltage was 12,20, which I thought was fine and didn't mess with it. I did however pay special attention not to put any unnessesary strain on them.
Roler wheels are tuned in a way that they barely touch 2020 rods, belts are neither too loose or too tight. barings are oiled with super fine machine oil.
Re: Opinions about the H3D K200 Delta? May 18, 2017 12:35PM |
dlc60
Elerion
dlc60
Hehehe...
Actually what I meant to ask was the bias setting on the stepper driver boards. They typically do not come properly tuned and you need to adjust to set the max current allowed. Too little and the motors skip, too high and they overheat. Did you have to tweak them?
Thanks again!
DLC
Re: Opinions about the H3D K200 Delta? May 18, 2017 02:03PM |
SWB
I've got the K200 printing relatively quickly, but with one major bug. I'm getting a large shift problem (picture) that I just haven't been able to figure out even after many hours of troubleshooting. I’ve mostly been testing with lower quality .4mm layers so far, but I really like the quality of the prints I’m getting until it does its shift thing. I can go into details later or in another thread.
Re: Opinions about the H3D K200 Delta? May 19, 2017 03:42AM |
