Re: Building a Kossel: Need advice on final parts January 29, 2017 02:08PM |
Re: Building a Kossel: Need advice on final parts January 29, 2017 03:41PM |
Re: Building a Kossel: Need advice on final parts January 29, 2017 03:55PM |
Re: Building a Kossel: Need advice on final parts January 29, 2017 04:07PM |
Re: Building a Kossel: Need advice on final parts January 30, 2017 07:24AM |
Re: Building a Kossel: Need advice on final parts January 30, 2017 08:15AM |
Re: Building a Kossel: Need advice on final parts January 30, 2017 08:57AM |
Re: Building a Kossel: Need advice on final parts January 30, 2017 09:35AM |
Re: Building a Kossel: Need advice on final parts January 30, 2017 10:23AM |
Re: Building a Kossel: Need advice on final parts January 30, 2017 06:17PM |
Re: Building a Kossel: Need advice on final parts January 30, 2017 07:33PM |
GroupB
You do not need to have all part exactly the same if you build in some clearance for hole, you adjust it when you first build it and put everything square ( you kinda need to do it anyway with pre build part, a 3d printer is not something you put A on B and expect it to work with the highest quality). Best build have adjustment all around and carefully measure everything before tightening,. something you CANT do if the part do not have some sort of adjustment and are screw in instead of Bolt in.
Re: Building a Kossel: Need advice on final parts January 30, 2017 11:21PM |
DjDemonD
GroupB - if you had access to a high quality CNC machine for free would you make an effector to replace your hand made one?
Re: Building a Kossel: Need advice on final parts January 30, 2017 11:28PM |
Riggi
Okay thanks for the warning on the idlers nebbian!
Re: Building a Kossel: Need advice on final parts January 31, 2017 12:30AM |
Re: Building a Kossel: Need advice on final parts January 31, 2017 01:42AM |
Re: Building a Kossel: Need advice on final parts January 31, 2017 03:56PM |
Re: Building a Kossel: Need advice on final parts January 31, 2017 04:29PM |
Re: Building a Kossel: Need advice on final parts February 01, 2017 03:28PM |
Re: Building a Kossel: Need advice on final parts February 01, 2017 10:27PM |
Re: Building a Kossel: Need advice on final parts February 02, 2017 07:05AM |
Re: Building a Kossel: Need advice on final parts February 02, 2017 07:40AM |
Re: Building a Kossel: Need advice on final parts February 02, 2017 08:06AM |
Re: Building a Kossel: Need advice on final parts February 02, 2017 08:39AM |
Re: Building a Kossel: Need advice on final parts February 02, 2017 10:28AM |
Re: Building a Kossel: Need advice on final parts February 02, 2017 10:37AM |
Re: Building a Kossel: Need advice on final parts February 02, 2017 11:14AM |
Re: Building a Kossel: Need advice on final parts February 02, 2017 11:29AM |
Riggi
Oh okay thanks for your explanation. I suppose it would be better to manually calibrate a bigger delta printer then?
Re: Building a Kossel: Need advice on final parts February 02, 2017 11:43AM |
Re: Building a Kossel: Need advice on final parts February 02, 2017 12:16PM |
dc42
Riggi
Auto-calibrating a large delta isn't difficult if you have a good Z probe. Either one that uses the nozzle itself as the probe (such as the pizeo sensor that there are a few threads about), or one that is small enough to mount close to the nozzle (such as my IR sensor) and you have taken care to minimise effector tilt. There is more information on auto calibrating a delta at [duet3d.com].
