Need formatting tips, Any and all help welcomed February 21, 2017 10:07PM |
Re: Need formatting tips, Any and all help welcomed February 21, 2017 11:59PM |
Re: Need formatting tips, Any and all help welcomed February 22, 2017 06:17AM |
Re: Need formatting tips, Any and all help welcomed February 22, 2017 09:49PM |
Re: Need formatting tips, Any and all help welcomed February 22, 2017 10:25PM |
Re: Need formatting tips, Any and all help welcomed February 22, 2017 10:59PM |
Re: Need formatting tips, Any and all help welcomed February 23, 2017 03:54PM |
Re: Need formatting tips, Any and all help welcomed February 23, 2017 08:25PM |
G1 F6000 Z20 X0 Y90 M340 P0 S700; // Deploy probe G30; // Measure height using Z probe
Re: Need formatting tips, Any and all help welcomed February 23, 2017 08:27PM |
Re: Need formatting tips, Any and all help welcomed February 23, 2017 08:45PM |
Re: Need formatting tips, Any and all help welcomed February 23, 2017 09:14PM |
// #################### Z-Probing ##################### #define Z_PROBE_Z_OFFSET 0 #define Z_PROBE_Z_OFFSET_MODE 0 #define UI_BED_COATING 1 #define FEATURE_Z_PROBE 1 #define Z_PROBE_BED_DISTANCE 10 #define Z_PROBE_PIN ORIG_Z_MIN_PIN #define Z_PROBE_PULLUP 0 #define Z_PROBE_ON_HIGH 1 #define Z_PROBE_X_OFFSET 0 #define Z_PROBE_Y_OFFSET 0 #define Z_PROBE_WAIT_BEFORE_TEST 0 #define Z_PROBE_SPEED 2 #define Z_PROBE_XY_SPEED 150 #define Z_PROBE_SWITCHING_DISTANCE 1 #define Z_PROBE_REPETITIONS 1 #define Z_PROBE_HEIGHT 9.65 #define Z_PROBE_START_SCRIPT "M340 P0 S700" #define Z_PROBE_FINISHED_SCRIPT "M340 P0 S1800" #define Z_PROBE_REQUIRES_HEATING 0 #define Z_PROBE_MIN_TEMPERATURE 150 #define FEATURE_AUTOLEVEL 1 #define Z_PROBE_X1 -69 #define Z_PROBE_Y1 -40 #define Z_PROBE_X2 69 #define Z_PROBE_Y2 -40 #define Z_PROBE_X3 0 #define Z_PROBE_Y3 80 #define BED_LEVELING_METHOD 0 #define BED_CORRECTION_METHOD 0 #define BED_LEVELING_GRID_SIZE 5 #define BED_LEVELING_REPETITIONS 5 #define BED_MOTOR_1_X 0 #define BED_MOTOR_1_Y 0 #define BED_MOTOR_2_X 200 #define BED_MOTOR_2_Y 0 #define BED_MOTOR_3_X 100 #define BED_MOTOR_3_Y 200 #define BENDING_CORRECTION_A 0 #define BENDING_CORRECTION_B 0 #define BENDING_CORRECTION_C 0 #define FEATURE_AXISCOMP 0 #define AXISCOMP_TANXY 0 #define AXISCOMP_TANYZ 0 #define AXISCOMP_TANXZ 0
Re: Need formatting tips, Any and all help welcomed February 23, 2017 09:52PM |
Re: Need formatting tips, Any and all help welcomed February 24, 2017 01:13AM |
Re: Need formatting tips, Any and all help welcomed February 24, 2017 08:40PM |
Re: Need formatting tips, Any and all help welcomed February 24, 2017 11:23PM |
Re: Need formatting tips, Any and all help welcomed February 25, 2017 05:49PM |
Re: Need formatting tips, Any and all help welcomed February 25, 2017 07:04PM |
Re: Need formatting tips, Any and all help welcomed February 25, 2017 07:22PM |
Re: Need formatting tips, Any and all help welcomed February 25, 2017 07:46PM |
Re: Need formatting tips, Any and all help welcomed February 25, 2017 09:09PM |
Re: Need formatting tips, Any and all help welcomed February 25, 2017 10:24PM |
Re: Need formatting tips, Any and all help welcomed February 28, 2017 07:08PM |
Re: Need formatting tips, Any and all help welcomed February 28, 2017 09:56PM |
Re: Need formatting tips, Any and all help welcomed March 01, 2017 06:04PM |
Re: Need formatting tips, Any and all help welcomed March 02, 2017 11:18AM |
Re: Need formatting tips, Any and all help welcomed March 02, 2017 06:54PM |
Re: Need formatting tips, Any and all help welcomed March 02, 2017 07:55PM |
Zulance
I have a file with a bunch of circles, but I am unable to crop it down to a size lower than 610kb. My belts are tight, but not overly tight. I use belt springs so that all of the belts have the same tension on them, as the belt stretches the spring compensates for the stretch. I made sure everything was tight, no gear slippage etc. the only thing I can think of is a formatting error of some sorts. The closer to the center, smaller I got the more you could see the octagon shape. The bigger the circles got the cleaner around they became. Not sure what would cause this.
Re: Need formatting tips, Any and all help welcomed March 02, 2017 08:03PM |
ayudtee
Zulance,
Based upon your "The bigger the circles got the cleaner around they became" observation, I think that the magnetic joints around the effector may be binding up. The photo attached to your first post ( when zoomed in) seems to show the magnetic rod ends on the effector completely covering over the joint balls instead of only cupping the top half of the ball like the connections on the carriage magnetic joints appear. Is the effector using a different size ball than the carriage?
Re: Need formatting tips, Any and all help welcomed March 02, 2017 08:06PM |
