Please help me fix this axis issue
Posted by Uscstaylor
February 23, 2017 11:48PM
Hey Guys
I have a Kossel printer that I have been using for about 2 months and everything was great until I add a Titan extruder. I had no issues with it until I needed to change directions on my stepper motor. Well that messed everything up cause I didn't save my old setting and some how I lost all my settings in my config file. So to make a long story short. I was able to find a Kossel Delta config h file and tweak it a bit to get just about my settings as far as the printer goes but what I came across now is my axis are not working correctly. I want to start with my z axis first. when I manually place the z axis in the highest position and try to move it down it does nothing. but when I go and try to move it in the home position it just clicks and makes noise like its moving up abut its already in the up position, so for starters I think I need to change the direction of my z axis motor via the software. After I get that axis moving correctly then I need to do the others X and Y.
Can I please ask someone to please help me. I'd gladly pay for your time via Paypal. I will post a pic of my system and then Ill post the Config h file. If you can look at the settings and let me know what you think I should do to fix it. I do have the old firmware files but they are old and I cant load them cause Marlin states that they need to be updated.
Here a link to my old original firmware files
[www.mediafire.com]
Here's a pic of my system:
Here's my Config h file I'm using now....
* Marlin 3D Printer Firmware
* Configuration.h
* Basic settings such as:
* - Type of electronics
* - Type of temperature sensor
* - Printer geometry
* - Endstop configuration
* - LCD controller
* - Extra features
* Advanced settings can be found in Configuration_adv.h
#ifndef CONFIGURATION_H
#define CONFIGURATION_H
* ** ATTENTION TO ALL DEVELOPERS **
* You must increment this version number for every significant change such as,
* but not limited to: ADD, DELETE RENAME OR REPURPOSE any directive/option.
* Note: Update also Version.h !
#define CONFIGURATION_H_VERSION 010100
//============================= Getting Started =============================
* Here are some standard links for getting your machine calibrated:
* [reprap.org]
* [youtu.be]
* [calculator.josefprusa.cz]
* [reprap.org]
* [www.thingiverse.com]
* [sites.google.com]
//============================= DELTA Printer ===============================
// For a Delta printer replace the configuration files with the files in the
// example_configurations/delta directory.
//============================= SCARA Printer ===============================
// For a Scara printer replace the configuration files with the files in the
// example_configurations/SCARA directory.
// @section info
// User-specified version info of this build to display in [Pronterface, etc] terminal window during
// startup. Implementation of an idea by Prof Braino to inform user that any changes made to this
// build by the user have been successfully uploaded into firmware.
#define STRING_CONFIG_H_AUTHOR "(none, default config)" // Who made the changes.
#define SHOW_BOOTSCREEN
#define STRING_SPLASH_LINE1 SHORT_BUILD_VERSION // will be shown during bootup in line 1
#define STRING_SPLASH_LINE2 WEBSITE_URL // will be shown during bootup in line 2
// *** VENDORS PLEASE READ *****************************************************
// Marlin now allow you to have a vendor boot image to be displayed on machine
// start. When SHOW_CUSTOM_BOOTSCREEN is defined Marlin will first show your
// custom boot image and them the default Marlin boot image is shown.
// We suggest for you to take advantage of this new feature and keep the Marlin
// boot image unmodified. For an example have a look at the bq Hephestos 2
// example configuration folder.
//#define SHOW_CUSTOM_BOOTSCREEN
// @section machine
* Select which serial port on the board will be used for communication with the host.
* This allows the connection of wireless adapters (for instance) to non-default port pins.
* Serial port 0 is always used by the Arduino bootloader regardless of this setting.
* :[0, 1, 2, 3, 4, 5, 6, 7]
#define SERIAL_PORT 0
* This setting determines the communication speed of the printer.
* 250000 works in most cases, but you might try a lower speed if
* you commonly experience drop-outs during host printing.
* :[2400, 9600, 19200, 38400, 57600, 115200, 250000]
#define BAUDRATE 250000
// Enable the Bluetooth serial interface on AT90USB devices
//#define BLUETOOTH
// The following define selects which electronics board you have.
// Please choose the name from boards.h that matches your setup
#ifndef MOTHERBOARD
#define MOTHERBOARD BOARD_RAMPS_14_EFB
#endif
// Optional custom name for your RepStrap or other custom machine
// Displayed in the LCD "Ready" message
#define CUSTOM_MACHINE_NAME "Joe's Kossel"
// Define this to set a unique identifier for this printer, (Used by some programs to differentiate between machines)
// You can use an online service to generate a random UUID. (eg [www.uuidgenerator.net])
//#define MACHINE_UUID "00000000-0000-0000-0000-000000000000"
// This defines the number of extruders
// :[1, 2, 3, 4]
#define EXTRUDERS 1
// Enable if your E steppers or extruder gear ratios are not identical
//#define DISTINCT_E_FACTORS
// For Cyclops or any "multi-extruder" that shares a single nozzle.
//#define SINGLENOZZLE
// A dual extruder that uses a single stepper motor
// Don't forget to set SSDE_SERVO_ANGLES and HOTEND_OFFSET_X/Y/Z
//#define SWITCHING_EXTRUDER
#if ENABLED(SWITCHING_EXTRUDER)
#define SWITCHING_EXTRUDER_SERVO_NR 0
#define SWITCHING_EXTRUDER_SERVO_ANGLES { 0, 90 } // Angles for E0, E1
//#define HOTEND_OFFSET_Z {0.0, 0.0}
#endif
* "Mixing Extruder"
* - Adds a new code, M165, to set the current mix factors.
* - Extends the stepping routines to move multiple steppers in proportion to the mix.
* - Optional support for Repetier Host M163, M164, and virtual extruder.
* - This implementation supports only a single extruder.
* - Enable DIRECT_MIXING_IN_G1 for Pia Taubert's reference implementation
//#define MIXING_EXTRUDER
#if ENABLED(MIXING_EXTRUDER)
#define MIXING_STEPPERS 2 // Number of steppers in your mixing extruder
#define MIXING_VIRTUAL_TOOLS 16 // Use the Virtual Tool method with M163 and M164
//#define DIRECT_MIXING_IN_G1 // Allow ABCDHI mix factors in G1 movement commands
#endif
// Offset of the extruders (uncomment if using more than one and relying on firmware to position when changing).
// The offset has to be X=0, Y=0 for the extruder 0 hotend (default extruder).
// For the other hotends it is their distance from the extruder 0 hotend.
//#define HOTEND_OFFSET_X {0.0, 20.00} // (in mm) for each extruder, offset of the hotend on the X axis
//#define HOTEND_OFFSET_Y {0.0, 5.00} // (in mm) for each extruder, offset of the hotend on the Y axis
* Select your power supply here. Use 0 if you haven't connected the PS_ON_PIN
* 0 = No Power Switch
* 1 = ATX
* 2 = X-Box 360 203Watts (the blue wire connected to PS_ON and the red wire to VCC)
* :{ 0:'No power switch', 1:'ATX', 2:'X-Box 360' }
#define POWER_SUPPLY 1
#if POWER_SUPPLY > 0
// Enable this option to leave the PSU off at startup.
// Power to steppers and heaters will need to be turned on with M80.
//#define PS_DEFAULT_OFF
#endif
// @section temperature
//============================= Thermal Settings ============================
* --NORMAL IS 4.7kohm PULLUP!-- 1kohm pullup can be used on hotend sensor, using correct resistor and table
* Temperature sensors available:
* -3 : thermocouple with MAX31855 (only for sensor 0)
* -2 : thermocouple with MAX6675 (only for sensor 0)
* -1 : thermocouple with AD595
* 0 : not used
* 1 : 100k thermistor - best choice for EPCOS 100k (4.7k pullup)
* 2 : 200k thermistor - ATC Semitec 204GT-2 (4.7k pullup)
* 3 : Mendel-parts thermistor (4.7k pullup)
* 4 : 10k thermistor !! do not use it for a hotend. It gives bad resolution at high temp. !!
* 5 : 100K thermistor - ATC Semitec 104GT-2 (Used in ParCan & J-Head) (4.7k pullup)
* 6 : 100k EPCOS - Not as accurate as table 1 (created using a fluke thermocouple) (4.7k pullup)
* 7 : 100k Honeywell thermistor 135-104LAG-J01 (4.7k pullup)
* 71 : 100k Honeywell thermistor 135-104LAF-J01 (4.7k pullup)
* 8 : 100k 0603 SMD Vishay NTCS0603E3104FXT (4.7k pullup)
* 9 : 100k GE Sensing AL03006-58.2K-97-G1 (4.7k pullup)
* 10 : 100k RS thermistor 198-961 (4.7k pullup)
* 11 : 100k beta 3950 1% thermistor (4.7k pullup)
* 12 : 100k 0603 SMD Vishay NTCS0603E3104FXT (4.7k pullup) (calibrated for Makibox hot bed)
* 13 : 100k Hisens 3950 1% up to 300°C for hotend "Simple ONE " & "Hotend "All In ONE"
* 20 : the PT100 circuit found in the Ultimainboard V2.x
* 60 : 100k Maker's Tool Works Kapton Bed Thermistor beta=3950
* 66 : 4.7M High Temperature thermistor from Dyze Design
* 70 : the 100K thermistor found in the bq Hephestos 2
* 1k ohm pullup tables - This is atypical, and requires changing out the 4.7k pullup for 1k.
* (but gives greater accuracy and more stable PID)
* 51 : 100k thermistor - EPCOS (1k pullup)
* 52 : 200k thermistor - ATC Semitec 204GT-2 (1k pullup)
* 55 : 100k thermistor - ATC Semitec 104GT-2 (Used in ParCan & J-Head) (1k pullup)
* 1047 : Pt1000 with 4k7 pullup
* 1010 : Pt1000 with 1k pullup (non standard)
* 147 : Pt100 with 4k7 pullup
* 110 : Pt100 with 1k pullup (non standard)
* Use these for Testing or Development purposes. NEVER for production machine.
* 998 : Dummy Table that ALWAYS reads 25°C or the temperature defined below.
* 999 : Dummy Table that ALWAYS reads 100°C or the temperature defined below.
* :{ '0': "Not used", '1':"100k / 4.7k - EPCOS", '2':"200k / 4.7k - ATC Semitec 204GT-2", '3':"Mendel-parts / 4.7k", '4':"10k !! do not use for a hotend. Bad resolution at high temp. !!", '5':"100K / 4.7k - ATC Semitec 104GT-2 (Used in ParCan & J-Head)", '6':"100k / 4.7k EPCOS - Not as accurate as Table 1", '7':"100k / 4.7k Honeywell 135-104LAG-J01", '8':"100k / 4.7k 0603 SMD Vishay NTCS0603E3104FXT", '9':"100k / 4.7k GE Sensing AL03006-58.2K-97-G1", '10':"100k / 4.7k RS 198-961", '11':"100k / 4.7k beta 3950 1%", '12':"100k / 4.7k 0603 SMD Vishay NTCS0603E3104FXT (calibrated for Makibox hot bed)", '13':"100k Hisens 3950 1% up to 300°C for hotend 'Simple ONE ' & hotend 'All In ONE'", '20':"PT100 (Ultimainboard V2.x)", '51':"100k / 1k - EPCOS", '52':"200k / 1k - ATC Semitec 204GT-2", '55':"100k / 1k - ATC Semitec 104GT-2 (Used in ParCan & J-Head)", '60':"100k Maker's Tool Works Kapton Bed Thermistor beta=3950", '66':"Dyze Design 4.7M High Temperature thermistor", '70':"the 100K thermistor found in the bq Hephestos 2", '71':"100k / 4.7k Honeywell 135-104LAF-J01", '147':"Pt100 / 4.7k", '1047':"Pt1000 / 4.7k", '110':"Pt100 / 1k (non-standard)", '1010':"Pt1000 / 1k (non standard)", '-3':"Thermocouple + MAX31855 (only for sensor 0)", '-2':"Thermocouple + MAX6675 (only for sensor 0)", '-1':"Thermocouple + AD595",'998':"Dummy 1", '999':"Dummy 2" }
#define TEMP_SENSOR_0 5
#define TEMP_SENSOR_1 0
#define TEMP_SENSOR_2 0
#define TEMP_SENSOR_3 0
#define TEMP_SENSOR_BED 0
// Dummy thermistor constant temperature readings, for use with 998 and 999
#define DUMMY_THERMISTOR_998_VALUE 25
#define DUMMY_THERMISTOR_999_VALUE 100
// Use temp sensor 1 as a redundant sensor with sensor 0. If the readings
// from the two sensors differ too much the print will be aborted.
//#define TEMP_SENSOR_1_AS_REDUNDANT
#define MAX_REDUNDANT_TEMP_SENSOR_DIFF 5
// Extruder temperature must be close to target for this long before M109 returns success
#define TEMP_RESIDENCY_TIME 10 // (seconds)
#define TEMP_HYSTERESIS 3 // (degC) range of +/- temperatures considered "close" to the target one
#define TEMP_WINDOW 1 // (degC) Window around target to start the residency timer x degC early.
// Bed temperature must be close to target for this long before M190 returns success
#define TEMP_BED_RESIDENCY_TIME 0 // (seconds)
#define TEMP_BED_HYSTERESIS 3 // (degC) range of +/- temperatures considered "close" to the target one
#define TEMP_BED_WINDOW 1 // (degC) Window around target to start the residency timer x degC early.
// The minimal temperature defines the temperature below which the heater will not be enabled It is used
// to check that the wiring to the thermistor is not broken.
// Otherwise this would lead to the heater being powered on all the time.
#define HEATER_0_MINTEMP 5
#define HEATER_1_MINTEMP 5
#define HEATER_2_MINTEMP 5
#define HEATER_3_MINTEMP 5
#define BED_MINTEMP 5
// When temperature exceeds max temp, your heater will be switched off.
// This feature exists to protect your hotend from overheating accidentally, but *NOT* from thermistor short/failure!
// You should use MINTEMP for thermistor short/failure protection.
#define HEATER_0_MAXTEMP 275
#define HEATER_1_MAXTEMP 275
#define HEATER_2_MAXTEMP 275
#define HEATER_3_MAXTEMP 275
#define BED_MAXTEMP 150
//============================= PID Settings ================================
// PID Tuning Guide here: [reprap.org]
// Comment the following line to disable PID and enable bang-bang.
#define PIDTEMP
#define BANG_MAX 255 // limits current to nozzle while in bang-bang mode; 255=full current
#define PID_MAX BANG_MAX // limits current to nozzle while PID is active (see PID_FUNCTIONAL_RANGE below); 255=full current
#if ENABLED(PIDTEMP)
//#define PID_AUTOTUNE_MENU // Add PID Autotune to the LCD "Temperature" menu to run M303 and apply the result.
//#define PID_DEBUG // Sends debug data to the serial port.
//#define PID_OPENLOOP 1 // Puts PID in open loop. M104/M140 sets the output power from 0 to PID_MAX
//#define SLOW_PWM_HEATERS // PWM with very low frequency (roughly 0.125Hz=8s) and minimum state time of approximately 1s useful for heaters driven by a relay
//#define PID_PARAMS_PER_HOTEND // Uses separate PID parameters for each extruder (useful for mismatched extruders)
// Set/get with gcode: M301 E[extruder number, 0-2]
#define PID_FUNCTIONAL_RANGE 10 // If the temperature difference between the target temperature and the actual temperature
// is more than PID_FUNCTIONAL_RANGE then the PID will be shut off and the heater will be set to min/max.
#define K1 0.95 //smoothing factor within the PID
// If you are using a pre-configured hotend then you can use one of the value sets by uncommenting it
// Ultimaker
#define DEFAULT_Kp 22.2
#define DEFAULT_Ki 1.08
#define DEFAULT_Kd 114
// MakerGear
//#define DEFAULT_Kp 7.0
//#define DEFAULT_Ki 0.1
//#define DEFAULT_Kd 12
// Mendel Parts V9 on 12V
//#define DEFAULT_Kp 63.0
//#define DEFAULT_Ki 2.25
//#define DEFAULT_Kd 440
#endif // PIDTEMP
//============================= PID > Bed Temperature Control ===============
// Select PID or bang-bang with PIDTEMPBED. If bang-bang, BED_LIMIT_SWITCHING will enable hysteresis
// Uncomment this to enable PID on the bed. It uses the same frequency PWM as the extruder.
// If your PID_dT is the default, and correct for your hardware/configuration, that means 7.689Hz,
// which is fine for driving a square wave into a resistive load and does not significantly impact you FET heating.
// This also works fine on a Fotek SSR-10DA Solid State Relay into a 250W heater.
// If your configuration is significantly different than this and you don't understand the issues involved, you probably
// shouldn't use bed PID until someone else verifies your hardware works.
// If this is enabled, find your own PID constants below.
//#define PIDTEMPBED
//#define BED_LIMIT_SWITCHING
// This sets the max power delivered to the bed, and replaces the HEATER_BED_DUTY_CYCLE_DIVIDER option.
// all forms of bed control obey this (PID, bang-bang, bang-bang with hysteresis)
// setting this to anything other than 255 enables a form of PWM to the bed just like HEATER_BED_DUTY_CYCLE_DIVIDER did,
// so you shouldn't use it unless you are OK with PWM on your bed. (see the comment on enabling PIDTEMPBED)
#define MAX_BED_POWER 255 // limits duty cycle to bed; 255=full current
#if ENABLED(PIDTEMPBED)
//#define PID_BED_DEBUG // Sends debug data to the serial port.
//120V 250W silicone heater into 4mm borosilicate (MendelMax 1.5+)
//from FOPDT model - kp=.39 Tp=405 Tdead=66, Tc set to 79.2, aggressive factor of .15 (vs .1, 1, 10)
#define DEFAULT_bedKp 10.00
#define DEFAULT_bedKi .023
#define DEFAULT_bedKd 305.4
//from pidautotune
//#define DEFAULT_bedKp 97.1
//#define DEFAULT_bedKi 1.41
//#define DEFAULT_bedKd 1675.16
// FIND YOUR OWN: "M303 E-1 C8 S90" to run autotune on the bed at 90 degreesC for 8 cycles.
#endif // PIDTEMPBED
// @section extruder
// This option prevents extrusion if the temperature is below EXTRUDE_MINTEMP.
// It also enables the M302 command to set the minimum extrusion temperature
// or to allow moving the extruder regardless of the hotend temperature.
// *** IT IS HIGHLY RECOMMENDED TO LEAVE THIS OPTION ENABLED! ***
#define PREVENT_COLD_EXTRUSION
#define EXTRUDE_MINTEMP 175
// This option prevents a single extrusion longer than EXTRUDE_MAXLENGTH.
// Note that for Bowden Extruders a too-small value here may prevent loading.
#define PREVENT_LENGTHY_EXTRUDE
#define EXTRUDE_MAXLENGTH 200
//======================== Thermal Runaway Protection =======================
* Thermal Protection protects your printer from damage and fire if a
* thermistor falls out or temperature sensors fail in any way.
* The issue: If a thermistor falls out or a temperature sensor fails,
* Marlin can no longer sense the actual temperature. Since a disconnected
* thermistor reads as a low temperature, the firmware will keep the heater on.
* If you get "Thermal Runaway" or "Heating failed" errors the
* details can be tuned in Configuration_adv.h
#define THERMAL_PROTECTION_HOTENDS // Enable thermal protection for all extruders
#define THERMAL_PROTECTION_BED // Enable thermal protection for the heated bed
//============================= Mechanical Settings =========================
// @section machine
// Uncomment one of these options to enable CoreXY, CoreXZ, or CoreYZ kinematics
// either in the usual order or reversed
//#define COREXY
//#define COREXZ
//#define COREYZ
//#define COREYX
//#define COREZX
//#define COREZY
//============================== Delta Settings =============================
// Enable DELTA kinematics and most of the default configuration for Deltas
#define DELTA
#if ENABLED(DELTA)
// Make delta curves from many straight lines (linear interpolation).
// This is a trade-off between visible corners (not enough segments)
// and processor overload (too many expensive sqrt calls).
#define DELTA_SEGMENTS_PER_SECOND 160
// NOTE NB all values for DELTA_* values MUST be floating point, so always have a decimal point in them
// Center-to-center distance of the holes in the diagonal push rods.
#define DELTA_DIAGONAL_ROD 216.0 // mm
// Horizontal offset from middle of printer to smooth rod center.
#define DELTA_SMOOTH_ROD_OFFSET 141.9 // mm
// Horizontal offset of the universal joints on the end effector.
#define DELTA_EFFECTOR_OFFSET 24.0 // mm
// Horizontal offset of the universal joints on the carriages.
#define DELTA_CARRIAGE_OFFSET 22.0 // mm
// Horizontal distance bridged by diagonal push rods when effector is centered.
#define DELTA_RADIUS (DELTA_SMOOTH_ROD_OFFSET-(DELTA_EFFECTOR_OFFSET)-(DELTA_CARRIAGE_OFFSET))
// Print surface diameter/2 minus unreachable space (avoid collisions with vertical towers).
#define DELTA_PRINTABLE_RADIUS 100.0
// Delta calibration menu
// uncomment to add three points calibration menu option.
// See [minow.blogspot.com]
// If needed, adjust the X, Y, Z calibration coordinates
// in [email protected]_delta_calibrate_menu()
//#define DELTA_CALIBRATION_MENU
// After homing move down to a height where XY movement is unconstrained
#define DELTA_HOME_TO_SAFE_ZONE
//#define DELTA_ENDSTOP_ADJ { 0, 0, 0 }
#endif
// Enable this option for Toshiba steppers
//#define CONFIG_STEPPERS_TOSHIBA
//============================== Endstop Settings ===========================
// @section homing
// Specify here all the endstop connectors that are connected to any endstop or probe.
// Almost all printers will be using one per axis. Probes will use one or more of the
// extra connectors. Leave undefined any used for non-endstop and non-probe purposes.
//#define USE_XMIN_PLUG
//#define USE_YMIN_PLUG
#define USE_ZMIN_PLUG
#define USE_XMAX_PLUG
#define USE_YMAX_PLUG
#define USE_ZMAX_PLUG
// coarse Endstop Settings
#define ENDSTOPPULLUPS // Comment this out (using // at the start of the line) to disable the endstop pullup resistors
#if DISABLED(ENDSTOPPULLUPS)
// fine endstop settings: Individual pullups. will be ignored if ENDSTOPPULLUPS is defined
//#define ENDSTOPPULLUP_XMAX
//#define ENDSTOPPULLUP_YMAX
//#define ENDSTOPPULLUP_ZMAX
//#define ENDSTOPPULLUP_XMIN
//#define ENDSTOPPULLUP_YMIN
//#define ENDSTOPPULLUP_ZMIN
//#define ENDSTOPPULLUP_ZMIN_PROBE
#endif
// Mechanical endstop with COM to ground and NC to Signal uses "false" here (most common setup).
#define X_MIN_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop.
#define Y_MIN_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop.
#define Z_MIN_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop.
#define X_MAX_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop.
#define Y_MAX_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop.
#define Z_MAX_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop.
//#define Z_MIN_PROBE_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop.
// Enable this feature if all enabled endstop pins are interrupt-capable.
// This will remove the need to poll the interrupt pins, saving many CPU cycles.
//#define ENDSTOP_INTERRUPTS_FEATURE
//============================== Movement Settings ============================
// @section motion
// delta speeds must be the same on xyz
* Default Settings
* These settings can be reset by M502
* You can set distinct factors for each E stepper, if needed.
* If fewer factors are given, the last will apply to the rest.
* Note that if EEPROM is enabled, saved values will override these.
* Default Axis Steps Per Unit (steps/mm)
* Override with M92
* X, Y, Z, E0 [, E1[, E2[, E3]]]
#define DEFAULT_AXIS_STEPS_PER_UNIT { 95, 95, 95, 95 } // default steps per unit for Kossel (GT2, 20 tooth)
* Default Max Feed Rate (mm/s)
* Override with M203
#define DEFAULT_MAX_FEEDRATE { 200, 200, 200, 200 }
* Default Max Acceleration (change/s) change = mm/s
* (Maximum start speed for accelerated moves)
* Override with M201
#define DEFAULT_MAX_ACCELERATION { 3000, 3000, 3000, 3000 }
* Default Acceleration (change/s) change = mm/s
* Override with M204
* M204 P Acceleration
* M204 R Retract Acceleration
* M204 T Travel Acceleration
#define DEFAULT_ACCELERATION 2500 // X, Y, Z and E acceleration for printing moves
#define DEFAULT_RETRACT_ACCELERATION 2500 // E acceleration for retracts
#define DEFAULT_TRAVEL_ACCELERATION 2500 // X, Y, Z acceleration for travel (non printing) moves
* Default Jerk (mm/s)
* "Jerk" specifies the minimum speed change that requires acceleration.
* When changing speed and direction, if the difference is less than the
* value set here, it may happen instantaneously.
#define DEFAULT_XJERK 20.0
#define DEFAULT_YJERK 20.0
#define DEFAULT_ZJERK 20.0 // Must be same as XY for delta
#define DEFAULT_EJERK 5.0
//============================= Z Probe Options =============================
// @section probes
// Probe Type
// Probes are sensors/switches that are activated / deactivated before/after use.
// Allen Key Probes, Servo Probes, Z-Sled Probes, FIX_MOUNTED_PROBE, etc.
// You must activate one of these to use Auto Bed Leveling below.
// Use M851 to set the Z probe vertical offset from the nozzle. Store with M500.
// A Fix-Mounted Probe either doesn't deploy or needs manual deployment.
// For example an inductive probe, or a setup that uses the nozzle to probe.
// An inductive probe must be deactivated to go below
// its trigger-point if hardware endstops are active.
//#define FIX_MOUNTED_PROBE
// The BLTouch probe emulates a servo probe.
// The default connector is SERVO 0. Set Z_ENDSTOP_SERVO_NR below to override.
//#define BLTOUCH
// Z Servo Probe, such as an endstop switch on a rotating arm.
//#define Z_ENDSTOP_SERVO_NR 0
//#define Z_SERVO_ANGLES {70,0} // Z Servo Deploy and Stow angles
// Enable if you have a Z probe mounted on a sled like those designed by Charles Bell.
//#define Z_PROBE_SLED
//#define SLED_DOCKING_OFFSET 5 // The extra distance the X axis must travel to pickup the sled. 0 should be fine but you can push it further if you'd like.
// Z Probe to nozzle (X,Y) offset, relative to (0, 0).
// X and Y offsets must be integers.
// In the following example the X and Y offsets are both positive:
// #define X_PROBE_OFFSET_FROM_EXTRUDER 10
// #define Y_PROBE_OFFSET_FROM_EXTRUDER 10
// +-- BACK ---+
// L | (+) P | R <-- probe (20,20)
// E | | I
// F | (-) N (+) | G <-- nozzle (10,10)
// T | | H
// | (-) | T
// O-- FRONT --+
// (0,0)
#define X_PROBE_OFFSET_FROM_EXTRUDER 0 // X offset: -left +right [of the nozzle]
#define Y_PROBE_OFFSET_FROM_EXTRUDER -10 // Y offset: -front +behind [the nozzle]
#define Z_PROBE_OFFSET_FROM_EXTRUDER -3.5 // Z offset: -below +above [the nozzle]
// X and Y axis travel speed (mm/m) between probes
#define XY_PROBE_SPEED 4000
// Speed for the first approach when double-probing (with PROBE_DOUBLE_TOUCH)
#define Z_PROBE_SPEED_FAST HOMING_FEEDRATE_Z
// Speed for the "accurate" probe of each point
#define Z_PROBE_SPEED_SLOW (Z_PROBE_SPEED_FAST / 2)
// Use double touch for probing
//#define PROBE_DOUBLE_TOUCH
// Allen key retractable z-probe as seen on many Kossel delta printers - [reprap.org]
// Deploys by touching z-axis belt. Retracts by pushing the probe down. Uses Z_MIN_PIN.
//#define Z_PROBE_ALLEN_KEY
#if ENABLED(Z_PROBE_ALLEN_KEY)
// 2 or 3 sets of coordinates for deploying and retracting the spring loaded touch probe on G29,
// if servo actuated touch probe is not defined. Uncomment as appropriate for your printer/probe.
// Kossel Mini
#define Z_PROBE_ALLEN_KEY_DEPLOY_1_X 30.0
#define Z_PROBE_ALLEN_KEY_DEPLOY_1_Y DELTA_PRINTABLE_RADIUS
#define Z_PROBE_ALLEN_KEY_DEPLOY_1_Z 100.0
#define Z_PROBE_ALLEN_KEY_DEPLOY_1_FEEDRATE XY_PROBE_SPEED
#define Z_PROBE_ALLEN_KEY_DEPLOY_2_X 0.0
#define Z_PROBE_ALLEN_KEY_DEPLOY_2_Y DELTA_PRINTABLE_RADIUS
#define Z_PROBE_ALLEN_KEY_DEPLOY_2_Z 100.0
#define Z_PROBE_ALLEN_KEY_DEPLOY_2_FEEDRATE (XY_PROBE_SPEED/10)
#define Z_PROBE_ALLEN_KEY_DEPLOY_3_X Z_PROBE_ALLEN_KEY_DEPLOY_2_X * 0.75
#define Z_PROBE_ALLEN_KEY_DEPLOY_3_Y Z_PROBE_ALLEN_KEY_DEPLOY_2_Y * 0.75
#define Z_PROBE_ALLEN_KEY_DEPLOY_3_Z Z_PROBE_ALLEN_KEY_DEPLOY_2_Z
#define Z_PROBE_ALLEN_KEY_DEPLOY_3_FEEDRATE XY_PROBE_SPEED
#define Z_PROBE_ALLEN_KEY_STOW_DEPTH 20
// Move the probe into position
#define Z_PROBE_ALLEN_KEY_STOW_1_X -64.0
#define Z_PROBE_ALLEN_KEY_STOW_1_Y 56.0
#define Z_PROBE_ALLEN_KEY_STOW_1_Z 23.0
#define Z_PROBE_ALLEN_KEY_STOW_1_FEEDRATE XY_PROBE_SPEED
// Move the nozzle down further to push the probe into retracted position.
#define Z_PROBE_ALLEN_KEY_STOW_2_X Z_PROBE_ALLEN_KEY_STOW_1_X
#define Z_PROBE_ALLEN_KEY_STOW_2_Y Z_PROBE_ALLEN_KEY_STOW_1_Y
#define Z_PROBE_ALLEN_KEY_STOW_2_Z (Z_PROBE_ALLEN_KEY_STOW_1_Z-Z_PROBE_ALLEN_KEY_STOW_DEPTH)
#define Z_PROBE_ALLEN_KEY_STOW_2_FEEDRATE (XY_PROBE_SPEED/10)
// Raise things back up slightly so we don't bump into anything
#define Z_PROBE_ALLEN_KEY_STOW_3_X Z_PROBE_ALLEN_KEY_STOW_2_X
#define Z_PROBE_ALLEN_KEY_STOW_3_Y Z_PROBE_ALLEN_KEY_STOW_2_Y
#define Z_PROBE_ALLEN_KEY_STOW_3_Z (Z_PROBE_ALLEN_KEY_STOW_1_Z+Z_PROBE_ALLEN_KEY_STOW_DEPTH)
#define Z_PROBE_ALLEN_KEY_STOW_3_FEEDRATE (XY_PROBE_SPEED/2)
#define Z_PROBE_ALLEN_KEY_STOW_4_X 0.0
#define Z_PROBE_ALLEN_KEY_STOW_4_Y 0.0
#define Z_PROBE_ALLEN_KEY_STOW_4_Z Z_PROBE_ALLEN_KEY_STOW_3_Z
#define Z_PROBE_ALLEN_KEY_STOW_4_FEEDRATE XY_PROBE_SPEED
#endif // Z_PROBE_ALLEN_KEY
// *** PLEASE READ ALL INSTRUCTIONS BELOW FOR SAFETY! ***
// To continue using the Z-min-endstop for homing, be sure to disable Z_SAFE_HOMING.
// Example: To park the head outside the bed area when homing with G28.
// To use a separate Z probe, your board must define a Z_MIN_PROBE_PIN.
// For a servo-based Z probe, you must set up servo support below, including
// NUM_SERVOS, Z_ENDSTOP_SERVO_NR and Z_SERVO_ANGLES.
// - RAMPS 1.3/1.4 boards may be able to use the 5V, GND, and Aux4->D32 pin.
// - Use 5V for powered (usu. inductive) sensors.
// - Otherwise connect:
// - normally-closed switches to GND and D32.
// - normally-open switches to 5V and D32.
// Normally-closed switches are advised and are the default.
// The Z_MIN_PROBE_PIN sets the Arduino pin to use. (See your board's pins file.)
// Since the RAMPS Aux4->D32 pin maps directly to the Arduino D32 pin, D32 is the
// default pin for all RAMPS-based boards. Most boards use the X_MAX_PIN by default.
// To use a different pin you can override it here.
// WARNING:
// Setting the wrong pin may have unexpected and potentially disastrous consequences.
// Use with caution and do your homework.
//#define Z_MIN_PROBE_PIN X_MAX_PIN
// Enable Z_MIN_PROBE_ENDSTOP to use _both_ a Z Probe and a Z-min-endstop on the same machine.
// With this option the Z_MIN_PROBE_PIN will only be used for probing, never for homing.
// Enable Z_MIN_PROBE_USES_Z_MIN_ENDSTOP_PIN to use the Z_MIN_PIN for your Z_MIN_PROBE.
// The Z_MIN_PIN will then be used for both Z-homing and probing.
#define Z_MIN_PROBE_USES_Z_MIN_ENDSTOP_PIN
// To use a probe you must enable one of the two options above!
// Enable Z Probe Repeatability test to see how accurate your probe is
//#define Z_MIN_PROBE_REPEATABILITY_TEST
* Z probes require clearance when deploying, stowing, and moving between
* probe points to avoid hitting the bed and other hardware.
* Servo-mounted probes require extra space for the arm to rotate.
* Inductive probes need space to keep from triggering early.
* Use these settings to specify the distance (mm) to raise the probe (or
* lower the bed). The values set here apply over and above any (negative)
* probe Z Offset set with Z_PROBE_OFFSET_FROM_EXTRUDER, M851, or the LCD.
* Only integer values >= 1 are valid here.
* Example: `M851 Z-5` with a CLEARANCE of 4 => 9mm from bed to nozzle.
* But: `M851 Z+1` with a CLEARANCE of 2 => 2mm from bed to nozzle.
#define Z_CLEARANCE_DEPLOY_PROBE 50 // Z Clearance for Deploy/Stow
#define Z_CLEARANCE_BETWEEN_PROBES 5 // Z Clearance between probe points
// For M851 give a range for adjusting the Z probe offset
#define Z_PROBE_OFFSET_RANGE_MIN -20
#define Z_PROBE_OFFSET_RANGE_MAX 20
// :{ 0:'Low', 1:'High' }
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define E_ENABLE_ON 0 // For all extruders
// Disables axis stepper immediately when it's not being used.
// WARNING: When motors turn off there is a chance of losing position accuracy!
#define DISABLE_X false
#define DISABLE_Y false
#define DISABLE_Z false
// Warn on display about possibly reduced accuracy
//#define DISABLE_REDUCED_ACCURACY_WARNING
#define DISABLE_E false // For all extruders
#define DISABLE_INACTIVE_EXTRUDER true //disable only inactive extruders and keep active extruder enabled
// @section machine
// Invert the stepper direction. Change (or reverse the motor connector) if an axis goes the wrong way.
#define INVERT_X_DIR true // DELTA does not invert
#define INVERT_Y_DIR true
#define INVERT_Z_DIR true
// For direct drive extruder v9 set to true, for geared extruder set to false.
#define INVERT_E0_DIR false
#define INVERT_E1_DIR false
#define INVERT_E2_DIR false
#define INVERT_E3_DIR false
// @section homing
//#define Z_HOMING_HEIGHT 15 // (in mm) Minimal z height before homing (G28) for Z clearance above the bed, clamps, ...
// Be sure you have this distance over your Z_MAX_POS in case.
// ENDSTOP SETTINGS:
// :[-1, 1]
#define X_HOME_DIR 1 // deltas always home to max
#define Y_HOME_DIR 1
#define Z_HOME_DIR 1
#define min_software_endstops false // If true, axis won't move to coordinates less than HOME_POS.
#define max_software_endstops false // If true, axis won't move to coordinates greater than the defined lengths below.
// @section machine
// Travel limits after homing (units are in mm)
#define X_MIN_POS -(DELTA_PRINTABLE_RADIUS)
#define Y_MIN_POS -(DELTA_PRINTABLE_RADIUS)
#define Z_MIN_POS 0
#define X_MAX_POS DELTA_PRINTABLE_RADIUS
#define Y_MAX_POS DELTA_PRINTABLE_RADIUS
#define Z_MAX_POS MANUAL_Z_HOME_POS
//========================= Filament Runout Sensor ==========================
//#define FILAMENT_RUNOUT_SENSOR // Uncomment for defining a filament runout sensor such as a mechanical or opto endstop to check the existence of filament
// RAMPS-based boards use SERVO3_PIN. For other boards you may need to define FIL_RUNOUT_PIN.
// It is assumed that when logic high = filament available
// when logic low = filament ran out
#if ENABLED(FILAMENT_RUNOUT_SENSOR)
#define FIL_RUNOUT_INVERTING false // set to true to invert the logic of the sensor.
#define ENDSTOPPULLUP_FIL_RUNOUT // Uncomment to use internal pullup for filament runout pins if the sensor is defined.
#define FILAMENT_RUNOUT_SCRIPT "M600"
#endif
//============================ Mesh Bed Leveling ============================
//#define MESH_BED_LEVELING // Enable mesh bed leveling.
#if ENABLED(MESH_BED_LEVELING)
#define MESH_INSET 10 // Mesh inset margin on print area
#define MESH_NUM_X_POINTS 3 // Don't use more than 7 points per axis, implementation limited.
#define MESH_NUM_Y_POINTS 3
#define MESH_HOME_SEARCH_Z 4 // Z after Home, bed somewhere below but above 0.0.
//#define MESH_G28_REST_ORIGIN // After homing all axes ('G28' or 'G28 XYZ') rest at origin [0,0,0]
//#define MANUAL_BED_LEVELING // Add display menu option for bed leveling.
#if ENABLED(MANUAL_BED_LEVELING)
#define MBL_Z_STEP 0.025 // Step size while manually probing Z axis.
#endif // MANUAL_BED_LEVELING
// Gradually reduce leveling correction until a set height is reached,
// at which point movement will be level to the machine's XY plane.
// The height can be set with M420 Z
#define ENABLE_LEVELING_FADE_HEIGHT
#endif // MESH_BED_LEVELING
//============================ Auto Bed Leveling ============================
// @section bedlevel
* Select one form of Auto Bed Leveling below.
* If you're also using the Probe for Z Homing, it's
* highly recommended to enable Z_SAFE_HOMING also!
* - 3POINT
* Probe 3 arbitrary points on the bed (that aren't collinear)
* You specify the XY coordinates of all 3 points.
* The result is a single tilted plane. Best for a flat bed.
* - LINEAR
* Probe several points in a grid.
* You specify the rectangle and the density of sample points.
* - BILINEAR
* The result is a mesh, best for large or uneven beds.
//#define AUTO_BED_LEVELING_3POINT
//#define AUTO_BED_LEVELING_LINEAR
//#define AUTO_BED_LEVELING_BILINEAR
* Enable detailed logging of G28, G29, M48, etc.
* Turn on with the command 'M111 S32'.
* NOTE: Requires a lot of PROGMEM!
//#define DEBUG_LEVELING_FEATURE
#if ENABLED(AUTO_BED_LEVELING_LINEAR) || ENABLED(AUTO_BED_LEVELING_BILINEAR)
// Set the number of grid points per dimension.
// Works best with 5 or more points in each dimension.
#define ABL_GRID_POINTS_X 9
#define ABL_GRID_POINTS_Y ABL_GRID_POINTS_X
// Set the boundaries for probing (where the probe can reach).
#define DELTA_PROBEABLE_RADIUS (DELTA_PRINTABLE_RADIUS - 10)
#define LEFT_PROBE_BED_POSITION -(DELTA_PROBEABLE_RADIUS)
#define RIGHT_PROBE_BED_POSITION DELTA_PROBEABLE_RADIUS
#define FRONT_PROBE_BED_POSITION -(DELTA_PROBEABLE_RADIUS)
#define BACK_PROBE_BED_POSITION DELTA_PROBEABLE_RADIUS
// The Z probe minimum outer margin (to validate G29 parameters).
#define MIN_PROBE_EDGE 10
// Probe along the Y axis, advancing X after each column
//#define PROBE_Y_FIRST
#if ENABLED(AUTO_BED_LEVELING_BILINEAR)
// Experimental Subdivision of the grid by Catmull-Rom method.
// Synthesizes intermediate points to produce a more detailed mesh.
//#define ABL_BILINEAR_SUBDIVISION
#if ENABLED(ABL_BILINEAR_SUBDIVISION)
// Number of subdivisions between probe points
#define BILINEAR_SUBDIVISIONS 3
#endif
#endif
#elif ENABLED(AUTO_BED_LEVELING_3POINT)
// 3 arbitrary points to probe.
// A simple cross-product is used to estimate the plane of the bed.
#define ABL_PROBE_PT_1_X 15
#define ABL_PROBE_PT_1_Y 180
#define ABL_PROBE_PT_2_X 15
#define ABL_PROBE_PT_2_Y 20
#define ABL_PROBE_PT_3_X 170
#define ABL_PROBE_PT_3_Y 20
#endif
* Commands to execute at the end of G29 probing.
* Useful to retract or move the Z probe out of the way.
//#define Z_PROBE_END_SCRIPT "G1 Z10 F12000\nG1 X15 Y330\nG1 Z0.5\nG1 Z10"
// @section homing
// The center of the bed is at (X=0, Y=0)
#define BED_CENTER_AT_0_0
// Manually set the home position. Leave these undefined for automatic settings.
// For DELTA this is the top-center of the Cartesian print volume.
//#define MANUAL_X_HOME_POS 0
//#define MANUAL_Y_HOME_POS 0
#define MANUAL_Z_HOME_POS 250 // Distance between the nozzle to printbed after homing
// Use "Z Safe Homing" to avoid homing with a Z probe outside the bed area.
// With this feature enabled:
// - Allow Z homing only after X and Y homing AND stepper drivers still enabled.
// - If stepper drivers time out, it will need X and Y homing again before Z homing.
// - Move the Z probe (or nozzle) to a defined XY point before Z Homing when homing all axes (G28).
// - Prevent Z homing when the Z probe is outside bed area.
//#define Z_SAFE_HOMING
#if ENABLED(Z_SAFE_HOMING)
#define Z_SAFE_HOMING_X_POINT ((X_MIN_POS + X_MAX_POS) / 2) // X point for Z homing when homing all axis (G28).
#define Z_SAFE_HOMING_Y_POINT ((Y_MIN_POS + Y_MAX_POS) / 2) // Y point for Z homing when homing all axis (G28).
#endif
// Delta only homes to Z
#define HOMING_FEEDRATE_Z (200*60)
//============================= Additional Features ===========================
// @section extras
// EEPROM
// The microcontroller can store settings in the EEPROM, e.g. max velocity...
// M500 - stores parameters in EEPROM
// M501 - reads parameters from EEPROM (if you need reset them after you changed them temporarily).
// M502 - reverts to the default "factory settings". You still need to store them in EEPROM afterwards if you want to.
//define this to enable EEPROM support
#define EEPROM_SETTINGS
#if ENABLED(EEPROM_SETTINGS)
// To disable EEPROM Serial responses and decrease program space by ~1700 byte: comment this out:
#define EEPROM_CHITCHAT // Please keep turned on if you can.
#endif
// Host Keepalive
// When enabled Marlin will send a busy status message to the host
// every couple of seconds when it can't accept commands.
#define HOST_KEEPALIVE_FEATURE // Disable this if your host doesn't like keepalive messages
#define DEFAULT_KEEPALIVE_INTERVAL 2 // Number of seconds between "busy" messages. Set with M113.
// M100 Free Memory Watcher
//#define M100_FREE_MEMORY_WATCHER // uncomment to add the M100 Free Memory Watcher for debug purpose
// G20/G21 Inch mode support
//#define INCH_MODE_SUPPORT
// M149 Set temperature units support
//#define TEMPERATURE_UNITS_SUPPORT
// Preheat Constants
#define PREHEAT_1_TEMP_HOTEND 180
#define PREHEAT_1_TEMP_BED 70
#define PREHEAT_1_FAN_SPEED 255 // Value from 0 to 255
#define PREHEAT_2_TEMP_HOTEND 240
#define PREHEAT_2_TEMP_BED 100
#define PREHEAT_2_FAN_SPEED 255 // Value from 0 to 255
// Nozzle Park -- EXPERIMENTAL
// When enabled allows the user to define a special XYZ position, inside the
// machine's topology, to park the nozzle when idle or when receiving the G27
// command.
// The "P" paramenter controls what is the action applied to the Z axis:
// P0: (Default) If current Z-pos is lower than Z-park then the nozzle will
// be raised to reach Z-park height.
// P1: No matter the current Z-pos, the nozzle will be raised/lowered to
// reach Z-park height.
// P2: The nozzle height will be raised by Z-park amount but never going over
// the machine's limit of Z_MAX_POS.
//#define NOZZLE_PARK_FEATURE
#if ENABLED(NOZZLE_PARK_FEATURE)
// Specify a park position as { X, Y, Z }
#define NOZZLE_PARK_POINT { (X_MIN_POS + 10), (Y_MAX_POS - 10), 20 }
#endif
// Clean Nozzle Feature -- EXPERIMENTAL
// When enabled allows the user to send G12 to start the nozzle cleaning
// process, the G-Code accepts two parameters:
// "P" for pattern selection
// "S" for defining the number of strokes/repetitions
// Available list of patterns:
// P0: This is the default pattern, this process requires a sponge type
// material at a fixed bed location, the cleaning process is based on
// "strokes" i.e. back-and-forth movements between the starting and end
// points.
// P1: This starts a zig-zag pattern between (X0, Y0) and (X1, Y1), "T"
// defines the number of zig-zag triangles to be done. "S" defines the
// number of strokes aka one back-and-forth movement. As an example
// sending "G12 P1 S1 T3" will execute:
// | (X0, Y1) | /\ /\ /\ | (X1, Y1)
// A | | / \ / \ / \ |
// | (X0, Y0) | / \/ \/ \ | (X1, Y0)
// |________|_________|_________|
// T1 T2 T3
// Caveats: End point Z should use the same value as Start point Z.
// Attention: This is an EXPERIMENTAL feature, in the future the G-code arguments
// may change to add new functionality like different wipe patterns.
//#define NOZZLE_CLEAN_FEATURE
#if ENABLED(NOZZLE_CLEAN_FEATURE)
// Number of pattern repetitions
#define NOZZLE_CLEAN_STROKES 12
// Specify positions as { X, Y, Z }
#define NOZZLE_CLEAN_START_POINT { 30, 30, (Z_MIN_POS + 1)}
#define NOZZLE_CLEAN_END_POINT {100, 60, (Z_MIN_POS + 1)}
// Moves the nozzle to the initial position
#define NOZZLE_CLEAN_GOBACK
#endif
// Print job timer
// Enable this option to automatically start and stop the
// print job timer when M104/M109/M190 commands are received.
// M104 (extruder without wait) - high temp = none, low temp = stop timer
// M109 (extruder with wait) - high temp = start timer, low temp = stop timer
// M190 (bed with wait) - high temp = start timer, low temp = none
// In all cases the timer can be started and stopped using
// the following commands:
// - M75 - Start the print job timer
// - M76 - Pause the print job timer
// - M77 - Stop the print job timer
#define PRINTJOB_TIMER_AUTOSTART
// Print Counter
// When enabled Marlin will keep track of some print statistical data such as:
// - Total print jobs
// - Total successful print jobs
// - Total failed print jobs
// - Total time printing
// This information can be viewed by the M78 command.
//#define PRINTCOUNTER
//============================= LCD and SD support ============================
// @section lcd
// LCD LANGUAGE
// Here you may choose the language used by Marlin on the LCD menus, the following
// list of languages are available:
// en, an, bg, ca, cn, cz, de, el, el-gr, es, eu, fi, fr, gl, hr, it,
// kana, kana_utf8, nl, pl, pt, pt_utf8, pt-br, pt-br_utf8, ru, tr, uk, test
// :{ 'en':'English', 'an':'Aragonese', 'bg':'Bulgarian', 'ca':'Catalan', 'cn':'Chinese', 'cz':'Czech', 'de':'German', 'el':'Greek', 'el-gr':'Greek (Greece)', 'es':'Spanish', 'eu':'Basque-Euskera', 'fi':'Finnish', 'fr':'French', 'gl':'Galician', 'hr':'Croatian', 'it':'Italian', 'kana':'Japanese', 'kana_utf8':'Japanese (UTF8)', 'nl':'Dutch', 'pl':'Polish', 'pt':'Portuguese', 'pt-br':'Portuguese (Brazilian)', 'pt-br_utf8':'Portuguese (Brazilian UTF8)', 'pt_utf8':'Portuguese (UTF8)', 'ru':'Russian', 'tr':'Turkish', 'uk':'Ukrainian', 'test':'TEST' }
#define LCD_LANGUAGE en
// LCD Character Set
// Note: This option is NOT applicable to Graphical Displays.
// All character-based LCD's provide ASCII plus one of these
// language extensions:
// - JAPANESE ... the most common
// - WESTERN ... with more accented characters
// - CYRILLIC ... for the Russian language
// To determine the language extension installed on your controller:
// - Compile and upload with LCD_LANGUAGE set to 'test'
// - Click the controller to view the LCD menu
// - The LCD will display Japanese, Western, or Cyrillic text
// See [github.com]
// :['JAPANESE', 'WESTERN', 'CYRILLIC']
#define DISPLAY_CHARSET_HD44780 JAPANESE
// LCD TYPE
// You may choose ULTRA_LCD if you have character based LCD with 16x2, 16x4, 20x2,
// 20x4 char/lines or DOGLCD for the full graphics display with 128x64 pixels
// (ST7565R family). (This option will be set automatically for certain displays.)
// IMPORTANT NOTE: The U8glib library is required for Full Graphic Display!
// [github.com]
//#define ULTRA_LCD // Character based
//#define DOGLCD // Full graphics display
// SD CARD
// SD Card support is disabled by default. If your controller has an SD slot,
// you must uncomment the following option or it won't work.
#define SDSUPPORT
// SD CARD: SPI SPEED
// Uncomment ONE of the following items to use a slower SPI transfer
// speed. This is usually required if you're getting volume init errors.
//#define SPI_SPEED SPI_HALF_SPEED
//#define SPI_SPEED SPI_QUARTER_SPEED
//#define SPI_SPEED SPI_EIGHTH_SPEED
// SD CARD: ENABLE CRC
// Use CRC checks and retries on the SD communication.
//#define SD_CHECK_AND_RETRY
// ENCODER SETTINGS
// This option overrides the default number of encoder pulses needed to
// produce one step. Should be increased for high-resolution encoders.
//#define ENCODER_PULSES_PER_STEP 1
// Use this option to override the number of step signals required to
// move between next/prev menu items.
//#define ENCODER_STEPS_PER_MENU_ITEM 5
* Encoder Direction Options
* Test your encoder's behavior first with both options disabled.
* Reversed Value Edit and Menu Nav? Enable REVERSE_ENCODER_DIRECTION.
* Reversed Menu Navigation only? Enable REVERSE_MENU_DIRECTION.
* Reversed Value Editing only? Enable BOTH options.
// This option reverses the encoder direction everywhere
// Set this option if CLOCKWISE causes values to DECREASE
//#define REVERSE_ENCODER_DIRECTION
// This option reverses the encoder direction for navigating LCD menus.
// If CLOCKWISE normally moves DOWN this makes it go UP.
// If CLOCKWISE normally moves UP this makes it go DOWN.
//#define REVERSE_MENU_DIRECTION
// Individual Axis Homing
// Add individual axis homing items (Home X, Home Y, and Home Z) to the LCD menu.
//#define INDIVIDUAL_AXIS_HOMING_MENU
// SPEAKER/BUZZER
// If you have a speaker that can produce tones, enable it here.
// By default Marlin assumes you have a buzzer with a fixed frequency.
//#define SPEAKER
// The duration and frequency for the UI feedback sound.
// Set these to 0 to disable audio feedback in the LCD menus.
// Note: Test audio output with the G-Code:
// M300 S P
//#define LCD_FEEDBACK_FREQUENCY_DURATION_MS 100
//#define LCD_FEEDBACK_FREQUENCY_HZ 1000
// CONTROLLER TYPE: Standard
// Marlin supports a wide variety of controllers.
// Enable one of the following options to specify your controller.
// ULTIMAKER Controller.
//#define ULTIMAKERCONTROLLER
// ULTIPANEL as seen on Thingiverse.
//#define ULTIPANEL
// Cartesio UI
// [mauk.cc]
//#define CARTESIO_UI
// PanelOne from T3P3 (via RAMPS 1.4 AUX2/AUX3)
// [reprap.org]
//#define PANEL_ONE
// MaKr3d Makr-Panel with graphic controller and SD support.
// [reprap.org]
//#define MAKRPANEL
// ReprapWorld Graphical LCD
// [reprapworld.com]
//#define REPRAPWORLD_GRAPHICAL_LCD
// Activate one of these if you have a Panucatt Devices
// Viki 2.0 or mini Viki with Graphic LCD
// [panucatt.com]
//#define VIKI2
//#define miniVIKI
// Adafruit ST7565 Full Graphic Controller.
// [github.com]
//#define ELB_FULL_GRAPHIC_CONTROLLER
// RepRapDiscount Smart Controller.
// [reprap.org]
// Note: Usually sold with a white PCB.
#define REPRAP_DISCOUNT_SMART_CONTROLLER
// GADGETS3D G3D LCD/SD Controller
// [reprap.org]
// Note: Usually sold with a blue PCB.
//#define G3D_PANEL
// RepRapDiscount FULL GRAPHIC Smart Controller
// [reprap.org]
//#define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER
// MakerLab Mini Panel with graphic
// controller and SD support - [reprap.org]
//#define MINIPANEL
// RepRapWorld REPRAPWORLD_KEYPAD v1.1
// REPRAPWORLD_KEYPAD_MOVE_STEP sets how much should the robot move when a key
// is pressed, a value of 10.0 means 10mm per click.
//#define REPRAPWORLD_KEYPAD
//#define REPRAPWORLD_KEYPAD_MOVE_STEP 1.0
// RigidBot Panel V1.0
// [www.inventapart.com]
//#define RIGIDBOT_PANEL
// BQ LCD Smart Controller shipped by
// default with the BQ Hephestos 2 and Witbox 2.
//#define BQ_LCD_SMART_CONTROLLER
// CONTROLLER TYPE: I2C
// Note: These controllers require the installation of Arduino's LiquidCrystal_I2C
// library. For more info: [github.com]
// Elefu RA Board Control Panel
// [www.elefu.com]
//#define RA_CONTROL_PANEL
// Sainsmart YW Robot (LCM1602) LCD Display
//#define LCD_I2C_SAINSMART_YWROBOT
// Generic LCM1602 LCD adapter
//#define LCM1602
// PANELOLU2 LCD with status LEDs,
// separate encoder and click inputs.
// Note: This controller requires Arduino's LiquidTWI2 library v1.2.3 or later.
// For more info: [github.com]
// Note: The PANELOLU2 encoder click input can either be directly connected to
// a pin (if BTN_ENC defined to != -1) or read through I2C (when BTN_ENC == -1).
//#define LCD_I2C_PANELOLU2
// Panucatt VIKI LCD with status LEDs,
// integrated click & L/R/U/D buttons, separate encoder inputs.
//#define LCD_I2C_VIKI
// SSD1306 OLED full graphics generic display
//#define U8GLIB_SSD1306
// SAV OLEd LCD module support using either SSD1306 or SH1106 based LCD modules
//#define SAV_3DGLCD
#if ENABLED(SAV_3DGLCD)
#define U8GLIB_SH1106
#endif
// CONTROLLER TYPE: Shift register panels
// 2 wire Non-latching LCD SR from [goo.gl]
// LCD configuration: [reprap.org]
//#define SAV_3DLCD
//=============================== Extra Features ==============================
// @section extras
// Increase the FAN PWM frequency. Removes the PWM noise but increases heating in the FET/Arduino
//#define FAST_PWM_FAN
// Use software PWM to drive the fan, as for the heaters. This uses a very low frequency
// which is not as annoying as with the hardware PWM. On the other hand, if this frequency
// is too low, you should also increment SOFT_PWM_SCALE.
//#define FAN_SOFT_PWM
// Incrementing this by 1 will double the software PWM frequency,
// affecting heaters, and the fan if FAN_SOFT_PWM is enabled.
// However, control resolution will be halved for each increment;
// at zero value, there are 128 effective control positions.
#define SOFT_PWM_SCALE 0
// Temperature status LEDs that display the hotend and bed temperature.
// If all hotends and bed temperature and temperature setpoint are < 54C then the BLUE led is on.
// Otherwise the RED led is on. There is 1C hysteresis.
//#define TEMP_STAT_LEDS
// M240 Triggers a camera by emulating a Canon RC-1 Remote
// Data from: [www.doc-diy.net]
//#define PHOTOGRAPH_PIN 23
// SkeinForge sends the wrong arc g-codes when using Arc Point as fillet procedure
//#define SF_ARC_FIX
// Support for the BariCUDA Paste Extruder.
//#define BARICUDA
//define BlinkM/CyzRgb Support
//#define BLINKM
// Support for an RGB LED using 3 separate pins with optional PWM
//#define RGB_LED
#if ENABLED(RGB_LED)
#define RGB_LED_R_PIN 34
#define RGB_LED_G_PIN 43
#define RGB_LED_B_PIN 35
#endif
* R/C SERVO support
* Sponsored by TrinityLabs, Reworked by codexmas
// Number of servos
// If you select a configuration below, this will receive a default value and does not need to be set manually
// set it manually if you have more servos than extruders and wish to manually control some
// leaving it undefined or defining as 0 will disable the servo subsystem
// If unsure, leave commented / disabled
//#define NUM_SERVOS 3 // Servo index starts with 0 for M280 command
// Delay (in microseconds) before the next move will start, to give the servo time to reach its target angle.
// 300ms is a good value but you can try less delay.
// If the servo can't reach the requested position, increase it.
#define SERVO_DELAY 300
// Servo deactivation
// With this option servos are powered only during movement, then turned off to prevent jitter.
//#define DEACTIVATE_SERVOS_AFTER_MOVE
* Support for a filament diameter sensor
* Also allows adjustment of diameter at print time (vs at slicing)
* Single extruder only at this point (extruder 0)
* Motherboards
* 34 - RAMPS1.4 - uses Analog input 5 on the AUX2 connector
* 81 - Printrboard - Uses Analog input 2 on the Exp1 connector (version B,C,D,E)
* 301 - Rambo - uses Analog input 3
* Note may require analog pins to be defined for different motherboards
// Uncomment below to enable
//#define FILAMENT_WIDTH_SENSOR
#define DEFAULT_NOMINAL_FILAMENT_DIA 3.00 //Enter the diameter (in mm) of the filament generally used (3.0 mm or 1.75 mm) - this is then used in the slicer software. Used for sensor reading validation
#if ENABLED(FILAMENT_WIDTH_SENSOR)
#define FILAMENT_SENSOR_EXTRUDER_NUM 0 //The number of the extruder that has the filament sensor (0,1,2)
#define MEASUREMENT_DELAY_CM 14 //measurement delay in cm. This is the distance from filament sensor to middle of barrel
#define MEASURED_UPPER_LIMIT 3.30 //upper limit factor used for sensor reading validation in mm
#define MEASURED_LOWER_LIMIT 1.90 //lower limit factor for sensor reading validation in mm
#define MAX_MEASUREMENT_DELAY 20 //delay buffer size in bytes (1 byte = 1cm)- limits maximum measurement delay allowable (must be larger than MEASUREMENT_DELAY_CM and lower number saves RAM)
#define DEFAULT_MEASURED_FILAMENT_DIA DEFAULT_NOMINAL_FILAMENT_DIA //set measured to nominal initially
//When using an LCD, uncomment the line below to display the Filament sensor data on the last line instead of status. Status will appear for 5 sec.
//#define FILAMENT_LCD_DISPLAY
#endif
#endif // CONFIGURATION_H
Edited 1 time(s). Last edit at 02/23/2017 11:50PM by Uscstaylor.
Re: Please help me fix this axis issue
February 24, 2017 04:17PM
If I can get my direction corrected then I could most likely finish this myself, If anyone would care to please take a look at this I would be grateful to you.
February 24, 2017 11:57PM
WIth it powered up, send M119 and see what the status of your endstops are.
Then manually trigger each of the endstops, and send another M119 to ensure that the endstops are triggering correctly.
If the endstops are working correctly, put the carriages in the middle of their travel, and send a home command (one hand on the power switch). Which direction do the carriages move?
February 26, 2017 11:38PM
Nebbian
X max Open
Y max Open
Z Min Triggered
z Max Open
I can't move them manually in Rep Host. I don't know why they are not moving....These were working fine before I lost all my settings. When I put the carriage in the middle of the printer and hit home only the back and the right side start to go up slowly, the left side axis just sits there.
Edited 2 time(s). Last edit at 02/26/2017 11:47PM by Uscstaylor.
February 27, 2017 12:00AM
By "manually triggering the endstops", I meant to push the switches with your finger, while sending M119.
Your issue sounds like your X stepper driver is blown, the current is set way too low, or the connector to the X stepper motor is loose. Try reseating the connector for the X motor, and if that doesn't solve it, try swapping the X and Y stepper motor drivers (with the power off, obviously).
February 27, 2017 02:59PM
I tried to press each endstop manually and they say Triggered, so they are working. I checked all the wires they are tight,
I cant get the left axis to move. The back one and the right one moves slowly but the left one is not moving at all. I cant understand how it cannot be working due to the lose of settings in the firmware. I have reloaded basic firmware and I'm tweaking it at the moment but my stepper motors are not running as fast as they were and one is not moving at all. Is it possible the current is not set high enough, is there settings in the firmware for that?
Edited 3 time(s). Last edit at 02/27/2017 03:28PM by Uscstaylor.
February 27, 2017 06:36PM
OK Now
I made some progress in the firmware. I had to reverse the directions of the steppers so now when I hit the Home button for all the axis they move up to the end switches but my left stepper motor is still not moving. If its the stepper driver can that be replaced.
February 27, 2017 09:50PM
It's possible that the newer version uses different eeprom mappings to the old version.
Try sending these commands:
M502;  // Read values from firmware
M500;  // Save those values to eeprom
If that fails, try swapping the stepper drivers from the X and Y axes.
February 27, 2017 10:35PM
OK I made more progress
My printer now homes to the very top and x axis 0= Triggered Y axis 0= Triggered and the Z axis 250= Triggered. The printer is homed but now when I drop the carriage the the bottom its not quite to the bed it stop short around 250 mm away from it and I'm not sure what to change to make it drop all the way to the bed.
Update after using your commands M502 and M500. My printer homes to the top then drops from 250 to 195.13 from the top then stops. Is that good? I liked when it was stopped at the top of the printer....Making progress now that all axis work. Just need to get this to get to the bottom of the bed.
Here's a pic as low as I can get it. What do I change in the firmware to get it lower please
Edited 2 time(s). Last edit at 02/27/2017 10:58PM by Uscstaylor.
February 27, 2017 10:44PM
Try increasing your Z max height.
It's currently set to 250, increase this by the distance it's stopping short by.
February 27, 2017 10:47PM
btw if you don't want it to move down a bit after homing, comment out this line:
February 27, 2017 11:04PM
You have no idea how excited I am to get this far...I have been watching so many videos, I think I'm going blind...Lol...I appreciate all the help once I get this thing running Ill take care of ya brother..
February 27, 2017 11:07PM
I went to make the changes for the home position to the top but that line was commented out already..weird it only happened after I ran the M502 and M500 command.
February 27, 2017 11:08PM
Are you using two slashes to denote a comment? It's uncommented in the file you posted above.
February 27, 2017 11:10PM
Can you post the log of what Pronterface spits out when you connect to the printer please?
February 27, 2017 11:13PM
btw it's really great that you're using turnbuckles to square up the towers. Most people haven't cottoned on to this trick. However you need two more, as it is, if you tighten those up quite a bit, you'll make the towers lean towards the front of the printer. It's best to use 4 turnbuckles in total, crossing them over to make an X on the X/Z and Y/Z face. Then you can make your towers rock solid.
February 27, 2017 11:27PM
This is copied right form my firmware settings....//#define Z_SAFE_HOMING
Edited 1 time(s). Last edit at 02/27/2017 11:27PM by Uscstaylor.
February 27, 2017 11:28PM
Uscstaylor
DELTA_HOME_TO_SAFE_ZONE is not the same as Z_SAFE_HOMING
February 27, 2017 11:29PM
Heres what Pontoface is spitting out...lol
Connecting...
start
Printer is now online.
echo:Marlin 1.1.0-RC8
echo: Last Updated: 2016-12-06 12:00 | Author: (none, default config)
Compiled: Feb 27 2017
echo: Free Memory: 3738 PlannerBufferBytes: 1168
echo:V27 stored settings retrieved (398 bytes)
echoconfused smileyteps per unit:
echo: M92 X80.00 Y80.00 Z80.00 E80.00
echo:Maximum feedrates (mm/s):
echo: M203 X200.00 Y200.00 Z200.00 E200.00
echo:Maximum Acceleration (mm/s2):
echo: M201 X3000 Y3000 Z3000 E3000
echo:Accelerations: P=printing, R=retract and T=travel
echo: M204 P2500.00 R2500.00 T2500.00
echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
echo: M205 S0.00 T0.00 B20000 X20.00 Y20.00 Z20.00 E20.00
echo:Home offset (mm)
echo: M206 X0.00 Y0.00 Z0.00
echo:Endstop adjustment (mm):
echo: M666 X0.00 Y0.00 Z0.00
echogrinning smileyelta settings: L=diagonal_rod, R=radius, S=segments_per_second, ABC=diagonal_rod_trim_tower_[123]
echo: M665 L216.00 R95.90 S160.00 A0.00 B0.00 C0.00
echo:Material heatup parameters:
echo: M145 S0 H180 B70 F255
M145 S1 H240 B100 F255
echotongue sticking out smileyID settings:
echo: M301 P22.20 I1.08 D114.00
echo:Filament settings: Disabled
echo: M200 D3.00
echo: M200 D0
echoconfused smileyD init fail
February 27, 2017 11:31PM
I dont know why those smiley faces are there..haha
February 27, 2017 11:39PM
How can I change the travel speed downward towards the bed when moving the z axis its super slow...
February 27, 2017 11:56PM
nebbian
Uscstaylor
Gotcha FIXED...Were getting there brother....Im stoked.
February 28, 2017 12:00AM
Uscstaylor
Change the mm/min Z speed in the pronterface panel. By default it's 100 mm/min, which is super slow. Set to 1000 or something.
February 28, 2017 12:24AM
Im using Repitier Host, I only used Ponterface to show you the log of the printer.
February 28, 2017 12:30AM
I changed it Ponterface...Just curious so I know I have my axis correct. The X axis is the left side and the Y axis is the right side correct, and what should be the movement of both axis X and the Y...please
February 28, 2017 12:36AM
I talk to ya tomorrow Nebbian..If ya want I can shoot ya my cell phone
February 28, 2017 01:19AM
Repetier host has the same option, it's just hidden in the printer settings.
February 28, 2017 01:20AM
The X tower is the left, Y tower is right, Z tower is rear.
Moving positive in the X direction moves the effector towards the right, moving positive in the Y direction moves the effector towards the back of the bed, moving positive in Z moves the effector up.
Edited 1 time(s). Last edit at 02/28/2017 01:21AM by nebbian.
February 28, 2017 02:09PM
Mine looks different but you talking about the Z axis Travel feedrate correct? Also I haven't been able to move my extruder motor. I think something might be commented out in the firmware.
February 28, 2017 05:41PM
Uscstaylor
Yep, Z axis travel feedrate. You probably can't move the extruder motor because it won't turn while the hotend is cold. This is a safety measure to stop the extruder motor trying to push filament that won't move.
