Endstops tiggered but printer does not stop
Posted by tim3716
April 02, 2017 06:42PM
I am running a azteeg x5 mini and I cant seem to get the endstops working properly. With M119 I can test all my end stops and they seem to be all working; when I home (G18), it seems like the software does not recognize the endstops at all and keeps the motors going.
Re: Endstops tiggered but printer does not stop
April 03, 2017 12:15AM
Attach your config and we might be able to see what's wrong.
April 04, 2017 11:12PM
I thought it was the wrong pin out but I checked with the axteeg x5 mini and it should be right.
open | download - config.txt (20.9 KB)
April 05, 2017 09:39PM
Hmm that config seems OK to me. The only difference with my config that might make a difference is the 'alpha_limit_enable' set to true on yours, mine doesn't have those lines (for alpha, beta and gamma). Try removing those lines (or set them to false).
Also you can try this: turn the machine on, and jog in Z in +1mm increments. Do your carriages go up or down? If they go down for +Z movements then you might have the issue below.
It's possible that you might have a combination of:
1) Wrong direction on motors, and
2) Endstops are not inverted.
