Marlin RC8 with Delta Auto Calibrate April 15, 2017 06:43AM |
Re: Marlin RC8 with Delta Auto Calibrate April 15, 2017 08:26AM |
Re: Marlin RC8 with Delta Auto Calibrate April 15, 2017 10:42AM |
Re: Marlin RC8 with Delta Auto Calibrate April 22, 2017 06:13AM |
Re: Marlin RC8 with Delta Auto Calibrate April 23, 2017 04:50AM |
Re: Marlin RC8 with Delta Auto Calibrate April 24, 2017 05:18AM |
Re: Marlin RC8 with Delta Auto Calibrate May 02, 2017 07:04AM |
Re: Marlin RC8 with Delta Auto Calibrate May 05, 2017 01:51AM |
Re: Marlin RC8 with Delta Auto Calibrate May 06, 2017 07:35PM |
Re: Marlin RC8 with Delta Auto Calibrate May 09, 2017 04:12PM |
Re: Marlin RC8 with Delta Auto Calibrate May 12, 2017 06:51AM |
Re: Marlin RC8 with Delta Auto Calibrate May 26, 2017 01:53AM |
Re: Marlin RC8 with Delta Auto Calibrate June 06, 2017 04:27AM |
Re: Marlin RC8 with Delta Auto Calibrate June 06, 2017 06:29AM |
GibaHC
I'm struggling with the calibration of my DYI kossel mini and decided to give a try on the G33, after lots of Escher calculator iterations with results that are worse than no calibration at all.
Re: Marlin RC8 with Delta Auto Calibrate June 06, 2017 08:37AM |
Re: Marlin RC8 with Delta Auto Calibrate June 06, 2017 04:45PM |
Re: Marlin RC8 with Delta Auto Calibrate June 07, 2017 03:18AM |
GibaHC
... but it should be possible to avoid the stow/deploy procedure in this case...
dc42
... I haven't used Marlin for 3 years. Does the current version even support tower position corrections expressed as differences from the ideal 120 degree angles, which is what other firmwares do and the calculator expects?
Re: Marlin RC8 with Delta Auto Calibrate June 10, 2017 01:40AM |
LVD
GibaHC
this was already fixed in the latest version in my rep (1.1.2-AC) and will be incorporated in Marlin 1.1.3; use G33 not to stow and G33 E to stow after each probe.
I tried the 1.1.3-AC today with excellent results. First i finished some measurements, realizing my delta radium should be trimmed for the x tower. From them on the G33 could handle the calibration.
I have attached a .pdf file showing the G29 return in each step, in case someone is interested. Every reflash i did M502 and M500 to reset the EEPROM.
Too late to start printing today, but tomorrow i'll extrude a test print.
Thanks
Re: Marlin RC8 with Delta Auto Calibrate August 01, 2017 04:02AM |
Re: Marlin RC8 with Delta Auto Calibrate August 02, 2017 04:46AM |
Re: Marlin RC8 with Delta Auto Calibrate August 11, 2017 06:37AM |
Re: Marlin RC8 with Delta Auto Calibrate August 29, 2017 03:13PM |
Re: Marlin RC8 with Delta Auto Calibrate August 30, 2017 02:48AM |
Re: Marlin RC8 with Delta Auto Calibrate August 30, 2017 01:04PM |
Re: Marlin RC8 with Delta Auto Calibrate August 31, 2017 03:15AM |
Re: Marlin RC8 with Delta Auto Calibrate November 03, 2017 12:52PM |
Re: Marlin RC8 with Delta Auto Calibrate November 04, 2017 12:41AM |
Re: Marlin RC8 with Delta Auto Calibrate November 04, 2017 01:05AM |
Re: Marlin RC8 with Delta Auto Calibrate November 04, 2017 10:29AM |
Re: Marlin RC8 with Delta Auto Calibrate November 07, 2017 12:39AM |
