Re: Removing vertical lines on prints May 27, 2017 02:54PM |
Re: Removing vertical lines on prints May 27, 2017 07:25PM |
Re: Removing vertical lines on prints May 28, 2017 03:33PM |
Re: Removing vertical lines on prints May 29, 2017 08:07AM |
Re: Removing vertical lines on prints May 30, 2017 01:32PM |
Re: Removing vertical lines on prints May 30, 2017 01:44PM |
Re: Removing vertical lines on prints May 30, 2017 06:11PM |
Re: Removing vertical lines on prints May 31, 2017 11:29AM |
Re: Removing vertical lines on prints June 06, 2017 01:19PM |
Re: Removing vertical lines on prints June 06, 2017 09:53PM |
SJN
Strange. I just removed the chinese heatbreak, and 0.4mm nozzle, and installed original E3D parts instead......now I also get the wood grain texture in my pints.....could not replicate that before at any layer height with the old nozzle
Printed at 0.25mm 0.4nozzle
Re: Removing vertical lines on prints June 07, 2017 02:30AM |
Re: Removing vertical lines on prints June 07, 2017 02:36AM |
Re: Removing vertical lines on prints June 07, 2017 09:02AM |
Re: Removing vertical lines on prints June 07, 2017 11:04AM |
Re: Removing vertical lines on prints June 07, 2017 12:34PM |
Re: Removing vertical lines on prints July 09, 2017 04:15AM |
Re: Removing vertical lines on prints July 09, 2017 09:44AM |
Re: Removing vertical lines on prints July 09, 2017 11:14AM |
Re: Removing vertical lines on prints March 17, 2019 07:08PM |
Re: Removing vertical lines on prints April 08, 2019 10:29AM |
Re: Removing vertical lines on prints April 09, 2019 03:02AM |
Wibbles
The standard Sintron is quite an amazing piece of kit, the problem is that Delta's are, as I learned, an absolute pig to configure. I would guess that many think that as it is cheap, it doesn't print well due to cheap parts, so they keep buying more expensive 'upgrades'. The printer in standard form, as many will testify, is capable of some wondrous things. The issue is that whereas a Cartesian printer will print pretty well when not perfect, a Delta needs to be tweaked to perfection or it won't produce the goods.
Re: Removing vertical lines on prints April 09, 2019 05:26AM |
+1 This is a big one.Quote
dc42
So IMO, anyone looking for a low cost machine should avoid deltas.
I partially disagree here. The relationship between layer height and the patterns on the surfaces is clearly shown in this thread.Quote
dc42
No need for magic layers heights, 0.2mm works just fine.
Re: Removing vertical lines on prints May 25, 2019 05:51AM |
Re: Removing vertical lines on prints May 25, 2019 10:37AM |
Re: Removing vertical lines on prints May 26, 2019 12:12AM |
Re: Removing vertical lines on prints May 26, 2019 05:08AM |
Re: Removing vertical lines on prints November 07, 2019 01:38PM |
Re: Removing vertical lines on prints November 09, 2019 08:04PM |
