Causes of Layer shifts on a Delta? April 23, 2017 01:54PM |
Re: Causes of Layer shifts on a Delta? April 23, 2017 03:25PM |
Re: Causes of Layer shifts on a Delta? April 23, 2017 05:11PM |
Re: Causes of Layer shifts on a Delta? April 23, 2017 11:06PM |
Re: Causes of Layer shifts on a Delta? April 23, 2017 11:34PM |
Re: Causes of Layer shifts on a Delta? April 24, 2017 01:59AM |
Re: Causes of Layer shifts on a Delta? April 24, 2017 03:58AM |
Re: Causes of Layer shifts on a Delta? April 25, 2017 09:47AM |
Re: Causes of Layer shifts on a Delta? April 25, 2017 11:36AM |
Ace67aod
DC What firmware version is the duet in now? It has been a while i am sure there has been updates i should update out of good practice.
Re: Causes of Layer shifts on a Delta? April 27, 2017 02:07AM |
Re: Causes of Layer shifts on a Delta? April 27, 2017 02:19AM |
Re: Causes of Layer shifts on a Delta? April 27, 2017 10:04AM |
Re: Causes of Layer shifts on a Delta? April 28, 2017 08:21AM |
Ace67aod
i have a file name "Temp" on my desktop that i put the bossac .exe file in then i extracted all the contents of your most recent update RepRap Firmware-dev is the original file name as it was from the download. When attepting this i changed the firmware file name to RepRapFirmware-1.18.1 could this be the problem. (Basically i tried default didnt work i changed name and the command and still same error)
Both are in the same "Temp" folder
Let me know what you think i can try a few thing tonight.
THanks
Re: Causes of Layer shifts on a Delta? April 28, 2017 10:12AM |
Re: Causes of Layer shifts on a Delta? April 30, 2017 12:07AM |
Re: Causes of Layer shifts on a Delta? April 30, 2017 12:14AM |
Re: Causes of Layer shifts on a Delta? April 30, 2017 03:50AM |
