blocking and jamming problem when hot end on
May 12, 2017 03:21AM
Hi all, I have a Delta mini, mega+ramps 1.4 but I have a big problem, my delta is well calibrated but when I turn on the hot end the motors start to make micromovements and lot of noise.If I launch any kind of movement like "g28" , it fails, motors start blocking and jamming. If I turn off the hot end the situation returns perfect .. i do not understand, could it be a ground problem? Or burned ramps? Or arduin gone?
Re: blocking and jamming problem when hot end on
May 12, 2017 04:52AM
Check the wires to your heater cartridge. Ensure that they are not touching each other, or the metal heat block.
May 12, 2017 08:29AM
Many thanks for your reply, When I back home I Ensure that they are not touching...Hoping you are in true thumbs up i'm scared of change my electronic
