Filament Dump Start Script - Cura May 17, 2017 05:46PM |
Re: Filament Dump Start Script - Cura May 18, 2017 02:19AM |
Re: Filament Dump Start Script - Cura May 18, 2017 12:20PM |
o_lampe
After M83 and all the purge stuff, you have to send M82 to tell the extruder to work in absolute mode again.
I'm also missing a M109 S command to heat up the hotend before purging, or is it a syringe extruding cold pudding?
Re: Filament Dump Start Script - Cura May 18, 2017 01:07PM |
Re: Filament Dump Start Script - Cura May 18, 2017 01:19PM |
Re: Filament Dump Start Script - Cura May 18, 2017 04:40PM |
Re: Filament Dump Start Script - Cura May 20, 2017 03:03PM |
Re: Filament Dump Start Script - Cura May 21, 2017 03:44AM |
M302 S1 ; Enables Extruder control M83 ; Sets Extruder to relative mode G28 ; home all G1 X-104 Y-60 Z30 F6000 ; move to purge zone G92 E0 ; resets extruder G1 E15 F100 ; extrude 15mm G92 E0 ; resets extruder G1 E-2 F600 ; retracts 2mm G92 E0 ; resets extruder
Re: Filament Dump Start Script - Cura May 21, 2017 10:51AM |
;FLAVOR:Repetier ;TIME:997 ;Generated with Cura_SteamEngine 2.5.0 M109 S0 M302 S1 ; Enables Extruder control M83 ; Sets Extruder to relative mode G28 ; home all G1 X-104 Y-60 Z30 F6000 ; move to purge zone G92 E0 ; resets extruder G1 E15 F100 ; extrude 15mm G92 E0 ; resets extruder G1 E-2 F600 ; retracts 2mm G92 E0 ; resets extruder ;LAYER_COUNT:100 ;LAYER:0 M107 G0 F4500 X9.991 Y-14.24 Z0.28 ;TYPE : SKIRT G1 F1800 X10.573 Y-14.2 E0.03396 G1 X11.143 Y-14.081 E0.06785 G1 X11.692 Y-13.885 E0.10178 G1 X12.209 Y-13.616 E0.1357 G1 X12.684 Y-13.278 E0.16963
;FLAVOR:Repetier ;TIME:997 ;Generated with Cura_SteamEngine 2.5.0 M109 S0 M302 S1 ; Enables Extruder control M83 ; Sets Extruder to relative mode G28 ; home all G1 X-104 Y-60 Z30 F6000 ; move to purge zone G92 E0 ; resets extruder G1 E15 F100 ; extrude 15mm G92 E0 ; resets extruder G1 E-2 F600 ; retracts 2mm G92 E0 ; resets extruder M82 ; Sets Extruder to absolute mode G92 E0 ; resets extruder ;LAYER_COUNT:100 ;LAYER:0 M107 G0 F4500 X9.991 Y-14.24 Z0.28 ;TYPE : SKIRT G1 F1800 X10.573 Y-14.2 E0.03396 G1 X11.143 Y-14.081 E0.06785 G1 X11.692 Y-13.885 E0.10178 G1 X12.209 Y-13.616 E0.1357 G1 X12.684 Y-13.278 E0.16963
;FLAVOR:Repetier ;TIME:997 ;Generated with Cura_SteamEngine 2.5.0 M109 S0 M302 S1 ; Enables Extruder control M83 ; Sets Extruder to relative mode G28 ; home all G1 X-104 Y-60 Z30 F6000 ; move to purge zone G92 E0 ; resets extruder G1 E15 F100 ; extrude 15mm G92 E0 ; resets extruder G1 E-2 F600 ; retracts 2mm G92 E0 ; resets extruder M83 ; Sets Extruder to absolute mode G92 E0 ; resets extruder M302 S1 ; Enables Extruder control G92 E0 ; resets extruder ;LAYER_COUNT:100 ;LAYER:0 M107 G0 F4500 X9.991 Y-14.24 Z0.28 ;TYPE : SKIRT G1 F1800 X10.573 Y-14.2 E0.03396 G1 X11.143 Y-14.081 E0.06785 G1 X11.692 Y-13.885 E0.10178 G1 X12.209 Y-13.616 E0.1357 G1 X12.684 Y-13.278 E0.16963
Re: Filament Dump Start Script - Cura May 21, 2017 04:15PM |
G28 ; home all G1 X-104 Y-60 Z30 F6000 ; move to purge zone G1 E15 F100 ; extrude 15mm G1 E-2 F600 ; retracts 2mm G92 E0 ; resets extruder
G28 ; home all M83 ; relative extrusion G1 X-104 Y-60 Z30 F6000 ; move to purge zone G1 E15 F100 ; extrude 15mm G1 E-2 F600 ; retracts 2mm G92 E0 ; resets extruder M82 ; absolute extrusion
Re: Filament Dump Start Script - Cura May 22, 2017 01:49AM |
Re: Filament Dump Start Script - Cura May 22, 2017 03:21AM |
Re: Filament Dump Start Script - Cura May 22, 2017 04:12AM |
Mils24
Hello DjDemonD
Unless I start my script with
M302 S1 M83 etc. etc.
My extruder motor will not work at all. However when I do the movement of the print file is not right.
Re: Filament Dump Start Script - Cura June 02, 2017 03:35PM |
M302 S1 M83 G1 E15 Z150
M302 S1 M83 G1 E15 Z150 G92 E0 M82
Re: Filament Dump Start Script - Cura June 02, 2017 06:04PM |
Re: Filament Dump Start Script - Cura June 02, 2017 06:30PM |
;FLAVOR:Repetier ;TIME:927 ;Generated with Cura_SteamEngine 2.5.0 M109 S0 M302 S1 M83; Sets Extruder to relative mode G28 ; home all G1 X-104 Y-60 Z30 F6000 ; move to purge G0 E15 F150 ; extrude 15mm G0 E-2 F600 ; retracts 2mm G92 E0 ; resets extruder ;LAYER_COUNT:100 ;LAYER:0 M107 G0 F4500 X9.991 Y-14.24 Z0.28 ;TYPEKIRT G1 F1800 X10.573 Y-14.2 E0.03396 G1 X11.143 Y-14.081 E0.06785 G1 X11.692 Y-13.885 E0.10178 G1 X12.209 Y-13.616 E0.1357 G1 X12.684 Y-13.278 E0.16963 G1 X13.108 Y-12.879 E0.20352 G1 X13.474 Y-12.425 E0.23746 G1 X13.774 Y-11.926 E0.27135 G1 X14.004 Y-11.39 E0.3053 G1 X14.158 Y-10.828 E0.33922 G1 X14.241 Y-9.99 E0.38823 G1 X14.241 Y9.991 E1.55123 G1 X14.201 Y10.572 E1.58513 G1 X14.082 Y11.143 E1.61908 G1 X13.886 Y11.692 E1.65301 G1 X13.617 Y12.208 E1.68688 G1 X13.279 Y12.684 E1.72086 G1 X12.88 Y13.108 E1.75475 G1 X12.426 Y13.474 E1.78869 G1 X11.927 Y13.774 E1.82258 G1 X11.391 Y14.004 E1.85653 G1 X10.829 Y14.158 E1.89045 G1 X9.991 Y14.241 E1.93946 G1 X-9.991 Y14.241 E3.10252 G1 X-10.572 Y14.201 E3.13641 G1 X-11.143 Y14.082 E3.17036 G1 X-11.692 Y13.886 E3.20429 G1 X-12.208 Y13.617 E3.23816 G1 X-12.684 Y13.279 E3.27214 G1 X-13.108 Y12.88 E3.30603 G1 X-13.474 Y12.426 E3.33997 G1 X-13.774 Y11.927 E3.37386 G1 X-14.004 Y11.391 E3.40781 G1 X-14.158 Y10.829 E3.44173 G1 X-14.241 Y9.991 E3.49074 G1 X-14.241 Y-9.991 E4.6538 G1 X-14.201 Y-10.572 E4.6877 G1 X-14.082 Y-11.143 E4.72165 G1 X-13.886 Y-11.692 E4.75558 G1 X-13.617 Y-12.208 E4.78945 G1 X-13.279 Y-12.684 E4.82343 G1 X-12.88 Y-13.108 E4.85732 G1 X-12.426 Y-13.474 E4.89126 G1 X-11.927 Y-13.774 E4.92515 G1 X-11.391 Y-14.004 E4.9591 G1 X-10.829 Y-14.158 E4.99301 G1 X-9.991 Y-14.241 E5.04203 G1 X9.991 Y-14.24 E6.20509 G0 F4500 X9.991 Y-13.74 G1 F1800 X10.537 Y-13.7 E6.23695 G1 X11.071 Y-13.581 E6.2688 G1 X11.583 Y-13.385 E6.30071 G1 X12.06 Y-13.118 E6.33252 G1 X12.493 Y-12.783 E6.36439 G1 X12.873 Y-12.389 E6.39625 G1 X13.192 Y-11.944 E6.42812 G1 X13.442 Y-11.457 E6.45998 G1 X13.619 Y-10.939 E6.49184 G1 X13.718 Y-10.401 E6.52368 G1 X13.741 Y-9.99 E6.54764 G1 X13.741 Y9.991 E7.71064 G1 X13.701 Y10.537 E7.74251 G1 X13.582 Y11.071 E7.77435 G1 X13.387 Y11.582 E7.80619 G1 X13.119 Y12.06 E7.83808 G1 X12.784 Y12.493 E7.86995 G1 X12.39 Y12.873 E7.90181 G1 X11.945 Y13.192 E7.93368 G1 X11.458 Y13.442 E7.96554 G1 X10.94 Y13.619 E7.9974 G1 X10.402 Y13.718 E8.02924 G1 X9.991 Y13.741 E8.0532 G1 X-9.991 Y13.741 E9.21626 G1 X-10.537 Y13.701 E9.24812 G1 X-11.071 Y13.582 E9.27997 G1 X-11.582 Y13.387 E9.3118 G1 X-12.06 Y13.119 E9.3437 G1 X-12.493 Y12.784 E9.37557 G1 X-12.873 Y12.39 E9.40743 G1 X-13.192 Y11.945 E9.4393 G1 X-13.442 Y11.458 E9.47116 G1 X-13.619 Y10.94 E9.50302 G1 X-13.718 Y10.402 E9.53486 G1 X-13.741 Y9.991 E9.55882 G1 X-13.741 Y-9.991 E10.72188 G1 X-13.701 Y-10.537 E10.75374 G1 X-13.582 Y-11.071 E10.78559 G1 X-13.387 Y-11.582 E10.81742 G1 X-13.119 Y-12.06 E10.84932 G1 X-12.784 Y-12.493 E10.88118 G1 X-12.39 Y-12.873 E10.91304 G1 X-11.945 Y-13.192 E10.94491 G1 X-11.458 Y-13.442 E10.97678 G1 X-10.94 Y-13.619 E11.00864 G1 X-10.402 Y-13.718 E11.04048 G1 X-9.991 Y-13.741 E11.06444 G1 X9.991 Y-13.74 E12.22749 G0 F4500 X9.991 Y-13.24 G1 F1800 X10.499 Y-13.2 E12.25715 G1 X10.995 Y-13.081 E12.28684 G1 X11.465 Y-12.886 E12.31646 G1 X11.9 Y-12.62 E12.34614 G1 X12.288 Y-12.29 E12.37579 G1 X12.619 Y-11.902 E12.40547 G1 X12.885 Y-11.468 E12.4351 G1 X13.081 Y-10.998 E12.46474 G1 X13.2 Y-10.502 E12.49443 G1 X13.241 Y-9.99 E12.52432 G1 X13.241 Y9.991 E13.68732 G1 X13.201 Y10.499 E13.71698 G1 X13.082 Y10.994 E13.74662 G1 X12.887 Y11.465 E13.77629 G1 X12.621 Y11.9 E13.80596 G1 X12.291 Y12.287 E13.83557 G1 X11.904 Y12.619 E13.86525 G1 X11.469 Y12.885 E13.89492 G1 X10.999 Y13.081 E13.92456 G1 X10.504 Y13.2 E13.9542 G1 X9.991 Y13.241 E13.98415 G1 X-9.991 Y13.241 E15.14721 G1 X-10.499 Y13.201 E15.17687 G1 X-10.994 Y13.082 E15.2065 G1 X-11.465 Y12.887 E15.23617 G1 X-11.9 Y12.621 E15.26585 G1 X-12.287 Y12.291 E15.29545 G1 X-12.619 Y11.904 E15.32513 G1 X-12.885 Y11.469 E15.35481 G1 X-13.081 Y10.999 E15.38445 G1 X-13.2 Y10.504 E15.41408 G1 X-13.241 Y9.991 E15.44404 G1 X-13.241 Y-9.991 E16.60709 G1 X-13.201 Y-10.499 E16.63675 G1 X-13.082 Y-10.994 E16.66638 G1 X-12.887 Y-11.465 E16.69606 G1 X-12.621 Y-11.9 E16.72573 G1 X-12.291 Y-12.287 E16.75534 G1 X-11.904 Y-12.619 E16.78502 G1 X-11.469 Y-12.885 E16.81469 G1 X-10.999 Y-13.081 E16.84433 G1 X-10.504 Y-13.2 E16.87397 G1 X-9.991 Y-13.241 E16.90392 G1 X9.991 Y-13.24 E18.06698 G1 F2400 E13.56698 G1 Z0.68 G0 F4500 X9.25 Y-9.25 Z0.68 ;TYPE:WALL-INNER G1 Z0.28 G1 F2400 E18.06698 G1 F1800 X9.25 Y9.25 E19.14403 G1 X-9.25 Y9.25 E20.22082 G1 X-9.25 Y-9.25 E21.29762 G1 X9.25 Y-9.25 E22.37442 G0 F4500 X9.18 Y-9.18 G0 X9.18 Y9.18 G0 X9.75 Y9.75 ;TYPE:WALL-OUTER G1 F1800 X-9.75 Y9.75 E23.50942 G1 X-9.75 Y-9.75 E24.64442 G1 X9.75 Y-9.75 E25.77942 G1 X9.75 Y9.75 E26.91442 G0 F4500 X9.5 Y9.75 G0 X9.024 Y9.024 ;TYPEKIN G1 F1800 X-9.024 Y-9.024 E28.40004 G1 X-9.112 Y-9.112 G0 F4500 X-9.024 Y-8.317 G1 F1800 X8.317 Y9.024 E29.82746 G1 X8.405 Y9.112 G0 F4500 X7.61 Y9.024 G1 F1800 X-9.024 Y-7.61 E31.19668 G1 X-9.112 Y-7.698 G0 F4500 X-9.024 Y-6.903 G1 F1800 X6.903 Y9.024 E32.5077 G1 X6.991 Y9.112 G0 F4500 X6.196 Y9.024 G1 F1800 X-9.024 Y-6.196 E33.76053 G1 X-9.112 Y-6.284 G0 F4500 X-9.024 Y-5.489 G1 F1800 X5.489 Y9.024 E34.95517 G1 X5.577 Y9.112 G0 F4500 X4.782 Y9.024 G1 F1800 X-9.024 Y-4.782 E36.0916 G1 X-9.112 Y-4.87 G0 F4500 X-9.024 Y-4.075 G1 F1800 X4.075 Y9.024 E37.16984 G1 X4.163 Y9.112 G0 F4500 X3.367 Y9.024 G1 F1800 X-9.024 Y-3.367 E38.1898 G1 X-9.112 Y-3.455 G0 F4500 X-9.024 Y-2.66 G1 F1800 X2.66 Y9.024 E39.15157 G1 X2.748 Y9.112 G0 F4500 X1.953 Y9.024 G1 F1800 X-9.024 Y-1.953 E40.05513 G1 X-9.112 Y-2.041 G0 F4500 X-9.024 Y-1.246 G1 F1800 X1.246 Y9.024 E40.9005 G1 X1.334 Y9.112 G0 F4500 X0.539 Y9.024 G1 F1800 X-9.024 Y-.539 E41.68768 G1 X-9.112 Y-.627 G0 F4500 X-9.024 Y0.167 G1 F1800 X-.167 Y9.024 E42.41674 G1 X-0.079 Y9.112 G0 F4500 X-.874 Y9.024 G1 F1800 X-9.024 Y0.874 E43.0876 G1 X-9.112 Y0.786 G0 F4500 X-9.024 Y1.581 G1 F1800 X-1.581 Y9.024 E43.70027 G1 X-1.493 Y9.112 G0 F4500 X-2.288 Y9.024 G1 F1800 X-9.024 Y2.288 E44.25474 G1 X-9.112 Y2.2 G0 F4500 X-9.024 Y2.996 G1 F1800 X-2.996 Y9.024 E44.75094 G1 X-2.908 Y9.112 G0 F4500 X-3.703 Y9.024 G1 F1800 X-9.024 Y3.703 E45.18893 G1 X-9.112 Y3.615 G0 F4500 X-9.024 Y4.41 G1 F1800 X-4.41 Y9.024 E45.56873 G1 X-4.322 Y9.112 G0 F4500 X-5.117 Y9.024 G1 F1800 X-9.024 Y5.117 E45.89034 G1 X-9.112 Y5.029 G0 F4500 X-9.024 Y5.824 G1 F1800 X-5.824 Y9.024 E46.15374 G1 X-5.736 Y9.112 G0 F4500 X-6.531 Y9.024 G1 F1800 X-9.024 Y6.531 E46.35895 G1 X-9.112 Y6.443 G0 F4500 X-9.024 Y7.238 G1 F1800 X-7.238 Y9.024 E46.50597 G1 X-7.15 Y9.112 G0 F4500 X-7.945 Y9.024 G1 F1800 X-9.024 Y7.945 E46.59478 G1 X-9.112 Y7.857 G0 F4500 X-9.024 Y8.652 G1 F1800 X-8.652 Y9.024 E46.6254 G0 F4500 X9.024 Y8.317 G1 F1800 X-8.317 Y-9.024 E48.05282 G1 X-8.405 Y-9.112 G0 F4500 X-7.61 Y-9.024 G1 F1800 X9.024 Y7.61 E49.42204 G1 X9.112 Y7.698 G0 F4500 X9.024 Y6.903 G1 F1800 X-6.903 Y-9.024 E50.73307 G1 X-6.991 Y-9.112 G0 F4500 X-6.196 Y-9.024 G1 F1800 X9.024 Y6.196 E51.9859 G1 X9.112 Y6.284 G0 F4500 X9.024 Y5.489 G1 F1800 X-5.489 Y-9.024 E53.18053 G1 X-5.577 Y-9.112 G0 F4500 X-4.782 Y-9.024 G1 F1800 X9.024 Y4.782 E54.31697 G1 X9.112 Y4.87 G0 F4500 X9.024 Y4.075 G1 F1800 X-4.075 Y-9.024 E55.39521 G1 X-4.163 Y-9.112 G0 F4500 X-3.367 Y-9.024 G1 F1800 X9.024 Y3.367 E56.41517 G1 X9.112 Y3.455 G0 F4500 X9.024 Y2.66 G1 F1800 X-2.66 Y-9.024 E57.37693 G1 X-2.748 Y-9.112 G0 F4500 X-1.953 Y-9.024 G1 F1800 X9.024 Y1.953 E58.2805 G1 X9.112 Y2.041 G0 F4500 X9.024 Y1.246 G1 F1800 X-1.246 Y-9.024 E59.12587 G1 X-1.334 Y-9.112 G0 F4500 X-.539 Y-9.024 G1 F1800 X9.024 Y0.539 E59.91304 G1 X9.112 Y0.627 G0 F4500 X9.024 Y-.167 G1 F1800 X0.167 Y-9.024 E60.64211 G1 X0.079 Y-9.112 G0 F4500 X0.874 Y-9.024 G1 F1800 X9.024 Y-.874 E61.31297 G1 X9.112 Y-.786 G0 F4500 X9.024 Y-1.581 G1 F1800 X1.581 Y-9.024 E61.92564 G1 X1.493 Y-9.112 G0 F4500 X2.288 Y-9.024 G1 F1800 X9.024 Y-2.288 E62.48011 G1 X9.112 Y-2.2 G0 F4500 X9.024 Y-2.996 G1 F1800 X2.996 Y-9.024 E62.9763 G1 X2.908 Y-9.112 G0 F4500 X3.703 Y-9.024 G1 F1800 X9.024 Y-3.703 E63.4143 G1 X9.112 Y-3.615 G0 F4500 X9.024 Y-4.41 G1 F1800 X4.41 Y-9.024 E63.7941 G1 X4.322 Y-9.112 G0 F4500 X5.117 Y-9.024 G1 F1800 X9.024 Y-5.117 E64.1157 G1 X9.112 Y-5.029 G0 F4500 X9.024 Y-5.824 G1 F1800 X5.824 Y-9.024 E64.37911 G1 X5.736 Y-9.112 G0 F4500 X6.531 Y-9.024 G1 F1800 X9.024 Y-6.531 E64.58432 G1 X9.112 Y-6.443 G0 F4500 X9.024 Y-7.238 G1 F1800 X7.238 Y-9.024 E64.73133 G1 X7.15 Y-9.112 G0 F4500 X7.945 Y-9.024 G1 F1800 X9.024 Y-7.945 E64.82015 G1 X9.112 Y-7.857 G0 F4500 X9.024 Y-8.652 G1 F1800 X8.652 Y-9.024 E64.85077 G0 F4500 X8.652 Y-8.75 G0 X9.18 Y9.18 G0 X9.25 Y9.25 ;TIME_ELAPSED:40.277812 ;LAYER:1 M106 S255 G0 F6750 X9.25 Y9.25 Z0.48 ;TYPE:WALL-INNER G1 F2700 X-9.25 Y9.25 E65.61991 G1 X-9.25 Y-9.25 E66.38905 G1 X9.25 Y-9.25 E67.15819 G1 X9.25 Y9.25 E67.92733 G0 F6750 X9.75 Y9.75 ;TYPE:WALL-OUTER G1 F1800 X-9.75 Y9.75 E68.73805 G1 X-9.75 Y-9.75 E69.54876 G1 X9.75 Y-9.75 E70.35948 G1 X9.75 Y9.75 E71.1702 G0 F6750 X9.5 Y9.75 G0 X8.652 Y9.024 ;TYPEKIN G1 F1800 X9.024 Y8.652 E71.19207 G0 F6750 X9.024 Y7.945 G1 F1800 X7.945 Y9.024 E71.25551 G1 X7.857 Y9.112 G0 F6750 X7.238 Y9.024 G1 F1800 X9.024 Y7.238 E71.36052 G1 X9.112 Y7.15 G0 F6750 X9.024 Y6.531 G1 F1800 X6.531 Y9.024 E71.5071 G1 X6.443 Y9.112 G0 F6750 X5.824 Y9.024 G1 F1800 X9.024 Y5.824 E71.69525 G1 X9.112 Y5.736 G0 F6750 X9.024 Y5.117 G1 F1800 X5.117 Y9.024 E71.92496 G1 X5.029 Y9.112 G0 F6750 X4.41 Y9.024 G1 F1800 X9.024 Y4.41 E72.19625 G1 X9.112 Y4.322 G0 F6750 X9.024 Y3.703 G1 F1800 X3.703 Y9.024 E72.5091 G1 X3.615 Y9.112 G0 F6750 X2.996 Y9.024 G1 F1800 X9.024 Y2.996 E72.86353 G1 X9.112 Y2.908 G0 F6750 X9.024 Y2.288 G1 F1800 X2.288 Y9.024 E73.25958 G1 X2.2 Y9.112 G0 F6750 X1.581 Y9.024 G1 F1800 X9.024 Y1.581 E73.6972 G1 X9.112 Y1.493 G0 F6750 X9.024 Y0.874 G1 F1800 X0.874 Y9.024 E74.17639 G1 X0.786 Y9.112 G0 F6750 X0.167 Y9.024 G1 F1800 X9.024 Y0.167 E74.69714 G1 X9.112 Y0.079 G0 F6750 X9.024 Y-.539 G1 F1800 X-.539 Y9.024 E75.25941 G1 X-.627 Y9.112 G0 F6750 X-1.246 Y9.024 G1 F1800 X9.024 Y-1.246 E75.86325 G1 X9.112 Y-1.334 G0 F6750 X9.024 Y-1.953 G1 F1800 X-1.953 Y9.024 E76.50865 G1 X-2.041 Y9.112 G0 F6750 X-2.66 Y9.024 G1 F1800 X9.024 Y-2.66 E77.19563 G1 X9.112 Y-2.748 G0 F6750 X9.024 Y-3.367 G1 F1800 X-3.367 Y9.024 E77.92417 G1 X-3.455 Y9.112 G0 F6750 X-4.075 Y9.024 G1 F1800 X9.024 Y-4.075 E78.69434 G1 X9.112 Y-4.163 G0 F6750 X9.024 Y-4.782 G1 F1800 X-4.782 Y9.024 E79.50608 G1 X-4.87 Y9.112 G0 F6750 X-5.489 Y9.024 G1 F1800 X9.024 Y-5.489 E80.35939 G1 X9.112 Y-5.577 G0 F6750 X9.024 Y-6.196 G1 F1800 X-6.196 Y9.024 E81.25427 G1 X-6.284 Y9.112 G0 F6750 X-6.903 Y9.024 G1 F1800 X9.024 Y-6.903 E82.19071 G1 X9.112 Y-6.991 G0 F6750 X9.024 Y-7.61 G1 F1800 X-7.61 Y9.024 E83.16873 G1 X-7.698 Y9.112 G0 F6750 X-8.317 Y9.024 G1 F1800 X9.024 Y-8.317 E84.18831 G1 X9.112 Y-8.405 G0 F6750 X9.024 Y-9.024 G1 F1800 X-9.024 Y9.024 E85.24947 G1 X-9.112 Y9.112 G0 F6750 X-9.024 Y8.317 G1 F1800 X8.317 Y-9.024 E86.26905 G1 X8.405 Y-9.112 G0 F6750 X7.61 Y-9.024 G1 F1800 X-9.024 Y7.61 E87.24707 G1 X-9.112 Y7.698 G0 F6750 X-9.024 Y6.903 G1 F1800 X6.903 Y-9.024 E88.18351 G1 X6.991 Y-9.112 G0 F6750 X6.196 Y-9.024 G1 F1800 X-9.024 Y6.196 E89.07839 G1 X-9.112 Y6.284 G0 F6750 X-9.024 Y5.489 G1 F1800 X5.489 Y-9.024 E89.9317 G1 X5.577 Y-9.112 G0 F6750 X4.782 Y-9.024 G1 F1800 X-9.024 Y4.782 E90.74344 G1 X-9.112 Y4.87 G0 F6750 X-9.024 Y4.075 G1 F1800 X4.075 Y-9.024 E91.51361 G1 X4.163 Y-9.112 G0 F6750 X3.367 Y-9.024 G1 F1800 X-9.024 Y3.367 E92.24215 G1 X-9.112 Y3.455 G0 F6750 X-9.024 Y2.66 G1 F1800 X2.66 Y-9.024 E92.92913 G1 X2.748 Y-9.112 G0 F6750 X1.953 Y-9.024 G1 F1800 X-9.024 Y1.953 E93.57453 G1 X-9.112 Y2.041 G0 F6750 X-9.024 Y1.246 G1 F1800 X1.246 Y-9.024 E94.17837 G1 X1.334 Y-9.112 G0 F6750 X0.539 Y-9.024 G1 F1800 X-9.024 Y0.539 E94.74064 G1 X-9.112 Y0.627 G0 F6750 X-9.024 Y-.167 G1 F1800 X-.167 Y-9.024 E95.2614 G1 X-0.079 Y-9.112 G0 F6750 X-.874 Y-9.024 G1 F1800 X-9.024 Y-.874 E95.74059 G1 X-9.112 Y-.786 G0 F6750 X-9.024 Y-1.581 G1 F1800 X-1.581 Y-9.024 E96.17821 G1 X-1.493 Y-9.112 G0 F6750 X-2.288 Y-9.024 G1 F1800 X-9.024 Y-2.288 E96.57426 G1 X-9.112 Y-2.2 G0 F6750 X-9.024 Y-2.996 G1 F1800 X-2.996 Y-9.024 E96.92868 G1 X-2.908 Y-9.112 G0 F6750 X-3.703 Y-9.024 G1 F1800 X-9.024 Y-3.703 E97.24153 G1 X-9.112 Y-3.615 G0 F6750 X-9.024 Y-4.41 G1 F1800 X-4.41 Y-9.024 E97.51282 G1 X-4.322 Y-9.112 G0 F6750 X-5.117 Y-9.024 G1 F1800 X-9.024 Y-5.117 E97.74254 G1 X-9.112 Y-5.029 G0 F6750 X-9.024 Y-5.824 G1 F1800 X-5.824 Y-9.024 E97.93068 G1 X-5.736 Y-9.112 G0 F6750 X-6.531 Y-9.024 G1 F1800 X-9.024 Y-6.531 E98.07726 G1 X-9.112 Y-6.443 G0 F6750 X-9.024 Y-7.238 G1 F1800 X-7.238 Y-9.024 E98.18227 G1 X-7.15 Y-9.112 G0 F6750 X-7.945 Y-9.024 G1 F1800 X-9.024 Y-7.945 E98.24571 G1 X-9.112 Y-7.857 G0 F6750 X-9.024 Y-8.652 G1 F1800 X-8.652 Y-9.024 E98.26759 G0 F6750 X-8.652 Y-8.75 G0 X9.18 Y9.18 G0 X9.25 Y9.25 ;TIME_ELAPSED:68.079823 ;LAYER:2 G0 F9000 X9.25 Y9.25 Z0.68 ;TYPE:WALL-INNER G1 F3600 X-9.25 Y9.25 E99.03673 G1 X-9.25 Y-9.25 E99.80587 G1 X9.25 Y-9.25 E100.57501 G1 X9.25 Y9.25 E101.34415 G0 F9000 X9.75 Y9.75 ;TYPE:WALL-OUTER G1 F1800 X-9.75 Y9.75 E102.15486 G1 X-9.75 Y-9.75 E102.96558 G1 X9.75 Y-9.75 E103.7763 G1 X9.75 Y9.75 E104.58701 G0 F9000 X9.5 Y9.75 G0 X9.024 Y9.024 ;TYPEKIN G1 F1800 X-9.024 Y-9.024 E105.64816 G1 X-9.112 Y-9.112 G0 F9000 X-9.024 Y-8.317 G1 F1800 X8.317 Y9.024 E106.66775 G1 X8.405 Y9.112 G0 F9000 X7.61 Y9.024 G1 F1800 X-9.024 Y-7.61 E107.64576 G1 X-9.112 Y-7.698 G0 F9000 X-9.024 Y-6.903 G1 F1800 X6.903 Y9.024 E108.58221 G1 X6.991 Y9.112 G0 F9000 X6.196 Y9.024 G1 F1800 X-9.024 Y-6.196 E109.47709 G1 X-9.112 Y-6.284 G0 F9000 X-9.024 Y-5.489 G1 F1800 X5.489 Y9.024 E110.3304 G1 X5.577 Y9.112 G0 F9000 X4.782 Y9.024 G1 F1800 X-9.024 Y-4.782 E111.14214 G1 X-9.112 Y-4.87 G0 F9000 X-9.024 Y-4.075 G1 F1800 X4.075 Y9.024 E111.91231 G1 X4.163 Y9.112 G0 F9000 X3.367 Y9.024 G1 F1800 X-9.024 Y-3.367 E112.64085 G1 X-9.112 Y-3.455 G0 F9000 X-9.024 Y-2.66 G1 F1800 X2.66 Y9.024 E113.32783 G1 X2.748 Y9.112 G0 F9000 X1.953 Y9.024 G1 F1800 X-9.024 Y-1.953 E113.97323 G1 X-9.112 Y-2.041 G0 F9000 X-9.024 Y-1.246 G1 F1800 X1.246 Y9.024 E114.57707 G1 X1.334 Y9.112 G0 F9000 X0.539 Y9.024 G1 F1800 X-9.024 Y-.539 E115.13934 G1 X-9.112 Y-.627 G0 F9000 X-9.024 Y0.167 G1 F1800 X-.167 Y9.024 E115.66009 G1 X-0.079 Y9.112 G0 F9000 X-.874 Y9.024 G1 F1800 X-9.024 Y0.874 E116.13928 G1 X-9.112 Y0.786 G0 F9000 X-9.024 Y1.581 G1 F1800 X-1.581 Y9.024 E116.5769 G1 X-1.493 Y9.112 G0 F9000 X-2.288 Y9.024 G1 F1800 X-9.024 Y2.288 E116.97295 G1 X-9.112 Y2.2 G0 F9000 X-9.024 Y2.996 G1 F1800 X-2.996 Y9.024 E117.32738 G1 X-2.908 Y9.112 G0 F9000 X-3.703 Y9.024 G1 F1800 X-9.024 Y3.703 E117.64023 G1 X-9.112 Y3.615 G0 F9000 X-9.024 Y4.41 G1 F1800 X-4.41 Y9.024 E117.91152 G1 X-4.322 Y9.112 G0 F9000 X-5.117 Y9.024 G1 F1800 X-9.024 Y5.117 E118.14123 G1 X-9.112 Y5.029 G0 F9000 X-9.024 Y5.824 G1 F1800 X-5.824 Y9.024 E118.32938 G1 X-5.736 Y9.112 G0 F9000 X-6.531 Y9.024 G1 F1800 X-9.024 Y6.531 E118.47596 G1 X-9.112 Y6.443 G0 F9000 X-9.024 Y7.238 G1 F1800 X-7.238 Y9.024 E118.58097 G1 X-7.15 Y9.112 G0 F9000 X-7.945 Y9.024 G1 F1800 X-9.024 Y7.945 E118.64441 G1 X-9.112 Y7.857 G0 F9000 X-9.024 Y8.652 G1 F1800 X-8.652 Y9.024 E118.66628 G0 F9000 X9.024 Y8.317 G1 F1800 X-8.317 Y-9.024 E119.68587 G1 X-8.405 Y-9.112 G0 F9000 X-7.61 Y-9.024 G1 F1800 X9.024 Y7.61 E120.66388 G1 X9.112 Y7.698 G0 F9000 X9.024 Y6.903 G1 F1800 X-6.903 Y-9.024 E121.60033 G1 X-6.991 Y-9.112 G0 F9000 X-6.196 Y-9.024 G1 F1800 X9.024 Y6.196 E122.49521 G1 X9.112 Y6.284 G0 F9000 X9.024 Y5.489 G1 F1800 X-5.489 Y-9.024 E123.34852 G1 X-5.577 Y-9.112 G0 F9000 X-4.782 Y-9.024 G1 F1800 X9.024 Y4.782 E124.16026 G1 X9.112 Y4.87 G0 F9000 X9.024 Y4.075 G1 F1800 X-4.075 Y-9.024 E124.93043 G1 X-4.163 Y-9.112 G0 F9000 X-3.367 Y-9.024 G1 F1800 X9.024 Y3.367 E125.65897 G1 X9.112 Y3.455 G0 F9000 X9.024 Y2.66 G1 F1800 X-2.66 Y-9.024 E126.34594 G1 X-2.748 Y-9.112 G0 F9000 X-1.953 Y-9.024 G1 F1800 X9.024 Y1.953 E126.99135 G1 X9.112 Y2.041 G0 F9000 X9.024 Y1.246 G1 F1800 X-1.246 Y-9.024 E127.59519 G1 X-1.334 Y-9.112 G0 F9000 X-.539 Y-9.024 G1 F1800 X9.024 Y0.539 E128.15745 G1 X9.112 Y0.627 G0 F9000 X9.024 Y-.167 G1 F1800 X0.167 Y-9.024 E128.67821 G1 X0.079 Y-9.112 G0 F9000 X0.874 Y-9.024 G1 F1800 X9.024 Y-.874 E129.1574 G1 X9.112 Y-.786 G0 F9000 X9.024 Y-1.581 G1 F1800 X1.581 Y-9.024 E129.59502 G1 X1.493 Y-9.112 G0 F9000 X2.288 Y-9.024 G1 F1800 X9.024 Y-2.288 E129.99107 G1 X9.112 Y-2.2 G0 F9000 X9.024 Y-2.996 G1 F1800 X2.996 Y-9.024 E130.34549 G1 X2.908 Y-9.112 G0 F9000 X3.703 Y-9.024 G1 F1800 X9.024 Y-3.703 E130.65835 G1 X9.112 Y-3.615 G0 F9000 X9.024 Y-4.41 G1 F1800 X4.41 Y-9.024 E130.92963 G1 X4.322 Y-9.112 G0 F9000 X5.117 Y-9.024 G1 F1800 X9.024 Y-5.117 E131.15935 G1 X9.112 Y-5.029 G0 F9000 X9.024 Y-5.824 G1 F1800 X5.824 Y-9.024 E131.3475 G1 X5.736 Y-9.112 G0 F9000 X6.531 Y-9.024 G1 F1800 X9.024 Y-6.531 E131.49408 G1 X9.112 Y-6.443 G0 F9000 X9.024 Y-7.238 G1 F1800 X7.238 Y-9.024 E131.59909 G1 X7.15 Y-9.112 G0 F9000 X7.945 Y-9.024 G1 F1800 X9.024 Y-7.945 E131.66253 G1 X9.112 Y-7.857 G0 F9000 X9.024 Y-8.652 G1 F1800 X8.652 Y-9.024 E131.6844 G0 F9000 X8.652 Y-8.75 G0 X9.18 Y9.18 G0 X9.25 Y9.25 ;TIME_ELAPSED:95.630580 ;LAYER:3 G0 X9.25 Y9.25 Z0.88 ;TYPE:WALL-INNER G1 F3600 X-9.25 Y9.25 E132.45354 G1 X-9.25 Y-9.25 E133.22268 G1 X9.25 Y-9.25 E133.99182 G1 X9.25 Y9.25 E134.76096 G0 F9000 X9.75 Y9.75 ;TYPE:WALL-OUTER G1 F1800 X-9.75 Y9.75 E135.57168 G1 X-9.75 Y-9.75 E136.3824 G1 X9.75 Y-9.75 E137.19311 G1 X9.75 Y9.75 E138.00383 G0 F9000 X9.5 Y9.75 G0 X8.652 Y9.024 ;TYPEKIN G1 F1800 X9.024 Y8.652 E138.0257 G0 F9000 X9.024 Y7.945 G1 F1800 X7.945 Y9.024 E138.08914 G1 X7.857 Y9.112 G0 F9000 X7.238 Y9.024 G1 F1800 X9.024 Y7.238 E138.19415 G1 X9.112 Y7.15 G0 F9000 X9.024 Y6.531 G1 F1800 X6.531 Y9.024 E138.34073 G1 X6.443 Y9.112 G0 F9000 X5.824 Y9.024 G1 F1800 X9.024 Y5.824 E138.52888 G1 X9.112 Y5.736 G0 F9000 X9.024 Y5.117 G1 F1800 X5.117 Y9.024 E138.75859 G1 X5.029 Y9.112 G0 F9000 X4.41 Y9.024 G1 F1800 X9.024 Y4.41 E139.02988 G1 X9.112 Y4.322 G0 F9000 X9.024 Y3.703 G1 F1800 X3.703 Y9.024 E139.34273 G1 X3.615 Y9.112 G0 F9000 X2.996 Y9.024 G1 F1800 X9.024 Y2.996 E139.69716 G1 X9.112 Y2.908 G0 F9000 X9.024 Y2.288 G1 F1800 X2.288 Y9.024 E140.09321 G1 X2.2 Y9.112 G0 F9000 X1.581 Y9.024 G1 F1800 X9.024 Y1.581 E140.53083 G1 X9.112 Y1.493 G0 F9000 X9.024 Y0.874 G1 F1800 X0.874 Y9.024 E141.01002 G1 X0.786 Y9.112 G0 F9000 X0.167 Y9.024 G1 F1800 X9.024 Y0.167 E141.53077 G1 X9.112 Y0.079 G0 F9000 X9.024 Y-.539 G1 F1800 X-.539 Y9.024 E142.09304 G1 X-.627 Y9.112 G0 F9000 X-1.246 Y9.024 G1 F1800 X9.024 Y-1.246 E142.69688 G1 X9.112 Y-1.334 G0 F9000 X9.024 Y-1.953 G1 F1800 X-1.953 Y9.024 E143.34228 G1 X-2.041 Y9.112 G0 F9000 X-2.66 Y9.024 G1 F1800 X9.024 Y-2.66 E144.02926 G1 X9.112 Y-2.748 G0 F9000 X9.024 Y-3.367 G1 F1800 X-3.367 Y9.024 E144.7578 G1 X-3.455 Y9.112 G0 F9000 X-4.075 Y9.024 G1 F1800 X9.024 Y-4.075 E145.52797 G1 X9.112 Y-4.163 G0 F9000 X9.024 Y-4.782 G1 F1800 X-4.782 Y9.024 E146.33971 G1 X-4.87 Y9.112 G0 F9000 X-5.489 Y9.024 G1 F1800 X9.024 Y-5.489 E147.19302 G1 X9.112 Y-5.577 G0 F9000 X9.024 Y-6.196 G1 F1800 X-6.196 Y9.024 E148.0879 G1 X-6.284 Y9.112 G0 F9000 X-6.903 Y9.024 G1 F1800 X9.024 Y-6.903 E149.02435 G1 X9.112 Y-6.991 G0 F9000 X9.024 Y-7.61 G1 F1800 X-7.61 Y9.024 E150.00236 G1 X-7.698 Y9.112 G0 F9000 X-8.317 Y9.024 G1 F1800 X9.024 Y-8.317 E151.02195 G1 X9.112 Y-8.405 G0 F9000 X9.024 Y-9.024 G1 F1800 X-9.024 Y9.024 E152.0831 G1 X-9.112 Y9.112 G0 F9000 X-9.024 Y8.317 G1 F1800 X8.317 Y-9.024 E153.10268 G1 X8.405 Y-9.112 G0 F9000 X7.61 Y-9.024 G1 F1800 X-9.024 Y7.61 E154.0807 G1 X-9.112 Y7.698 G0 F9000 X-9.024 Y6.903 G1 F1800 X6.903 Y-9.024 E155.01714 G1 X6.991 Y-9.112 G0 F9000 X6.196 Y-9.024 G1 F1800 X-9.024 Y6.196 E155.91202 G1 X-9.112 Y6.284 G0 F9000 X-9.024 Y5.489 G1 F1800 X5.489 Y-9.024 E156.76533 G1 X5.577 Y-9.112 G0 F9000 X4.782 Y-9.024 G1 F1800 X-9.024 Y4.782 E157.57707 G1 X-9.112 Y4.87 G0 F9000 X-9.024 Y4.075 G1 F1800 X4.075 Y-9.024 E158.34724 G1 X4.163 Y-9.112 G0 F9000 X3.367 Y-9.024 G1 F1800 X-9.024 Y3.367 E159.07579 G1 X-9.112 Y3.455 G0 F9000 X-9.024 Y2.66 G1 F1800 X2.66 Y-9.024 E159.76276 G1 X2.748 Y-9.112 G0 F9000 X1.953 Y-9.024 G1 F1800 X-9.024 Y1.953 E160.40817 G1 X-9.112 Y2.041 G0 F9000 X-9.024 Y1.246 G1 F1800 X1.246 Y-9.024 E161.012 G1 X1.334 Y-9.112 G0 F9000 X0.539 Y-9.024 G1 F1800 X-9.024 Y0.539 E161.57427 G1 X-9.112 Y0.627 G0 F9000 X-9.024 Y-.167 G1 F1800 X-.167 Y-9.024 E162.09503 G1 X-0.079 Y-9.112 G0 F9000 X-.874 Y-9.024 G1 F1800 X-9.024 Y-.874 E162.57422 G1 X-9.112 Y-.786 G0 F9000 X-9.024 Y-1.581 G1 F1800 X-1.581 Y-9.024 E163.01184 G1 X-1.493 Y-9.112 G0 F9000 X-2.288 Y-9.024 G1 F1800 X-9.024 Y-2.288 E163.40789 G1 X-9.112 Y-2.2 G0 F9000 X-9.024 Y-2.996 G1 F1800 X-2.996 Y-9.024 E163.76231 G1 X-2.908 Y-9.112 G0 F9000 X-3.703 Y-9.024 G1 F1800 X-9.024 Y-3.703 E164.07516 G1 X-9.112 Y-3.615 G0 F9000 X-9.024 Y-4.41 G1 F1800 X-4.41 Y-9.024 E164.34645 G1 X-4.322 Y-9.112 G0 F9000 X-5.117 Y-9.024 G1 F1800 X-9.024 Y-5.117 E164.57617 G1 X-9.112 Y-5.029 G0 F9000 X-9.024 Y-5.824 G1 F1800 X-5.824 Y-9.024 E164.76431 G1 X-5.736 Y-9.112 G0 F9000 X-6.531 Y-9.024 G1 F1800 X-9.024 Y-6.531 E164.91089 G1 X-9.112 Y-6.443 G0 F9000 X-9.024 Y-7.238 G1 F1800 X-7.238 Y-9.024 E165.0159 G1 X-7.15 Y-9.112 G0 F9000 X-7.945 Y-9.024 G1 F1800 X-9.024 Y-7.945 E165.07934 G1 X-9.112 Y-7.857 G0 F9000 X-9.024 Y-8.652 G1 F1800 X-8.652 Y-9.024 E165.10122 G0 F9000 X-8.652 Y-8.75 G0 X9.18 Y9.18 G0 X9.25 Y9.25 ;TIME_ELAPSED:123.015787 ;LAYER:4 G0 X9.25 Y9.25 Z1.08 ;TYPE:WALL-INNER G1 F3600 X-9.25 Y9.25 E165.87036 G1 X-9.25 Y-9.25 E166.6395 G1 X9.25 Y-9.25 E167.40864 G1 X9.25 Y9.25 E168.17778 G0 F9000 X9.75 Y9.75 ;TYPE:WALL-OUTER G1 F1800 X-9.75 Y9.75 E168.98849 G1 X-9.75 Y-9.75 E169.79921 G1 X9.75 Y-9.75 E170.60993 G1 X9.75 Y9.75 E171.42064 G0 F9000 X9.5 Y9.75 G0 X9.024 Y9.024
Re: Filament Dump Start Script - Cura June 02, 2017 06:38PM |
Re: Filament Dump Start Script - Cura June 03, 2017 02:40AM |
Re: Filament Dump Start Script - Cura June 03, 2017 02:43AM |
Re: Filament Dump Start Script - Cura June 03, 2017 02:49AM |
Re: Filament Dump Start Script - Cura June 03, 2017 12:40PM |
Re: Filament Dump Start Script - Cura June 03, 2017 12:42PM |
