New delta printer impossible to calibrate with firmware May 26, 2017 07:47PM |
Re: New delta printer impossible to calibrate with firmware May 27, 2017 02:10AM |
Re: New delta printer impossible to calibrate with firmware May 28, 2017 03:18AM |
Re: New delta printer impossible to calibrate with firmware May 28, 2017 04:27AM |
Re: New delta printer impossible to calibrate with firmware May 28, 2017 06:21AM |
Re: New delta printer impossible to calibrate with firmware May 28, 2017 07:16AM |
Re: New delta printer impossible to calibrate with firmware May 28, 2017 07:28AM |
Re: New delta printer impossible to calibrate with firmware May 28, 2017 01:21PM |
Re: New delta printer impossible to calibrate with firmware May 28, 2017 01:34PM |
Re: New delta printer impossible to calibrate with firmware May 28, 2017 02:07PM |
DjDemonD
However with marlin the number of parameters you can adjust, just isn't enough...
Re: New delta printer impossible to calibrate with firmware May 28, 2017 03:16PM |
Re: New delta printer impossible to calibrate with firmware May 28, 2017 11:42PM |
ohfurryone
- Make sure your end-stops are fairly accurate by measuring from the base of the printer.
- Place a piece of masking tape on one side of your bed along the X axis from center to edge.
- Lower nozzle to the bed and scribble around it with a pencil, raise and find center of circle left behind.
- Find an accurate ruler, square, fabric measuring tape ect. and mark out 20, 40, 60 and 80mm from center to edge.
- Move the nozzle along the bed on the X axis and see if it scales to 60-80mm properly, you should find it will be out by 1/2mm or so.
Change Smooth_Delta_Rod_Offset up and down to compensate. You eventually want to adjust it in .25mm intervals, until the nozzle ends up bang on at 80mm. The reason why you need multiple measurements is if one is 1/2mm wrong, it will stick out and you can re-mark it.
Re: New delta printer impossible to calibrate with firmware May 29, 2017 05:09AM |
DjDemonD
Good luck, sensors often are easier but not necessarily more accurate, I sometimes check the sensor by manually calibrating.
Re: New delta printer impossible to calibrate with firmware May 29, 2017 10:06AM |
titeuf007
DjDemonD
personally i have tried without sensor and no good results
if you keep an eye about my youtube video you will see that i have used esch3D website to tune my delta
but it s not perfect on all corners after spending so much time...smoothieware do it without no brain storming if you add a microswitch which cost less than 4usd(for a good one..)
so why we shouldn t use them?it s really cheap actually and will be more easy to tune
now i am agree with you we need to check some points like same rod lenght,towers are equal distance etc etc
