Delta G33 Auto Level, Bed not leveled
June 09, 2017 12:54AM
I have latest Marlin 1.1.3 I enabeled
delta Calibration wit fixed Z probe. I run G33 P7, everything goes well
M500, but the Bed is not leveled if I check it manually, about a millimetre
or so in the center from the corners
Am I doing something wrong or ?
Please advise
Mario
LVD
Re: Delta G33 Auto Level, Bed not leveled
June 09, 2017 05:19AM
probably but with that info hard to tell
June 09, 2017 06:14AM
what inormation you need to solve this problem?
I'm more than happy to give any ingo you need
LVD
June 09, 2017 06:20AM
video and screen copy of the calibration results (G33 P3 V2); how you proceed with manual check,...
Edited 1 time(s). Last edit at 06/09/2017 06:20AM by LVD.
June 09, 2017 08:09AM
First, when I manually leveled the Bed was Delta Radius 161,42 and I manually adjusted x,y,z endsops
The bed was leveled to a certain degree.
When I run G33 Delta Radius is around 164 and Bed is not leveled.
I'v run G33 P3 V2 , here is code from Repetier:
13:47:30.613 : G33 Auto Calibrate
13:47:31.615 : Checking... AC
13:47:31.618 : .Height:259.42 Ex:+0.00 Ey:+0.00 Ez:+0.00 Radius:161.24
13:47:31.620 : .Tower angle : Tx:+0.00 Ty:+0.00 Tz:+0.00
13:47:50.456 : . c:+0.00 x:-0.06 y:+0.23 z:+0.92
13:47:50.458 : . yz:+0.98 zx:-0.40 xy:+0.35
13:47:50.460 : Iteration : 01 std dev:0.554
13:47:50.463 : .Height:259.11 Ex:-0.90 Ey:+0.00 Ez:-0.03 Radius:163.91
13:47:50.466 : .Tower angle : Tx:+1.32 Ty:+0.39 Tz:+0.00
13:48:12.702 : . c:-0.32 x:+0.02 y:-0.55 z:-0.06
13:48:12.704 : . yz:-0.35 zx:-0.58 xy:+0.03
13:48:12.706 : Iteration : 02 std dev:0.353
13:48:12.709 : .Height:259.49 Ex:-0.71 Ey:+0.00 Ez:-0.10 Radius:164.49
13:48:12.712 : .Tower angle : Tx:+2.32 Ty:+0.65 Tz:+0.00
13:48:34.847 : . c:+0.11 x:+0.46 y:-0.30 z:+0.25
13:48:34.848 : . yz:-0.21 zx:+0.04 xy:+0.20
13:48:34.850 : Iteration : 03 std dev:0.256
13:48:34.853 : .Height:259.52 Ex:-0.28 Ey:-0.11 Ez:+0.00 Radius:164.23
13:48:34.857 : .Tower angle : Tx:+2.95 Ty:+0.81 Tz:+0.00
13:48:57.029 : . c:+0.05 x:+0.43 y:-0.28 z:+0.31
13:48:57.031 : . yz:-0.18 zx:+0.17 xy:+0.02
13:48:57.033 : Iteration : 04 std dev:0.245
13:48:57.036 : .Height:259.39 Ex:-0.11 Ey:-0.51 Ez:+0.00 Radius:164.44
13:48:57.039 : .Tower angle : Tx:+3.37 Ty:+0.96 Tz:+0.00
13:49:19.251 : . c:+0.00 x:+0.31 y:-0.21 z:+0.14
13:49:19.252 : . yz:-0.29 zx:+0.09 xy:-0.03
13:49:19.255 : Iteration : 05 std dev:0.189
13:49:19.258 : .Height:259.25 Ex:+0.00 Ey:-0.89 Ez:-0.13 Radius:164.43
13:49:19.260 : .Tower angle : Tx:+3.56 Ty:+0.98 Tz:+0.00
13:49:41.495 : . c:+0.00 x:+0.23 y:-0.12 z:+0.13
13:49:41.497 : . yz:-0.23 zx:+0.07 xy:-0.04
13:49:41.499 : Iteration : 06 std dev:0.144
13:49:41.502 : .Height:259.08 Ex:+0.00 Ey:-1.24 Ez:-0.28 Radius:164.44
13:49:41.505 : .Tower angle : Tx:+3.66 Ty:+0.96 Tz:+0.00
13:50:03.738 : . c:-0.00 x:+0.13 y:-0.02 z:+0.10
13:50:03.740 : . yz:-0.15 zx:-0.02 xy:-0.07
13:50:03.742 : Iteration : 07 std dev:0.090
13:50:03.745 : .Height:259.01 Ex:+0.00 Ey:-1.39 Ez:-0.34 Radius:164.42
13:50:03.748 : .Tower angle : Tx:+3.70 Ty:+0.95 Tz:+0.00
13:50:25.982 : . c:-0.01 x:+0.12 y:+0.01 z:+0.08
13:50:25.983 : . yz:-0.18 zx:-0.05 xy:-0.08
13:50:25.986 : Iteration : 08 std dev:0.093
13:50:25.991 : .Height:258.96 Ex:+0.00 Ey:-1.52 Ez:-0.41 Radius:164.39
13:50:25.991 : .Tower angle : Tx:+3.71 Ty:+0.91 Tz:+0.00
13:50:48.226 : . c:+0.02 x:+0.10 y:+0.07 z:+0.16
13:50:48.227 : . yz:-0.05 zx:-0.07 xy:-0.09
13:50:48.229 : Iteration : 09 std dev:0.090
13:50:48.232 : .Height:258.95 Ex:+0.00 Ey:-1.52 Ez:-0.36 Radius:164.34
13:50:48.235 : .Tower angle : Tx:+3.78 Ty:+0.92 Tz:+0.00
13:51:10.472 : . c:+0.00 x:+0.15 y:+0.05 z:+0.15
13:51:10.474 : . yz:-0.08 zx:-0.03 xy:-0.10
13:51:10.476 : Calibration OK rolling back.
13:51:10.479 : .Height:258.96 Ex:+0.00 Ey:-1.52 Ez:-0.41 Radius:164.39
13:51:10.481 : .Tower angle : Tx:+3.71 Ty:+0.91 Tz:+0.00
13:51:10.484 : Save with M500 and/or copy to Configuration.h
I save with M500
You asked for a video , what did you have in mind?
thanks
Mario
Edited 1 time(s). Last edit at 06/09/2017 09:21AM by novio8.
LVD
June 09, 2017 11:31AM
With your manual calibration:
c:+0.00 ... center is at zero
x:-0.06 y:+0.23 z:+0.92 ... Z-tower is 1mm higher
yz:+0.98 zx:-0.40 xy:+0.35 ... point opposite the X-tower is also 1mm higher
This is not "leveled to a certain degree" but completely off
after G33
c:+0.00 ... center is at 0
x:+0.15 y:+0.05 z:+0.15 towers are a bit higher
yz:-0.05 zx:-0.07 xy:-0.09 points opposite the towers are a bit lower
What do you mean the bed is not levelled? Still much better then the manual starting point.
But you still have a big std.dev. and rather important angular corrections; that indicates something is wrong in your build and/or probe...
run a M48 X Y S in the center, at the towers and opposite the towers to test the probe repeatability at different locations (enable Z_MIN_PROBE_REPEATABILITY_TEST in Configuration.h) and check your frame (perpendicular towers to the bed; equidistant triangles,...)
Edited 1 time(s). Last edit at 06/09/2017 11:32AM by LVD.
June 09, 2017 03:45PM
By not leveled I mean when I print Bed is Convex so edges are lower than the center
so extrusion on the edges is higher than in the center.
I jus run M48 on several points and results are as follows
21:39:47.008 : X:0.00 Y:0.00 Z:259.24 E:0.00 Count X:54234 Y:54234 Z:54234
21:39:56.335 : M48 Z-Probe Repeatability Test
21:40:11.273 : Finished!
21:40:11.274 : Mean: 0.053735 Min: 0.049 Max: 0.059 Range: 0.010
21:40:11.276 : Standard Deviation: 0.005005
21:40:11.279 : X:0.00 Y:-45.00 Z:24.90 E:0.00 Count X:31715 Y:31715 Z:27704
21:40:26.576 : X:0.00 Y:0.00 Z:259.24 E:0.00 Count X:54234 Y:54234 Z:54234
21:40:59.454 : M48 Z-Probe Repeatability Test
21:41:14.573 : Finished!
21:41:14.574 : Mean: -0.005438 Min: -0.018 Max: 0.002 Range: 0.020
21:41:14.575 : Standard Deviation: 0.006396
21:41:14.579 : X:60.00 Y:-25.00 Z:24.90 E:0.00 Count X:27625 Y:33603 Z:28539
21:41:35.288 : X:0.00 Y:0.00 Z:259.24 E:0.00 Count X:54234 Y:54234 Z:54234
21:41:50.702 : M48 Z-Probe Repeatability Test
21:42:05.817 : Finished!
21:42:05.818 : Mean: 0.018539 Min: 0.002 Max: 0.022 Range: 0.020
21:42:05.820 : Standard Deviation: 0.006401
21:42:05.824 : X:60.00 Y:-25.00 Z:24.90 E:0.00 Count X:27625 Y:33603 Z:28539
21:42:35.199 : M48 Z-Probe Repeatability Test
21:42:43.960 : Finished!
21:42:43.961 : Mean: 0.010532 Min: 0.002 Max: 0.012 Range: 0.010
21:42:43.962 : Standard Deviation: 0.002994
21:42:43.966 : X:60.00 Y:-25.00 Z:24.90 E:0.00 Count X:27625 Y:33603 Z:28539
21:42:54.846 : M48 Z-Probe Repeatability Test
21:43:04.860 : Finished!
21:43:04.862 : Mean: -0.227460 Min: -0.238 Max: -0.218 Range: 0.020
21:43:04.863 : Standard Deviation: 0.005390
21:43:04.867 : X:-60.00 Y:-25.00 Z:24.90 E:0.00 Count X:33603 Y:27625 Z:28539
21:43:23.110 : M48 Z-Probe Repeatability Test
21:43:32.659 : Finished!
21:43:32.660 : Mean: 0.735846 Min: 0.733 Max: 0.743 Range: 0.010
21:43:32.662 : Standard Deviation: 0.004587
21:43:32.666 : X:0.00 Y:115.00 Z:24.90 E:0.00 Count X:24488 Y:24488 Z:34770
21:44:20.055 : M48 Z-Probe Repeatability Test
21:44:29.136 : Finished!
21:44:29.138 : Mean: 0.343942 Min: 0.329 Max: 0.349 Range: 0.020
21:44:29.139 : Standard Deviation: 0.006715
21:44:29.143 : X:60.00 Y:95.00 Z:24.90 E:0.00 Count X:21313 Y:28762 Z:33846
21:44:41.342 : M48 Z-Probe Repeatability Test
21:44:51.388 : Finished!
21:44:51.389 : Mean: -0.192062 Min: -0.201 Max: -0.191 Range: 0.010
21:44:51.390 : Standard Deviation: 0.003003
21:44:51.394 : X:-60.00 Y:95.00 Z:24.90 E:0.00 Count X:28762 Y:21313 Z:33846
Edited 1 time(s). Last edit at 06/09/2017 04:47PM by novio8.
LVD
June 09, 2017 08:05PM
is a lot; I'm getting around 0.010 and printing flat. But that is due to the build accuracy.
Another thing pops into my mind; did you enable EEPROM in order to be able to store the settings? After M500 do you get "Settings Stored (453 bytes; crc -24675)"?
June 10, 2017 09:36AM
yes I did enable EEPROM and settings are Stored
