Help! New delta G28 doesnt home. But moves all motors about 10mm opposite way
Posted by Jmtech
July 25, 2017 03:05PM
Hi! Got a new delta. Loved the build. Its an Anycubic plus.
Problem im having.
When i send Home to the printer (code or on the interface). It doesnt go up. It goes down. But it doesnt try to home. Each motor in turn lowers a few mm. Then if i press it again, the same thing happens?
Re: Help! New delta G28 doesnt home. But moves all motors about 10mm opposite way
July 25, 2017 03:26PM
Endstops report triggered even though they're physically not? Maybe run M119 and see?
Wow. Çheers! Z min open. X y and z max triggered.... how bizarre.
Most likely cause?
Firmware is preconfigured by the supplier.... but wonder if its wiring or config....
Thanks in advance
J
All triggered. Wiring issue. Im such a tool. Did it according to the board instead of the config. Doh!
Life saver!
J
