300mm PVC/acrylic tube as a shell August 28, 2017 08:35AM |
Re: 300mm PVC/acrylic tube as a shell August 30, 2017 01:43AM |
Re: 300mm PVC/acrylic tube as a shell August 30, 2017 11:28AM |
Re: 300mm PVC/acrylic tube as a shell August 30, 2017 12:00PM |
Re: 300mm PVC/acrylic tube as a shell August 31, 2017 02:11AM |
Re: 300mm PVC/acrylic tube as a shell August 31, 2017 06:41AM |
Re: 300mm PVC/acrylic tube as a shell September 01, 2017 01:51AM |
Re: 300mm PVC/acrylic tube as a shell September 07, 2017 04:47AM |
Re: 300mm PVC/acrylic tube as a shell September 07, 2017 01:08PM |
Re: 300mm PVC/acrylic tube as a shell September 07, 2017 01:15PM |
Re: 300mm PVC/acrylic tube as a shell September 07, 2017 01:29PM |
Re: 300mm PVC/acrylic tube as a shell September 07, 2017 01:57PM |
Re: 300mm PVC/acrylic tube as a shell September 07, 2017 03:19PM |
Re: 300mm PVC/acrylic tube as a shell September 08, 2017 03:34AM |
Re: 300mm PVC/acrylic tube as a shell September 08, 2017 03:46AM |
Re: 300mm PVC/acrylic tube as a shell September 08, 2017 05:26PM |
Re: 300mm PVC/acrylic tube as a shell September 08, 2017 10:46PM |
Re: 300mm PVC/acrylic tube as a shell September 08, 2017 11:45PM |
lhartmann
Also found this guy on thingiverse that used PCBs as carts/effector mounting plates. Neat idea, PCBs are rigid and have a low profile, which is useful given the diameter limitation. He did not take full advantage of his concept, though. LED lighting would have been a really nice feature.
Re: 300mm PVC/acrylic tube as a shell September 09, 2017 12:00AM |
Re: 300mm PVC/acrylic tube as a shell September 09, 2017 12:05AM |
kasom
lhartmann
I got inspired by dc42's smart PCB effector. My version is dumb.
Re: 300mm PVC/acrylic tube as a shell September 09, 2017 02:37AM |
Re: 300mm PVC/acrylic tube as a shell September 09, 2017 03:59AM |
Re: 300mm PVC/acrylic tube as a shell September 09, 2017 05:35AM |
Re: 300mm PVC/acrylic tube as a shell September 09, 2017 05:50AM |
o_lampe
Placing the belts inside the extrusion is definitely possible. ( see D-BOT CoreXY )
Screwing the extrusion directly to the tube wall, might stress the pipe. Tighten it differently at one of the towers could end up in an egg shaped printer.
Re: 300mm PVC/acrylic tube as a shell September 09, 2017 07:27AM |
Re: 300mm PVC/acrylic tube as a shell September 09, 2017 09:09AM |
Re: 300mm PVC/acrylic tube as a shell September 09, 2017 09:20AM |
Re: 300mm PVC/acrylic tube as a shell September 09, 2017 09:34AM |
Re: 300mm PVC/acrylic tube as a shell September 09, 2017 09:44AM |
Re: 300mm PVC/acrylic tube as a shell September 09, 2017 11:04AM |
