Double Arm flying extruder. September 05, 2017 10:40PM |
Re: Double Arm flying extruder. September 06, 2017 12:21AM |
Re: Double Arm flying extruder. September 06, 2017 12:27AM |
Re: Double Arm flying extruder. September 06, 2017 03:40AM |
Re: Double Arm flying extruder. September 06, 2017 03:42AM |
frankvdh
Your "double delta" idea would allow the same kind of thing in software, doing on-the-fly digital filtering of the motion commands so that the extruder stays within some specified distance of the hot-end position. Or software could pre-calculate the motion of the extruder to keep it within bounds of speed and acceleration and distance from the hot-end. Effectively, this would "tune" your suspension to each object being printed.
Re: Double Arm flying extruder. September 06, 2017 03:56AM |
Re: Double Arm flying extruder. September 06, 2017 05:06AM |
Re: Double Arm flying extruder. September 06, 2017 05:35AM |
clearlynotstefan
THe thing is, with a flying extruder, you're already adding that weight to the carrier anyway. and worse, you're suspending it from elastic which is going to bounce it around and exacerbate the effect it has, How much weight can you be adding by adding arms so it gets pushed where it needs to be instead of dangling in the air?
Re: Double Arm flying extruder. September 06, 2017 05:55AM |
Re: Double Arm flying extruder. September 06, 2017 11:31AM |
Re: Double Arm flying extruder. September 06, 2017 04:07PM |
Re: Double Arm flying extruder. September 06, 2017 04:31PM |
clearlynotstefan
Re: Double Arm flying extruder. September 06, 2017 04:53PM |
Re: Double Arm flying extruder. September 07, 2017 06:40PM |
Re: Double Arm flying extruder. September 07, 2017 06:52PM |
Re: Double Arm flying extruder. September 07, 2017 07:11PM |
Re: Double Arm flying extruder. September 07, 2017 07:16PM |
Re: Double Arm flying extruder. September 07, 2017 07:26PM |
Re: Double Arm flying extruder. September 08, 2017 02:45AM |
Re: Double Arm flying extruder. September 08, 2017 09:22AM |
Re: Double Arm flying extruder. September 15, 2017 12:10AM |
Re: Double Arm flying extruder. September 15, 2017 02:43AM |
Re: Double Arm flying extruder. September 15, 2017 03:37AM |
dc42
With the extruder drive mounted directly on the effector, you need very little retraction and it doesn't need to be fast. So in this situation you can use a gear ratio much higher than 3:1. The remote direct drive extruders on the market use 30:1 and 40:1.
Re: Double Arm flying extruder. October 16, 2017 05:42PM |
Re: Double Arm flying extruder. October 18, 2017 05:48PM |
