ball-cap rod-end concept pros and cons September 09, 2017 12:44AM |
Re: ball-cap rod-end concept pros and cons September 09, 2017 02:23AM |
Re: ball-cap rod-end concept pros and cons September 09, 2017 03:45AM |
Re: ball-cap rod-end concept pros and cons September 09, 2017 07:51AM |
Re: ball-cap rod-end concept pros and cons September 10, 2017 04:05PM |
Re: ball-cap rod-end concept pros and cons September 11, 2017 04:56AM |
Re: ball-cap rod-end concept pros and cons September 11, 2017 01:36PM |
Re: ball-cap rod-end concept pros and cons September 12, 2017 09:03AM |
Re: ball-cap rod-end concept pros and cons September 15, 2017 07:49PM |
Re: ball-cap rod-end concept pros and cons May 14, 2018 03:00PM |
Re: ball-cap rod-end concept pros and cons May 14, 2018 03:40PM |
Re: ball-cap rod-end concept pros and cons June 15, 2018 06:17PM |
Re: ball-cap rod-end concept pros and cons June 16, 2018 03:48AM |
Re: ball-cap rod-end concept pros and cons June 16, 2018 04:59AM |
Re: ball-cap rod-end concept pros and cons June 16, 2018 05:29AM |
Re: ball-cap rod-end concept pros and cons June 16, 2018 05:31PM |
Re: ball-cap rod-end concept pros and cons June 16, 2018 08:00PM |
Re: ball-cap rod-end concept pros and cons June 17, 2018 01:22AM |
So for hobbyists it seems useless...[Hylite]
Re: ball-cap rod-end concept pros and cons June 17, 2018 05:23AM |
Re: ball-cap rod-end concept pros and cons June 17, 2018 01:19PM |
Re: ball-cap rod-end concept pros and cons June 17, 2018 06:10PM |
Re: ball-cap rod-end concept pros and cons November 11, 2018 06:27PM |
Re: ball-cap rod-end concept pros and cons November 12, 2018 03:58AM |
Re: ball-cap rod-end concept pros and cons November 12, 2018 08:43AM |
Re: ball-cap rod-end concept pros and cons November 12, 2018 01:01PM |
Re: ball-cap rod-end concept pros and cons November 12, 2018 04:31PM |
Re: ball-cap rod-end concept pros and cons November 13, 2018 08:06PM |
Re: ball-cap rod-end concept pros and cons November 14, 2018 01:04AM |
Re: ball-cap rod-end concept pros and cons December 03, 2018 01:34AM |
Re: ball-cap rod-end concept pros and cons December 03, 2018 01:04PM |
Redemptioner
Like I have said before, grab an effector on a mag ball setup and give it a wiggle (and it will wiggle around)
Redemptioner
If we take DC42’s favorite mag balls he keeps spruiking by hayden, then you can see we are only constraining about 15% of the ball with the cup, and we now have to align the ball on the effector across 3 axis using a bolt hopefully centered on the ball through another slightly oversize hole in the effector. If we use a DC42 effector this is easier (we won’t get into the other problems with this effector design), but it still has play in the ball mounting holes and you can get 1mm out in the ball mounts from side to side..
Redemptioner
If we use a DC42 effector this is easier (we won’t get into the other problems with this effector design)...
