Re: ball-cap rod-end concept pros and cons December 03, 2018 01:13PM |
Re: ball-cap rod-end concept pros and cons December 03, 2018 01:55PM |
Re: ball-cap rod-end concept pros and cons December 03, 2018 11:06PM |
dc42
My effector has zero wiggle. Yes, ZERO.
dc42
I'm sorry, but IMHO that's utter rubbish! The holes in the effector are slightly undersize (2.9mm), not oversize. The ball studs are a close fit in them with nothing like 1mm side to side play before tightening, maybe 0.1mm. And what exactly do you mean by "only constraining about 15% of the ball with the cup"? Is that by surface area, angle, or what? Any way I measure it, it's far more than 15%. The ball ends are more than adequately constrained, bearing in mind that the forces applied during printing are predominantly longitudinal.
dc42
You have obviously never used Haydn Huntley's magnetic joints. Please stop assuming that your experience with inferior magnetic joints applies to all magnetic joints.
dc42
Suggestions for improving our products are always welcome, provided they are based on actual experience and not theorising.
Re: ball-cap rod-end concept pros and cons December 03, 2018 11:43PM |
frankvdh
There seems to be some assumption that rod-ends don't have any play, which is completely contrary to my experience. One of the reasons I went to mag-ball was the play in the rod-ends.
etfrench
Whether you use mag joints or ball ends, you still need to bolt one end to the effector. The potential for misalignment is the same for both. My effector was made on a CNC machine and distances between all of the balls are within a few microns of being equal (including the balls on the carriages).
Re: ball-cap rod-end concept pros and cons December 04, 2018 02:37AM |
Re: ball-cap rod-end concept pros and cons December 04, 2018 03:22AM |
Re: ball-cap rod-end concept pros and cons December 04, 2018 03:43AM |
