Belt & Pully design - build question September 09, 2017 05:48PM |
Re: Belt & Pully design - build question September 09, 2017 06:20PM |
Re: Belt & Pully design - build question September 09, 2017 06:25PM |
Re: Belt & Pully design - build question September 10, 2017 12:15AM |
Re: Belt & Pully design - build question September 10, 2017 12:28AM |
Re: Belt & Pully design - build question September 10, 2017 01:58AM |
Re: Belt & Pully design - build question September 10, 2017 07:45AM |
Re: Belt & Pully design - build question September 10, 2017 11:36AM |
o_lampe
My question about the subject would be: Is it better to mount the belt in the center or off center?
When it's centered, even the smallest difference in friction can cause the carrier to wobble.
When it's a bit off center, the carrier is always preloaded. So small differences in friction won't change the movement. But wear is slightly bigger.
Too much offset and you get racking.
That's just my gut feeling talking and it's not scientificly evaluated...
Re: Belt & Pully design - build question September 10, 2017 12:12PM |
Re: Belt & Pully design - build question September 10, 2017 02:34PM |
Re: Belt & Pully design - build question September 10, 2017 03:54PM |
Re: Belt & Pully design - build question September 10, 2017 07:58PM |
Re: Belt & Pully design - build question September 11, 2017 01:26AM |
Re: Belt & Pully design - build question September 11, 2017 01:39AM |
dc42
o_lampe
I could be wrong, but won't the preload change direction when the belt direction reverses, leading to backlash?
Re: Belt & Pully design - build question September 11, 2017 04:05AM |
Mils24
etfrench, is that pulleys centred (bottom image in OP) or belt centred (top image in OP)???
Thanks
Re: Belt & Pully design - build question September 11, 2017 08:07AM |
Re: Belt & Pully design - build question September 11, 2017 10:15AM |
Re: Belt & Pully design - build question September 11, 2017 01:10PM |
hercek
If you want more opinions then here you go:
- Belt centered is slightly better (especially as for as bearing/rod wear goes).
- As for as predictability of backslash due to off center belt: It will also depend on how much off-center the belt mount is, the position of the head over the build platform, the current acceleration forces and friction between hotend and the part. I do not think it makes sense to consider higher predictability of off-center belt as a positive because the problem is much more complex. Better get longer linear bearings (or two bearings on each rod) to lower backslash in general if you are concerned about this.
- Space your rods as much far away as it is reasonable (55 mm sounds on the low side). The same is true for diagonal rods.
- Use at least Ø 12 mm rods. On my delta, 70 cm long, Ø 8 mm rods did bent visibly during printing. Will not be a big problem at low accelerations.
- Your glass core GT2 belts will be too springy. But it does not really matter if you intend to use accelerations below 5000 mm/s². Well for such low accelerations you can probably go for Ø 8 mm rods too.
Edit: Yeah, if you are going to buy cheap Chinese linear bearing then buy about two times as much as you actually need. Then select ones which have the right fit (not too loose, not too tight). Throw the rest into a garbage bin ... or give it to your enemy if you feel fancy :-D
Re: Belt & Pully design - build question September 11, 2017 02:35PM |
Re: Belt & Pully design - build question September 11, 2017 02:53PM |
dc42
My 2p worth:
- I agree with attaching the belt centrally in the carriage if you have the choice.
- The spacing between diagonal rods is a compromise. Larger gives more stability; but it also increases the size of the effector (unless it needs to be large for other reasons), which reduces build space because the nozzle can't get as close to the towers. We chose 55mm for the Duet3D smart effector and I think this is a good compromise for a printer with a build diameter of 300mm. But it's too large for a Mini Kossel.
- Yes glass core GT2 belts are standard. The steel core ones wear out very quickly unless you use large diameter pulleys, which reduces resolution.
- Use 16 tooth pulleys, not 20 tooth. They give you better resolution, also the resolution is a more useful figure e.g. 10um per 1/16 microstep instead of 12.5um.
- For best results use 0.9deg motors and 24V power. But it's not essential, the print quality using 1.8deg motors is only slightly less.
- Use a nozzle-contact Z probe, such as our smart effector, or FSRs or piezos under the bed.
- Above all, design your printer so that the geometry is accurate. See [duet3d.com] for more.
HTH David
Re: Belt & Pully design - build question September 12, 2017 01:01AM |
Mils24
Sorry to sound stupid but how did you work that out? And also what does that mean? Is 1:10 good?
My set up will be same belt and pulleys (GT2 2mm + 20 tooth) and my rods will be spaced 55mm apart.
There seems to be a real split on belt centered or belt offset. I'm starting to think does it really matter??
Re: Belt & Pully design - build question September 12, 2017 04:56AM |
Re: Belt & Pully design - build question September 12, 2017 08:07AM |
Re: Belt & Pully design - build question September 12, 2017 08:51AM |
Re: Belt & Pully design - build question September 12, 2017 09:18AM |
hercek
Well, I typically use speed of 120 mm/s and accelerations 9000 mm/s², non-printing speed 250 mm/s.
Why would one build delta if not for speed? Cartesians can print at low speed just fine and they are much easier to calibrate and do not need as powerful electronics.
Well there are some other reasons to use a delta printer as well. E.g. when one wants to print very tall objects or just likes the funny way delta moves. But otherwise deltas have only disadvantages. They are harder to build precisely. And did I mention that they are a real pain to calibrate if you do not happen to have dc42's firmware or are not skilled enough to use my calibration notebook? And still the numerical calibration methods are not good enough. If you were unlucky and built your delta with skewed towers then you are screwed. You can just dump it and star over ... or wait till somebody implements calibration which will compensate for this. It is possible but nobody cared enough to implement it yet.
Re: Belt & Pully design - build question September 12, 2017 09:28AM |
Re: Belt & Pully design - build question September 12, 2017 09:55AM |
hercek
Does it compensate for wrong tower positions only or also for skewed towers (towers which are not equidistant to each other)?
If it does the later too then that is great! Se could dismiss the calibration disadvantage of deltas as irrelevant. Deltas would need just more powerful/expensive hardware. Not a big deal.
Re: Belt & Pully design - build question September 12, 2017 10:12AM |
Re: Belt & Pully design - build question September 12, 2017 11:58AM |
