looking for stubby ball stud
Posted by shadowphile
September 10, 2017 06:33PM
Hi, I can't find the source for these kinds of neck-less ball studs:
The stud needs to be M3 and the ball 3/8" (preferred, but I will take 10mm)
thanks
Re: looking for stubby ball stud
September 11, 2017 12:01AM
What are the thread size of Haydn's balls?
September 11, 2017 01:30AM
Im pretty sure Haydns are what you are looking for.
Go to Thingiverse,search for 'Zero-Backlash Magnetic Ball Joint Rod Ends' and drop Haydn an email.
September 11, 2017 02:49AM
They are also in stock at Duet3D.com in the UK.
September 11, 2017 12:32PM
dc42 I cannot seem to find them on the Duet3D website, the echer3D website or on think3dprint3d.
what section are they in?
September 11, 2017 02:15PM
They are listed as addons to the smart effector at [www.duet3d.com]. If you email info at Duet3D dot com, I expect they will be happy to supply them on their own unless stocks are running low.
September 11, 2017 06:59PM
Mils24
I got the dimensions from Haydn and they are longer than those in the picture that I thought they would fit my setup.
However, I checked again and I can make them work, just need to have more care than before. The duet3d and the Ultibot ball-studs appear to be identical.
Trick Laser has their ball-cap rod-ends back in stock but I need to see if they will fit my machine. Otherwise, I will have them printed at Shapeways, although it won't be as accurate as the injection-molded Trick Laser parts. BTW, the Trick Laser parts have 5mm-wide shanks so the rods will need to be very large (I think archery shafts are the intended source)
thanks for your help!
