Re: FA-MAS mostly metal delta build - AKA Metal Gear November 17, 2017 04:42PM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 17, 2017 05:14PM |
FA-MAS
Got the new Igus bearings with adjustable preload. Got them installed and I was able to take out most of the play. If I took out any more, they would not move on the rail.
I am slightly disappointed that the adjustment screws are plastic, felt like I was damaging them just by turning them.
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 17, 2017 05:44PM |
toolson
I bought the same years ago and didn't even one print with them. They are not suitable for a delta printer. Adjustable preload or not, doesn't matter.
Maybe you are luckier, but everyone in the german subforum demounted the TWE rails. There is always a little play, at least in one axis.
If you tighten the adjustment too much, the play is low but the friction to high.
Expect that you will not be satisfied with them for long time.
I learned my lesson, mine are still for sale.
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 17, 2017 06:16PM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 17, 2017 06:18PM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 17, 2017 06:19PM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 18, 2017 03:06AM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 18, 2017 03:15AM |
FA-MAS
Having some issues with the dc42 ir sensor board. It blinks 4 times, but probe always reads 0 on the web interface and doesn't light up when I put anything near it.
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 18, 2017 03:21AM |
dc42
FA-MAS
If the led blinks at startup like it is supposed to but doesn't light up when you put your finger under the sensitive area, ask your supplier for a replacement. If it responds to your finger but not to the bed, then you probably have it mounted too high. The bottom edge should be about 1.5mm higher than the nozzle.
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 18, 2017 03:29AM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 18, 2017 04:53AM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 18, 2017 05:03AM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 18, 2017 07:54AM |
FA-MAS
dc42
FA-MAS
It does not light up when I put my finger under it.
Edit: ran autotune and it seems fine now.
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 20, 2017 03:35PM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 20, 2017 03:37PM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 20, 2017 03:45PM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 20, 2017 03:47PM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 20, 2017 03:50PM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 21, 2017 01:30AM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 21, 2017 06:27AM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 22, 2017 02:49PM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 22, 2017 03:23PM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 22, 2017 03:34PM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 24, 2017 11:27AM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 24, 2017 06:46PM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 24, 2017 07:18PM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 25, 2017 03:05AM |
FA-MAS
Having a weird issue with home position
When I home the printer, M114 reports Z position at 271.399
But that's not what's set in my config.g
And If I command it down to Z0, it stops about 5mm above the bed.
Edit: just added to homed height until Z0 came correct.
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 26, 2017 08:17PM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 27, 2017 03:22AM |
Re: FA-MAS mostly metal delta build - AKA Metal Gear November 27, 2017 03:37AM |
