Please help align the right size printer delta
Posted by Girl
September 20, 2017 01:38AM
Sorry for my english capital.
Currently I have a printer Delta but I get an error when printing it skewed size.
I'm testing block 2x2x2 cm cube size.
But during the printing process, the full height 2cm
The remaining width and breadth only 1,8cm.
I've aligned machine calibrated image below.
But still did not get the correct results.
Someone can help me
open | download - SET UP TRUC DELTA.png (186.5 KB)
Re: Please help align the right size printer delta
September 20, 2017 09:50AM
With an error of that size, most likely you have configured the diagonal rod length incorrectly in the configuration file or in the firmware. But you should print a large cube, because under or over extrusions can change the dimensions by a few tenths of a mm.
