Mid mounted pivoting extruders as a solution for a very short bowden October 25, 2017 12:47AM |
Re: Mid mounted pivoting extruders as a solution for a very short bowden October 25, 2017 03:10AM |
Re: Mid mounted pivoting extruders as a solution for a very short bowden October 25, 2017 04:30AM |
Re: Mid mounted pivoting extruders as a solution for a very short bowden October 25, 2017 05:54PM |
Re: Mid mounted pivoting extruders as a solution for a very short bowden October 25, 2017 06:14PM |
Re: Mid mounted pivoting extruders as a solution for a very short bowden October 25, 2017 06:17PM |
Re: Mid mounted pivoting extruders as a solution for a very short bowden October 25, 2017 07:43PM |
Re: Mid mounted pivoting extruders as a solution for a very short bowden October 26, 2017 03:11AM |
my swingarm base pivot point on the clamp to the extruder upright tube sucks, they squeak now, really horrible embarrassing design but it was one of the first and has not been revised. just barely good enough to test. something with bearings, an improved damping spring from my design, all would be good.
Re: Mid mounted pivoting extruders as a solution for a very short bowden October 26, 2017 03:20PM |
o_lampe
Now that your mention it... there is enough "meat" around the screws to add small flanged bearings.
My swinging extruder work without dampening. Do you see any overshoot when you try without dampers?
BTW: I like the cylindric shape of the Delrin gliders, they provide way more guidance than the v-rollers. Just wondering if the friction/stiction could be even lower with an hourglass shape instead off plain cylindric?
lets just say it's very durable for the task it has in this system, the forces involved dont even scratch its surface it looks brand new where it's running on the aluminum.|
Re: Mid mounted pivoting extruders as a solution for a very short bowden October 28, 2017 03:59AM |
Re: Mid mounted pivoting extruders as a solution for a very short bowden October 28, 2017 10:07AM |
Re: Mid mounted pivoting extruders as a solution for a very short bowden October 29, 2017 11:03AM |
Re: Mid mounted pivoting extruders as a solution for a very short bowden October 29, 2017 02:03PM |
Re: Mid mounted pivoting extruders as a solution for a very short bowden October 29, 2017 03:16PM |
Re: Mid mounted pivoting extruders as a solution for a very short bowden October 30, 2017 02:56AM |
