how to select the best cooling fan for my delta October 30, 2017 08:50PM |
Re: how to select the best cooling fan for my delta November 06, 2017 01:04PM |
Re: how to select the best cooling fan for my delta November 06, 2017 02:09PM |
Re: how to select the best cooling fan for my delta November 06, 2017 07:50PM |
Re: how to select the best cooling fan for my delta November 06, 2017 08:57PM |
Re: how to select the best cooling fan for my delta November 07, 2017 02:04PM |
frankvdh
30mm blower fans are *way* more expensive (~$8 each on AliExpress, vs $1.25 for a 50mm one), and 12V ones aren't common, (Hopefully someone will point me to a cheaper source!) and do half the airflow (1.85CFM vs 3.6CFM for a 50mm). So I (being a cheapskate) would always go for 1 * 50mm fan over 2 * 30mm fans.
OTOH, 3.6CFM is way too much for print cooling, so probably 1 * 30mm fan would be good for that. Or a 50mm fan running at half-speed or so, controlled via PWM by Repetier/Marlin.
I have had a 50mm blower mounted on my hot-end; it seemed to improve things.
Out of interest, my Stratasys uPrint has *big* blower fans at the side of the bed for print cooling.
What (apart from the noise) is the downside of leaving the print-cooling fan running all the time?
Re: how to select the best cooling fan for my delta November 11, 2017 04:20PM |
Re: how to select the best cooling fan for my delta November 11, 2017 10:06PM |
Re: how to select the best cooling fan for my delta November 16, 2017 02:36PM |
